    Terrain modeling problem?
    25 Posts 7 Posters 2.2k Views 7 Watching
    • H
      habbaz
      ANY HELP PLEASE
      • soloS
        Can you share model?
        • H
          habbaz
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          • H
            habbaz
            how can i remove this lines please
            • K
              kaas
              You could try to hide them or smooth those lines by choosing the eraser and holding shift (hide) or ctrl (soften / smooth) while 'erasing' those lines.
              • H
                habbaz
                but terrain is much much big
                and the other problem is the empty faces
                • KrisidiousK
                  Krisidious
                  I think there is a free version... If not, it's worth every penny.
                  404 Not Found
                  (www.valiarchitects.com)
                  By: Kristoff Rand
                  • H
                    habbaz
                    i have this plugin and its note work
                    • KrisidiousK
                      Krisidious
                      Not work? why not? It's pretty simple.
                      make a path you want to be a road.
                      make that path a group.
                      make sure the land geometry is below the path.
                      select the land and the path group and click make road.
                      By: Kristoff Rand
                      • H
                        habbaz
                        thanks
                        but, not work
                        • KrisidiousK
                          Krisidious
                          what does it do?
                          By: Kristoff Rand
                          • BoxB
                            The missing faces look very small, what size are you working at. Perhaps simply scaling up your model will allow the faces to form properly.
                            • KrisidiousK
                              Krisidious
                              By: Kristoff Rand
                              • H
                                habbaz
                                this link is help me to hide the edges but the empty faces is still
                                http://www.cad-addict.com/2008/11/sketchup-hide-all-edges.html
                                • H
                                  habbaz
                                  Metre
                                  • BoxB
                                    Metre what?
                                    Is the whole model 1 meter or are the small missing faces 1 meter?
                                    SU has trouble forming tiny or huge faces. If those missing faces are down around 1mm then they won't form properly.
                                    • H
                                      habbaz
                                      @box said:
                                      Metre what?
                                      the unit for model by meter
                                      model surface is: 3 000 000 m²
                                      small missing faces between 1m to 10m or more
                                      • cottyC
                                        cotty
                                        Did you try to use a plugin to create those faces? (e.g. add faces)
                                        my SketchUp gallery
                                        • H
                                          habbaz
                                          yes and all not working
                                          addfaces
                                          makeface
                                          clean up²... and more and more...
                                          • H
                                            habbaz
                                            This is the 3d model sketchup file:
                                            http://www66.zippyshare.com/v/16315036/file.html
