[Plugin] TextureTools
@tig said:
Buki
If you get the menu items working, then it is loading OK.
So first a simple question...
Have you activated the Toolbar from Views > Toolbars ?
By default it's inactive after the initial installation...
Even if you had misplaced the toolbar-buttons' png files the activated toolbar would still exist, but with blank buttons ??Yep, like I guessed, user error. I didn't see that it was off by default in the tools menu. I was a bit hasty in asking, thank you for getting back to me so quickly
awesome thanks
thanks man,,very helpful,,
good evening
I try to use your pluggin to change the size of a tiling texture, but each time the texture turns along the dimension changesthank you in advance
@marco62118 said:
good evening
You need to use the scale and then the position tool together...
You haven't explained very clearly what it is you want to do and what it's doing -
good evening
Ā I do not understand the plugin does not respond
dialog boxes are displayed correctly, but nothing happensCan you help me?
the plugin only works on front faces (not sure why) - so, check that your texture is painted facing front and then try again. perhaps TIG can make it work on back face as well in the future.
These tools only works on front-faces... because that's where textured-material ought to be applied.
Applying a material onto a back-face is just bad practice.
Back-faces should never be visible.
Modeling with reversed faces can lead to many problems when pushpulling, applying cutting components etc, and when the SKP is exported, used in many rendering applications etc, etc...The native context-menu Texture tool will adjust front/back-face textures, depending on which side of the face you are seeing... use that if you insist on sloppy modeling.
BUT I deliberately discourage the application of materials on back-faces.
So these tools will only ever adjust textured-materials applied onto front-faces.Use Monochrome mode, with a contrasting back-face default-material in the Style, to check that you are not modeling 'inside out'
The context-menu items Reverse and Orient are useful to fix reversed faces as you model - shortcut keys is highly recommended. Also use Monochrome as you model to check the correctness of the faces' orientation. Only start applying materials and texturing once the geometry is pretty much resolved... -
yes, i understand, though i guess that's only if you are using a rendering package, if you use SU for render, than back faces are just as good - and of course when you paint both you don't get those pesky flickering edges.
Eneroth Texture Positioning Tools
http://extensions.sketchup.com/en/content/eneroth-texture-positioning-toolsIs this same plugin?
No, mine is the original one... -
How do I install?
@mafalda_melo_oliveira said:
How do I install?
Find the tool in the SCF PluginStore [Resources menu first item], get the RBZ and install it with Preferences > Extensions > Install... button in v2013 or v8...
OR get the SketchUcation Plugin Store toolset [second item in that menu or in the first item - under most popular...] - that lets you AutoInstall Plugins from within SketchUp itself...You need to ensure you have FULL security permissions to your Plugins folder - there are several post covering that...
New version available at the PluginStore http://sketchucation.com/forums/viewtopic.php?p=329765#p329765
thanx man
great plugin - would be fantastic if it worked on back faces too
@cadfather said:
great plugin - would be fantastic if it worked on back-faces too
But why is any textured material applied to back-faces ?
They should never be seen !However, I have PM'd you a version to test called TextureTools_BACK ! which works like TextureTools but only on back-faces... It's a separate toolset and toolbar [it has similar icons but with a blue-gray background]
Please test and see it it's what you expected...
Thank you TIG, that works great!
basically since often i don't photo-render my drawings, the front-back issue doesn't arise.
should i change my mind later i could always swap and even reverse faces with the su4you materials plugin: http://sketchucation.com/pluginstore?pln=S4U_Material
If anyone else wants to try the 'TextureTools_BACK', please ask and I'm PM it to you...
btw TIG, i tried unifying the 2 plugins, but i might as well work out the quantum/relativity problem first.......
if you do join both scripts into one, PM me first please!
