    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 182.9k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @jgb said:
      1) When I first loaded a model with 42 layers, SU's layers panel took about 3/4 screen height, and did not need a vertical scroll bar.
      Your panel was longer due to your using a higher row height, and it had a vertical scroll bar. That is not a problem.
      The problem was the vertical scroll bar does not work (greyed out), nor does mouse wheel scrolling, so I cannot see the last 7 layers in the list.
      2) I often open a second SU session to clipboard copy reusable components from a different model. When I loaded the 2nd model, your layer panel stayed as the first model. It should have switched to the second model.
      Are you using Mac OSX ? Layers Panel does not support OSX for now.
      If not, what are your windows version, Internet Explorer version, and Sketchup version ?
      @jgb said:
      2) Since ALL my layers are numbered, in SU they sort properly, either ascending or descending when I click on the header.
      They were in seemingly random order in your layer panel, neither numeric nor alphabetic. I had to move them into the numeric order I wanted.
      The layer sort order should initially match the SU Layer sort order.
      The default order in SU layer is by creation order. The API doesn't allow to get how the user is sorting layers in the layers window.
      @jgb said:
      3) I simulate indenting/nesting by variable spacing the name of the layer after the number.
      You delete multiple spaces in the name.
      I'll look at that.
      @jgb said:
      4) I noticed that to create a nest of layers, you have to define a new group, then move the layers to be nested under that new group, and rename the group layer.
      In my case, this creates a redundant top level layer, and since I have a bunch of components inside that layer, it can't be eliminated.
      You should consider the ability to elevate any existing layer to a group header status.
      I wondered about that and decided not to do it. Read this old thread : http://sketchucation.com/forums/viewtopic.php?p=472428
      Remember that Layers Panel has a whole different logic that SU's layers window.
      @jgb said:
      1) I was trying to "un-nest" a layer in a group by pulling it left. Didn't work. I had to move the lay up or down out of the group. That is not the issue. On a few occasions, and it is not always repeatable, if my cursor was dragged too far left and onto the model space, the model started panning right and could only be stopped hitting ESC. Then the model was way off in space to the left. Zoom Extents brought it back.
      Can you do a small video ? I don't really understand what's happening.
      @jgb said:
      3) This one may be impossible to fix. After I rearranged all the layers under several groups in a more natural order without a lot of number prefixes, I needed to assign a layer to a new component. But the layer list in Entity Info is in the SU order (alphabetical), making it tough to find the correct layer to assign (because I got used to the new groupings in your layer list). πŸ˜‰
      Yeah, it's impossible to correct. I'll add a way to assign geometry to a layer directly from the plugin, though.
      • jgbJ Offline
        jgb
        My oops.
        Win XP Pro
        SU 8 Free
        Firefox
        As far s a video for the wild panning, A) I don't know how to do it, and B) not sure I could capture the problem as it is not always repeatable when I try on purpose.
        jgb
          jiminy-billy-bob
          Sketchup's webdialog use Internet Explorer, even if your default browser is firefox. Which version do you have ?
          I don't have WinXP, can't test on it. Anybody else have the scrolling issue ?
          For the video, Screenr is pretty easy. In case you're able to reproduce it one day.
            jiminy-billy-bob
            Ok, I can reproduce the scrolling problem with IE6 and 7. If you do use one of these, please mind updating to IE8 (Or better : Windows 7 and IE10 !)
            • jgbJ Offline
              jgb
              I am relieved you saw this too. πŸ˜„
              I know SU uses the IE interface. My IE is Ver 8.6.
              I do very much dislike IE for several reasons, so I don't use it unless I have no choice. My Firefox is the latest (Ver 23.0.1) and I have IE Tab installed that sets up an IE session in an FF tab. Works well about 95% of the time. There are still some IE centric developers and many pages out there that use sneaky API calls that FF or other browsers cannot handle, especially around password handling and that dreadful CAPTCHA crap foisted on us. πŸ‘Ώ
              I will not upgrade Windows to 7 or 8 or whatever, even under threat of no support soon. There never really was from MS, so no loss there. Too many issues with 7 on a few other apps on my system, aside from its own deficiencies. 🀒
              jgb
                jiminy-billy-bob
                IE 8.6 ? Are you sure ? The latest release is "8.0.7601.17514".
