    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 288.1k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Sketchup's webdialog use Internet Explorer, even if your default browser is firefox. Which version do you have ?
      I don't have WinXP, can't test on it. Anybody else have the scrolling issue ?
      For the video, Screenr is pretty easy. In case you're able to reproduce it one day.
        jiminy-billy-bob
        Ok, I can reproduce the scrolling problem with IE6 and 7. If you do use one of these, please mind updating to IE8 (Or better : Windows 7 and IE10 !)
        • jgbJ Offline
          jgb
          I am relieved you saw this too. πŸ˜„
          I know SU uses the IE interface. My IE is Ver 8.6.
          I do very much dislike IE for several reasons, so I don't use it unless I have no choice. My Firefox is the latest (Ver 23.0.1) and I have IE Tab installed that sets up an IE session in an FF tab. Works well about 95% of the time. There are still some IE centric developers and many pages out there that use sneaky API calls that FF or other browsers cannot handle, especially around password handling and that dreadful CAPTCHA crap foisted on us. πŸ‘Ώ
          I will not upgrade Windows to 7 or 8 or whatever, even under threat of no support soon. There never really was from MS, so no loss there. Too many issues with 7 on a few other apps on my system, aside from its own deficiencies. 🀒
          jgb
            jiminy-billy-bob
            IE 8.6 ? Are you sure ? The latest release is "8.0.7601.17514".
            Can you screenshot http://whatsmyua.com/ when opened with IE ? Thanks
            • jgbJ Offline
              jgb
              Oops (again) 😳 😳
              My IE is V 8.0.6001.18702
              Do you still need the screenshot?
              I have dual hi-res widescreen monitors, so I need to edit the screenshot down in size and a bit in res to send it up the pipe.
              jgb
                jiminy-billy-bob
                No it's ok.
                The fact you have this issue in IE8 is really weird. I can't reproduce it.
                I'm sorry but I won't support outdated versions of this crappy browser. I know you can't have a higher version of IE on XP, but we're talking about a 12 years old OS...
                  jiminy-billy-bob
                  Hey guys, how about choosing what layers to render ? πŸ˜„
                  Got it working with at least Vray, Kerkythea, and Maxwell suite.
                  • ToboboT Offline
                    Tobobo
                    That is a very interesting concept.
                    It means you could using to hide walls etc
                    Toby
                    Philippians 4:13
                      jiminy-billy-bob
                      It means the plugin will hide/unhide chosen layers when you hit the render button, without actually hidding/showing them. So you could have heavy vegetation layers sent to the renderer, but never activated in SU's viewport.
                      • tt_suT Offline
                        tt_su
                        Oh? Now that sounds mighty interesting.
                          jiminy-billy-bob
                          Yeah, and that's pretty simple :
                          • Start operation with UI disabled
                          • Hide/unhide chosen layers (But UI is disabled, so their visibility is not actually changed)
                          • Trigger render (like "VRayForSketchUp.launch_vray_render")
                          • Revert back layers visibility
                          • Commit operation
                          πŸ˜„
                          • Bob JamesB Offline
                            Bob James
                            Totally outstanding plugin πŸ‘ πŸ‘
                            Would it be possible to add the ability to delete a layer into the current layer?
                            Example:
                            I have layer 5 chosen as the current default layer.
                            I want to put all the stuff in layer 8 into layer 5
                            I need the option to select 1. delete completely, 2. delete to layer 0, and 3. delete to current layer.
                            The first two exist (the red garbage can and the green garbage can)
                            Now I'd like a "blue" garbage can "delete to current layer" πŸ˜„
                            Once again: Outstanding Plugin
                              Bob James
                              While using Ctrl-z to undelete portions of the model that I have just deleted, I get this dialog.
                                jiminy-billy-bob
                                Noted bob about deleting to active layer.
                                Not sure about the undo problem, though. Do you get this every time ?
                                  jiminy-billy-bob
                                  BOOM !
                                  Choose what layer to render ! πŸ‘
                                  [screenr:t24aadah]OHcH[/screenr:t24aadah]
                                  Works with Vray, Maxwell, Kerkythea and Indigo. I'm working with Tomasz to get Thea to support this feature.
                                  It still needs some finishing, but the release is not far πŸ˜‰
                                  • ToboboT Offline
                                    Tobobo
                                    BOOM !
                                    Well done!!! I cant wait to have a crack πŸ‘
                                    Toby
                                    Philippians 4:13
                                      jiminy-billy-bob
                                      New version 0.4 beta !
                                      Changelog :
                                      • Adds the ability to choose which layers to render (Works with Vray, Maxwell, Indigo, and Kerkythea)
                                      • Fix bug when having too many layers
                                      • The dialog now remembers its size and position when closed
                                      • Fix focus jumping at the top of the dialog
                                      Download in the plugin store !
                                        kirill2008
                                        I won't be original, just want to say: it is a great plugin! πŸ‘ Many thanks for it!
                                          jiminy-billy-bob
                                          @kirill2008 said:
                                          I won't be original
                                          You don't have to, it's always nice to hear that πŸ˜‰
                                          • U Offline
                                            Ulimann
                                            Hallo Jiminy
                                            Great plugin , installed the update and get the resulting screen on activation.
                                            I am running Windows 7 64 SU 8 PRO.
                                            • 33
                                            • 34
                                            • 7 / 34
