    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
    • jgbJ
      jgb
      @jiminy-billy-bob said:
      Ok, I can reproduce the scrolling problem with IE6 and 7. If you do use one of these, please mind updating to IE8 (Or better : Windows 7 and IE10 !)
      I am relieved you saw this too. πŸ˜„
      I know SU uses the IE interface. My IE is Ver 8.6.
      I do very much dislike IE for several reasons, so I don't use it unless I have no choice. My Firefox is the latest (Ver 23.0.1) and I have IE Tab installed that sets up an IE session in an FF tab. Works well about 95% of the time. There are still some IE centric developers and many pages out there that use sneaky API calls that FF or other browsers cannot handle, especially around password handling and that dreadful CAPTCHA crap foisted on us. πŸ‘Ώ
      I will not upgrade Windows to 7 or 8 or whatever, even under threat of no support soon. There never really was from MS, so no loss there. Too many issues with 7 on a few other apps on my system, aside from its own deficiencies. 🀒
      jgb
      • jiminy-billy-bobJ
        jiminy-billy-bob
        IE 8.6 ? Are you sure ? The latest release is "8.0.7601.17514".
        Can you screenshot http://whatsmyua.com/ when opened with IE ? Thanks
        • jgbJ
          jgb
          Oops (again) 😳 😳
          My IE is V 8.0.6001.18702
          Do you still need the screenshot?
          I have dual hi-res widescreen monitors, so I need to edit the screenshot down in size and a bit in res to send it up the pipe.
          jgb
          • jiminy-billy-bobJ
            jiminy-billy-bob
            No it's ok.
            The fact you have this issue in IE8 is really weird. I can't reproduce it.
            I'm sorry but I won't support outdated versions of this crappy browser. I know you can't have a higher version of IE on XP, but we're talking about a 12 years old OS...
            • jiminy-billy-bobJ
              jiminy-billy-bob
              Hey guys, how about choosing what layers to render ? πŸ˜„
              Got it working with at least Vray, Kerkythea, and Maxwell suite.
              • ToboboT
                Tobobo
                That is a very interesting concept.
                It means you could using to hide walls etc
                Toby
                Philippians 4:13
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  It means the plugin will hide/unhide chosen layers when you hit the render button, without actually hidding/showing them. So you could have heavy vegetation layers sent to the renderer, but never activated in SU's viewport.
                  • tt_suT
                    tt_su
                    Oh? Now that sounds mighty interesting.
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      Yeah, and that's pretty simple :
                      • Start operation with UI disabled
                      • Hide/unhide chosen layers (But UI is disabled, so their visibility is not actually changed)
                      • Trigger render (like "VRayForSketchUp.launch_vray_render")
                      • Revert back layers visibility
                      • Commit operation
                      πŸ˜„
                      • Bob JamesB
                        Bob James
                        Totally outstanding plugin πŸ‘ πŸ‘
                        Would it be possible to add the ability to delete a layer into the current layer?
                        Example:
                        I have layer 5 chosen as the current default layer.
                        I want to put all the stuff in layer 8 into layer 5
                        I need the option to select 1. delete completely, 2. delete to layer 0, and 3. delete to current layer.
                        The first two exist (the red garbage can and the green garbage can)
                        Now I'd like a "blue" garbage can "delete to current layer" πŸ˜„
                        Once again: Outstanding Plugin
                        • Bob JamesB
                          Bob James
                          While using Ctrl-z to undelete portions of the model that I have just deleted, I get this dialog.
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            Noted bob about deleting to active layer.
                            Not sure about the undo problem, though. Do you get this every time ?
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              BOOM !
                              Choose what layer to render ! πŸ‘
                              [screenr:t24aadah]OHcH[/screenr:t24aadah]
                              Works with Vray, Maxwell, Kerkythea and Indigo. I'm working with Tomasz to get Thea to support this feature.
                              It still needs some finishing, but the release is not far πŸ˜‰
                              • ToboboT
                                Tobobo
                                BOOM !
                                Well done!!! I cant wait to have a crack πŸ‘
                                Toby
                                Philippians 4:13
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  New version 0.4 beta !
                                  Changelog :
                                  • Adds the ability to choose which layers to render (Works with Vray, Maxwell, Indigo, and Kerkythea)
                                  • Fix bug when having too many layers
                                  • The dialog now remembers its size and position when closed
                                  • Fix focus jumping at the top of the dialog
                                  Download in the plugin store !
                                  • K
                                    kirill2008
                                    I won't be original, just want to say: it is a great plugin! πŸ‘ Many thanks for it!
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      @kirill2008 said:
                                      I won't be original
                                      You don't have to, it's always nice to hear that πŸ˜‰
                                      • U
                                        Ulimann
                                        Hallo Jiminy
                                        Great plugin , installed the update and get the resulting screen on activation.
                                        I am running Windows 7 64 SU 8 PRO.
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          Can you delete everything concerning Layers Panel in your plugin folder, and reinstall it ?
                                          Plugins/jbb_layers_panel.rb
                                          • U
                                            Ulimann
                                            Thanks for the quick reply,did as you suggested its up and running.
                                            • 33
                                            • 34
                                            • 7 / 34