                Can you screenshot http://whatsmyua.com/ when opened with IE ? Thanks
                • jgbJ Offline
                  jgb
                  Oops (again) 😳 😳
                  My IE is V 8.0.6001.18702
                  Do you still need the screenshot?
                  I have dual hi-res widescreen monitors, so I need to edit the screenshot down in size and a bit in res to send it up the pipe.
                  jgb
                    jiminy-billy-bob
                    No it's ok.
                    The fact you have this issue in IE8 is really weird. I can't reproduce it.
                    I'm sorry but I won't support outdated versions of this crappy browser. I know you can't have a higher version of IE on XP, but we're talking about a 12 years old OS...
                      jiminy-billy-bob
                      Hey guys, how about choosing what layers to render ? πŸ˜„
                      Got it working with at least Vray, Kerkythea, and Maxwell suite.
                      • ToboboT Offline
                        Tobobo
                        That is a very interesting concept.
                        It means you could using to hide walls etc
                        Toby
                        Philippians 4:13
                          jiminy-billy-bob
                          It means the plugin will hide/unhide chosen layers when you hit the render button, without actually hidding/showing them. So you could have heavy vegetation layers sent to the renderer, but never activated in SU's viewport.
                          • tt_suT Offline
                            tt_su
                            Oh? Now that sounds mighty interesting.
                              jiminy-billy-bob
                              Yeah, and that's pretty simple :
                              • Start operation with UI disabled
                              • Hide/unhide chosen layers (But UI is disabled, so their visibility is not actually changed)
                              • Trigger render (like "VRayForSketchUp.launch_vray_render")
                              • Revert back layers visibility
                              • Commit operation
                              πŸ˜„
                              • Bob JamesB Offline
                                Bob James
                                Totally outstanding plugin πŸ‘ πŸ‘
                                Would it be possible to add the ability to delete a layer into the current layer?
                                Example:
                                I have layer 5 chosen as the current default layer.
                                I want to put all the stuff in layer 8 into layer 5
                                I need the option to select 1. delete completely, 2. delete to layer 0, and 3. delete to current layer.
                                The first two exist (the red garbage can and the green garbage can)
                                Now I'd like a "blue" garbage can "delete to current layer" πŸ˜„
                                Once again: Outstanding Plugin
                                  Bob James
                                  While using Ctrl-z to undelete portions of the model that I have just deleted, I get this dialog.
                                    jiminy-billy-bob
                                    Noted bob about deleting to active layer.
                                    Not sure about the undo problem, though. Do you get this every time ?
                                      jiminy-billy-bob
                                      BOOM !
                                      Choose what layer to render ! πŸ‘
                                      [screenr:t24aadah]OHcH[/screenr:t24aadah]
                                      Works with Vray, Maxwell, Kerkythea and Indigo. I'm working with Tomasz to get Thea to support this feature.
                                      It still needs some finishing, but the release is not far πŸ˜‰
                                      • ToboboT Offline
                                        Tobobo
                                        BOOM !
                                        Well done!!! I cant wait to have a crack πŸ‘
                                        Toby
                                        Philippians 4:13
                                          jiminy-billy-bob
                                          New version 0.4 beta !
                                          Changelog :
                                          • Adds the ability to choose which layers to render (Works with Vray, Maxwell, Indigo, and Kerkythea)
                                          • Fix bug when having too many layers
                                          • The dialog now remembers its size and position when closed
                                          • Fix focus jumping at the top of the dialog
                                          Download in the plugin store !
                                            kirill2008
                                            I won't be original, just want to say: it is a great plugin! πŸ‘ Many thanks for it!
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 33 / 34
