    Terrain modeling problem?
    25 Posts 7 Posters 1.9k Views 7 Watching
    • H Offline
      habbaz
      i want to make road but the problem
      terrain give me much lines and empty rectangular faces i want to repair and clean them
      sorry for my bad english
      thanks
      • H Offline
        habbaz
        ANY HELP PLEASE
        • soloS Offline
          Can you share model?
          • H Offline
            habbaz
            Error 404 (Not Found)!!1
            (sketchup.google.com)
            • H Offline
              habbaz
              how can i remove this lines please
                kaas
                You could try to hide them or smooth those lines by choosing the eraser and holding shift (hide) or ctrl (soften / smooth) while 'erasing' those lines.
                • H Offline
                  habbaz
                  but terrain is much much big
                  and the other problem is the empty faces
                  • KrisidiousK Offline
                    Krisidious
                    I think there is a free version... If not, it's worth every penny.
                    404 Not Found
                    (www.valiarchitects.com)
                    By: Kristoff Rand
                    • H Offline
                      habbaz
                      i have this plugin and its note work
                        Krisidious
                        Not work? why not? It's pretty simple.
                        make a path you want to be a road.
                        make that path a group.
                        make sure the land geometry is below the path.
                        select the land and the path group and click make road.
                        By: Kristoff Rand
                        • H Offline
                          habbaz
                          thanks
                          but, not work
                            Krisidious
                            what does it do?
                            By: Kristoff Rand
                            • BoxB Offline
                              The missing faces look very small, what size are you working at. Perhaps simply scaling up your model will allow the faces to form properly.
                                Krisidious
                                By: Kristoff Rand
                                • H Offline
                                  habbaz
                                  this link is help me to hide the edges but the empty faces is still
                                  http://www.cad-addict.com/2008/11/sketchup-hide-all-edges.html
                                  • H Offline
                                    habbaz
                                    Metre
                                    • BoxB Offline
                                      Metre what?
                                      Is the whole model 1 meter or are the small missing faces 1 meter?
                                      SU has trouble forming tiny or huge faces. If those missing faces are down around 1mm then they won't form properly.
                                      • H Offline
                                        habbaz
                                        @box said:
                                        Metre what?
                                        the unit for model by meter
                                        model surface is: 3 000 000 m²
                                        small missing faces between 1m to 10m or more
                                        • cottyC Offline
                                          cotty
                                          Did you try to use a plugin to create those faces? (e.g. add faces)
                                          my SketchUp gallery
                                          • H Offline
                                            habbaz
                                            yes and all not working
                                            addfaces
                                            makeface
                                            clean up²... and more and more...
