    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • I Offline
      ibrahim zambak
      tools on surface v1.8a plugin, sketchup 8 does not work. windows 8 operating system
        Ibrahim,
        More info is needed here. I have SU 8 on Windows 8 and the tool works fine on my computer so a "general doesn't work" is not enough.
          sasrabirawa
          works fine on SKP 8 but doesn't work on SKP 2013. The libfred doesn't compatible w/ SKP 2013. even if I use the latest one... can anybody tell me how to fix ??
          Just an ordinary Sketchup user
            The latest LibFredo... and several related tools were remade to be compatible with all previous versions and v2013.
            We must assume you are using the latest versions available from the SCF PluginStore...
            So you must be doing something wrong ?
            Are you properly installing things ?
            Since you haven't told us your OS I must guess at PC.
            If it's a new v2013 installation into the usual 'Program Files' folder, then Windows will have given the new SketchUp folder [and all of its subfolders] Read-only permissions. Then you can't Write new files into the Plugins folder; but to confuse you Windows might make it look like you have, but it has a actually put the files into a VirtualStore to protect you from yourself, so they don't auto-load as SketchUp starts! A link/button in the top-bars of the Plugins folder's Windows Explorer window is an indication of such limitations...
            If you use an RBZ archive and then 'install' button under Preferences > Extensions, or use the SCF Plugin Store dialog's AutoInstall feature from within SketchUp then it might still install properly, despite your own limited permissions; but that depends on several other things though...
            It is always best to have your Plugins folder set to have FULL read/write permissions for every entry in the 'users' uder the Security list: to do this...
            right-click > context-menu > Properties > Security > Edit ... tick FULL for each and Apply & OK...
            [you will need admin rights to do this].
            Note that even if you are setup in the Users Control Panel to have full 'admin' rights, that will not change the initial permissions the OS sets to the SketchUp folder and its contents, even admins are limited.
            Note that it is also advisable to always install apps as as admin... AND for SketchUp.exe I'd also set its Properties > Compatibility, with the 'Run this program as an administrator' box ticked...
            • E Offline
              elisaha
              Hi everyone,
              I'm a SU-newbie with SU 8 on a Mac with OS X 10.7.5, however I have troubles installing ToolsOnSurface 1.8a. I do have the ZLoarder, LibFredo and the Tutorial Offset on Surface in the correct plugin folder. It even shows up in my extensions, but there is no line-up. What can I do?
              I do have a general problem with installing plug-ins.. I don't know what I would be doing wrong, please help!
              Thanks alot,
              Elisa
              • mitcorbM Offline
                mitcorb
                Hi:
                On the very first page of this thread under Installation, for Mac is this:
                [On Mac the SU plugin directory should be:
                Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins]
                In your case, it will be Sketchup 8 but the rest of the path should be correct.
                Alternatively, go to the top of this page, mouse over Resources, and select Plugin Store Download. This automates the process. Watch the video, read the information.
                  giltora
                  tools on surface not responding.. help please!!!!
                    More info is needed.
                    HOW isn't it 'responding' ?
                    Do you get the extension/toolbar ?
                    Are there error messages?
                    [Try it with the Ruby Console window open...]
                    Did you get the latest versions of this tool AND the required LibFredo...
                    Both are available in the SCF PluginStore...
                      popfunky
                      Thank but i can't install 😢
                        Please explain your problem better, so we can help you properly.
                        How are you trying to install this ?
                        Do you have the required support 'Lib' installed as explained in the download details ?
                          archdeacon
                          Fredo thank you for these great tools. i am having a hard time installing this one though. I am on sketchup 8 pro - Windows 7. any ideas...? i have observed the footprint and everything. I do not appear to have the LibFredo6.rb that you are mentioning (i have the newer library). Is this because you have updated the lbrary to the new version? can you instruct me on how to cure this problem.
                          thanks for your help.
                          • fredo6F Offline
                            Since you have Sketchup 8, you should
                            • first, install the Sketchucation Plugin Store tool
                            • Then Auto-install my scripts with this tool. You'll have zero problem and it's much easier and faster than with the ZIP file. You will also get the latest versions available
                            You may need to do a clean up of your SU Plugins directory before if you had a wrong installation
                              archdeacon
                              oops...
                              i just restarted sketchup (i had done it before as well and it did not work)
                              BUT IT WORKS FINE NOW!
                              thank you very much! 😍
                                Karen, can you post a screen shot that shows the problem?
                                  kdrr1607
                                  Hi! I have a question. The construction lines are not showing every time I click on the surface after picking the initial point, so I cant pick an end point. Uhm, how can I solve this? Thanks.
                                    kdrr1607
                                    Here is the screen shot. I pressed print screen then pasted it on paint, but the mouse was did not appear on paint, so i took another photo that shows it on close-up. The construction line isnt showing as i move my pointer away from the initial point. I tried specifying a diameter/distance, but nothing happened.
                                    Here is another photo showing the toolsonsurface as a mouse pointer.
                                      Do you get guidelines if you use the yellow Tape measure tool? I'm wondering if this is an OpenGL setting issue.
                                        kdrr1607
                                        Yes, everything works fine but my tools on surface plugin.
                                          Is it possible the construction lines are inside your cylinder? What do you see if you switch to X-ray face style?
                                            kdrr1607
                                            Yes, Ive done that, still no lines showing.
                                            • 31
                                            • 32
                                            • 6 / 32
