    [Plugin] Lattice Maker
    149 Posts 69 Posters 370.8k Views 68 Watching
    • charly2008C Offline
      charly2008
      Hi TIG
      Some may not know that there are two "Lattice Plugins" from you. I find both very helpful. Would it be possible for you to bring both together in order to get these different results.
      Charly
      • broomstickB Offline
        broomstick
        Hi TIG, finally got around to make an Italian translation for this plugin. Tested it, seems to work fine.
        Words with an accent in Italian (at the end of a word, sometimes we use è and à) have been replaced without that letter, because I don't know if they would be read.
        Anyway, here's the lingvo:
        latticeMakerIT.lingvo.zip
        Hope it's of use to other Italian speaking users 😄
          tulacong
          good man
            tobias3d
            install .rbz? in sketchup
              Is that a question about how to install RBZ files in SketchUp?
              If so: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                tobias3d
                thanks¡¡¡¡ thomthom
                  askmo
                  help me please.
                  I dwnl Lattice Maker v1.3 20130528 has ".lingvo" file extension, but in the plugin folder it don't work because is not file .rb.
                  I wonder, how I can do to work it?
                    @Morris
                    Since you have not supplied your OS or SUp version I must guess...
                    How did you download this exactly ?
                    Did you get it as a .RBZ file ?
                    Did you then install it using the v8 [latest version] Preferences > Extensions > Install... button
                    OR did you auto-install it using the SketchUcation Plugin Store dialog from within SketchUp?
                    OR did you rename it .ZIP and extract its file/subfolder of files and put these into the Plugins folder, respecting the same relative relationships of files?
                    This has been covered endlessly on the forums...
                    Thomthom linked to a relevant post a few items back...
                    If you do not keep the same relative locations tools just won't work! So for example if you put the tool's lingvo files directly into the Plugins folder you are screwed!
                    Look in the .ZIP/.RBZ and you will see the tool's main 'loader' .rb and a subfolder of the same name containing a few other files - in the case of this tool there are some .lingvo files used for translations; in this tool's archive there is also a 'deBabelizer.rb' file used for the translations...
                    The 'automated installation' methods are by far the safest for users such as yourself who are somewhat challenged in this regard... I commend them to you.
                    If you have mis-installed files you MUST remove everything and start again - in the case of this tools having some duplicated lingvo files in the wrong location won't do any harm BUT for other tools that ship with rb files inside their subfolder moving those out into Plugins will break SketchUp BIG TIME!!
                    So please don't do it, and if you do tidy up !
                      archdeacon
                      Tig many thanks for this great tool. I have a request and question. I am trying to make gridshells (and am trying to avoid using rhino in order to do so hehem) and i am trying to make diagonals drawn accross a surface generated from your extrude tools, then mirrored and reapplied to produce a net of diagonals to then produce a lattice. i have attached what i mean.this is the sort of net i need to latticize
                      any ideas how i would do such a think. Ideally the diagonal rails would not be coplanar. they need to be placed on top of eachother. How do i take them though, apply a thickness to them, then extrude them to make the curved consequtive elements i require...
                      I would be very, very grateful for any help.
                      • BoxB Offline
                        Have you tried Tigs, Extrude Edges by Rails to Lattice which you will find in his Extrusion tools.
                          As Box says...
                          My Extrusion Tools EEbyRailsToLattice offers several options:
                          There are 3d 'box-extrusions'
                          Just rail lines
                          Just profile lines
                          Just diagonal lines [this is probably what you want... run it twice, picking rails alternately so the two groups of diagonals run oppositely then explode/merge the groups and rails/profiles into one container]
                            archdeacon
                            TIG many thanks for this reply. I did exactly as you mentioned previously in order to make the mesh i showed above. I want to make a lattice out of it though. Can the code for your latticizer be modified in order to be able to form lattices in three dimensions in the way that the latticizer works (axially on the line without splitting the lattice along that axis)? thank you for your help in advance.
                              Here's a future-proofed update.
                              http://sketchucation.com/forums/viewtopic.php?p=244981#p244981
                              • ppoublanP Offline
                                ppoublan
                                Dear all,
                                I'm in the process re-installing my plugins for SU 2014.
                                Just downloaded from plugins store lattice maker.
                                got an error
                                Erreur de chargement du fichier latticeMaker.rb
                                Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                I think this is linked to language files not encoded in UTF-8.
                                Is there newer version somewhere ? or plans to update.
                                Yours
                                Pascal
                                  Thanks for the report...
                                  It should already be compatible with v2014... 😕
                                  If not I'll be able to fix it very easily !
                                  • ppoublanP Offline
                                    ppoublan
                                    I had a similar problem with my plugin.
                                    Seems it only appears when extended caracters are read from non UTF-8 language string files.
                                    Just re-encoded text files to solve this.
                                    Problem did not occur with US-en version.
                                    Yours
                                    Pascal
                                      LatticeMaker IS already compatible with v2014.
                                      I just reinstalled it to convince myself ! 😒
                                      Please get NEW versions of ALL of your Plugins installed into v2014.
                                      Do NOT copy older versions over - often they may be incompatible...
                                      I do not understand your report regarding the UTF8 error 😕
                                      Did you perhaps copy files, instead of the necessary reinstall from the newest RBZ source ??
                                      • ppoublanP Offline
                                        ppoublan
                                        Just reinstalled on a virgin setup of SU2014 the version downloaded from Pluginstore (installed with plugin store).
                                        Here is the error I got
                                        I'm using french version of SU on Windows.
                                        I was able to correct it myself :
                                        • opened latticemakerfr.lingvo in notepad++
                                        • converted to UTF-8
                                        • saved the file
                                          and then it works.
                                          But I think it should be done at the source within your package.
                                          Do not know the details, but UTF-8 encoding for non ascii files is a change in Ruby 2.0 vs Ruby 1.0
                                          Yours
                                          Pascal
                                          Thanks - at last we discover that there's a rogue lingvo file...
                                          I thought I had made all of them compatible !
                                          The EN-US one is OK, but the FR one isn't !
                                          I'll issue an update asap - sorry about that 😒
                                            Here's version v1.5
                                            http://sketchucation.com/pluginstore?pln=latticeMaker
                                            Its FR lingvo file is now encoded so it's compatible with v2014 😒
                                            • 5 / 8
