    Terrain modeling problem?
    25 Posts 7 Posters 1.7k Views 7 Watching
    • H Offline
      habbaz
      how can i remove this lines please
        kaas
        You could try to hide them or smooth those lines by choosing the eraser and holding shift (hide) or ctrl (soften / smooth) while 'erasing' those lines.
        • H Offline
          habbaz
          but terrain is much much big
          and the other problem is the empty faces
          • KrisidiousK Offline
            Krisidious
            I think there is a free version... If not, it's worth every penny.
            (www.valiarchitects.com)
            By: Kristoff Rand
            • H Offline
              habbaz
              i have this plugin and its note work
                Krisidious
                Not work? why not? It's pretty simple.
                make a path you want to be a road.
                make that path a group.
                make sure the land geometry is below the path.
                select the land and the path group and click make road.
                By: Kristoff Rand
                • H Offline
                  habbaz
                  thanks
                  but, not work
                    Krisidious
                    what does it do?
                    By: Kristoff Rand
                    • BoxB Offline
                      The missing faces look very small, what size are you working at. Perhaps simply scaling up your model will allow the faces to form properly.
                        Krisidious
                        By: Kristoff Rand
                        • H Offline
                          habbaz
                          this link is help me to hide the edges but the empty faces is still
                          http://www.cad-addict.com/2008/11/sketchup-hide-all-edges.html
                          • H Offline
                            habbaz
                            Metre
                            • BoxB Offline
                              Metre what?
                              Is the whole model 1 meter or are the small missing faces 1 meter?
                              SU has trouble forming tiny or huge faces. If those missing faces are down around 1mm then they won't form properly.
                              • H Offline
                                habbaz
                                @box said:
                                Metre what?
                                the unit for model by meter
                                model surface is: 3 000 000 m²
                                small missing faces between 1m to 10m or more
                                • cottyC Offline
                                  cotty
                                  Did you try to use a plugin to create those faces? (e.g. add faces)
                                  my SketchUp gallery
                                  • H Offline
                                    habbaz
                                    yes and all not working
                                    addfaces
                                    makeface
                                    clean up²... and more and more...
                                    • H Offline
                                      habbaz
                                      This is the 3d model sketchup file:
                                      http://www66.zippyshare.com/v/16315036/file.html
                                      • H Offline
                                        habbaz
                                        help me please
                                        • pbacotP Offline
                                          I've followed this thread some. Not sure how the drape(was that it?) operation ruined your terrain. It looks like you have to repair that area (or go back to the original terrain file). Good idea to save a base terrain model without mods. I don't have v.13 but if I have time I will look at the file. I have v. 8.
                                          Probably better to erase the troubled area and create a new regular skin inside without all the chopped up faces.
                                          Edit: I looked at the file and the best thing is to start over with your original terrain. If you want to intersect a road on it, use a very simple outline of the road to establish the outlines. Try your road method on smaller pieces of terrain before committing to the large model. Try other methods of road creation such as "instant Road" or making a texture with a road painted on it. Or create a road using a copy of the terrain and let it float a little above an unaltered version (depends on what you are using the file for). Use as simple (low poly) terrain as possible for your needs. I would consider this terrain irreparable, myself.
                                          Keep Layer0 the active layer always. Only assign groups or components to other layers, keeping all raw geometry on Layer0.
                                          • H Offline
                                            habbaz
                                            finaly terrain repaired but i still can't create road by instant road
                                            what the best setting to create road (width 8m) with simple sidewalk 20x20cm
                                            http://www.hdwallpapersinn.com/wp-content/uploads/2013/04/curved-road-on-white.jpg
