    1.3k Posts 299 Posters 3.0m Views 297 Watching
      tomboston27
      HI! Could anyone please help me work out how to download this onto sketchup? ive been unable to find 'CURVILOFT_Dir_12' and I am not sure if this is why I haven't been able to get the plugin to work... if anyone knows what I am doing wrong your comments would be really appreciated!!! thanks πŸ˜„
        @Tom
        To install Plugins, including those that are the contents of RBZ archives...
        Check you have FULL permissions to your Plugins folder...
        As an Admin...
        Select its icon and right-click
        Context-menu
        Properties
        Security
        Edit
        FULL for every user / group listed
        Apply/OK
        Also set the SketchUp.exe icon...
        Properties
        Compatibility
        'Always Run as Administrator...'
        Now use The installer button under Preferences > Extensions... OR use the SketchUcation Plugin Store tool to AutoInstall the files for you...
          albertjees
          Hi i couldnt use the plugin,can someone please help me.
          Cheers
          AJ
          [img]file:///C:/Users/Tansformational/Desktop/Curviloft%20Error.jpg[/img]
            Cheers
            AJ
            @AJ
            Please upload the file to SCF, adding a link to your πŸ˜„ drive won't work for anyone but you! πŸ˜’
            Can you also explain what this problem is...
            It's installation?
            It's execution?
            It's results?
            etc
            Perhaps the missing image would help us help you, but a few words of explanation could also assist...
            Many hundreds of users have no problems with this tool, so once we know what your intention/issue is it will be resolvable πŸ˜„
              albertjees
              Hi I have downloaded the plugin but it couldn't be use, can someone please help me?
                @Albert
                Have you actually 'installed' it correctly?
                Did you also install the supporting Lib as explained on the tool's download page [first in this thread]?
                When you unzip the ZIP version got from this thread did you ensure the installation was as explained - keeping all files that are archived in subfolders inside those etc?
                Do you have FULL read/write Properties/Security/Edit permissions to the Plugins folder ?
                Because you have SUp v8 there should be a Preferences > Extensions > Install archive... button that auto-installs tools from their RBZ format archives - you can download that RBZ version of most tools from the SCF PluginStore, which accessed from the Resources menu above... You could also install the 'SketchUcation Plugin Store' toolset [linked in that menu too] - that lets you AutoInstall plugins from a toolbar from within SketchUp itself - as well as easy use of custom plugins folders and many other useful extension/plugin management tools [the impending update even has a new ZIP/RBZ installer option].
                If it loads what problems are you having with it ?
                • N Offline
                  nfr_ib
                  Fredo6,
                  Hello. Thank you for all your work. I wonder, though, if "Curviloft" is available for SketchUp 2013 (I tried, and failed). In fact, none of your plugins seem to be available for 2013. I am wondering if that will change anytime soon? 2013 seems to me to be a significant upgrade over v.8, or at least it appears that way to me, anyways.
                  But I know which movie screens to go see certain movies on -- IMAX, of course, but if not there then screen #3 or #4 at the other movie theatre in town if it is a 3D movie, or screen #1 or #17 if it's not. Went to visit my mother one time and saw a movie, but just at the "local" theatre. There was a great stadium seating, IMAX one about 40 min. up the highway, but she couldn't imagine why I would want to go to that one. It drove me nuts.
                  That's kind of how I feel about the difference between Sketchup Pro 8 and SketchUp 2013.
                  So I hope that your "Curviloft" tool will be available on 2013 soon.
                  • fredo6F Offline
                    @nfr_ib,
                    My scripts run on SU13.
                    Just upgrade to the latest versions, in particular LibFredo6 5.2.
                    • N Offline
                      nfr_ib
                      Thanks! Just got around to it today. Appreciate all the work you put in with SketchUp!
                        du_pmm
                        Hi, I work with "curviloft" and "round corner" plugins every day in my office, using sketchup 8. Yesterday, in my office, I tried to install these both plugins and it worked normally after Sketchup 2013 was installed. But today, I tried to install these plugins with Sketchup 2013 in my personal computer and it simply doesn't work! It appears a messsage on the screen saying "Module Curviloft requires Sketchup version greather than 6, Current version is 13.0.3689" So, why does it work normally yesterday in my computer's office, and it doesn't work in my personal computer? What should I do?
                        • fredo6F Offline
                          Just upgrade to the latest versions of the scripts (in particular LibFredo6 5.2).
                          Indeed, it is strongly recommended you install first the Plugin Store tool and then autoinstall my plugins with the tool.
                            antonio555
                            The Greatest Extension! Thank You! πŸ‘
                              du_pmm
                              Tahnk you! πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                antonio555
                                Hi. I use Curviloft 1.2 d. It works good, but I see the error every time, when I start work in my ScetchUp 8.
                                Error Loading File bootstrap_Curviloft.rb
                                uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
                                uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                                uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                                uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                                How can I improve this?
                                Thank You.
                                • fredo6F Offline
                                  You seem to have a wrong instalation of LibFredo6.
                                  Please check the posts and respect the footprint, or better, install the SCF Plugin Store and then autoinstall the scripts with it.
                                    Missy_X
                                    Not sure if this is expected behavior but i fired up Sketchup earlier, it told me there were updates for a couple plugins (libfredo, curviloft, round corners, ...) , i used Sketchucation Plugin Store inside Sketchup to update the plugins and now Curviloft shows a progress bar in the middle of my screen whenever i use it, and it stays there until i submit, which is very annoying. Is it supposed to be like that now ?
                                    http://imagesup.net/?di=4137976133713
                                    • fredo6F Offline
                                      There may be a bug.
                                      Could you open the Ruby Console before launching and check if there are messages.
                                        Missy_X
                                        @fredo6 said:
                                        There may be a bug.
                                        Very strange, works like a charm now πŸ˜• Maybe that's what i get for not giving Sketchup some love for 2 weeks πŸ˜† Thank you anyway and i'll check the ruby console if it ever does it again πŸ˜„
                                          tk22
                                          great plugin fredo...thanks..
                                          but i have a problem. why it works in SU8 but it always crash in SU7 ?
                                          • I Offline
                                            iheartpi
                                            Awesome plugin! You know what I am thinking. I'll draw lines on my friends face, take a snapshot, using the snapshot as reference draw the lines in sketchup, then curviloft it πŸ˜„
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 65
                                            • 66
                                            • 46 / 66
