    Looking for tool to cut non-solids along a plane
    34 Posts 10 Posters 2.6k Views 10 Watching
      Surrely that make the same result!
      But not sure you will maybe obtain some lines trimed on the tiles!
      In the original file seems tiles are yet trimed! 😲
      erase all walls for see that!
      So use tiles without lines trimed!
      • cottyC Offline
        cotty
        Reading the other answers I'm not longer shure that I understand the question right, but I created a little screencast, so here it is ...
        http://screenr.com/x84H
        my SketchUp gallery
        • kuponoK Offline
          kupono
          Cutting the tiles at the cut-planes isn't the problem. Any of the Intersect Faces options will work. It's the niggling work erasing the hairy remnants that takes time. Cotty's screen-cast illustrates the problem. Even after aligning with axis, selecting and erasing took him some time. Zorro2's Slice Model at Section options is very nice, erasing everything behind a section, but it can't handle inside areas. Checkout my first screen-cast.
          302 Found
          (www.screenr.com)
          Thanks for all the help.
          Roof to tile
            Ah! Ok! I had not understood that you want cut your roof's tiles! 😳
            I had trimmed only the wals ! πŸ˜„
            So first : as your tiles are some similar you have way better to make a component!
            You will obtain a very more light file!
            And if by hasard you want to change the model of the tile that will be more easy!
            So second: if your model 3D of tile is "manifold" (waterproof) and if you have the Pro version (you have as said your profile) you can make easily Boolean diff with 3D walls! πŸ˜„
            • S ShepherdS Offline
              S Shepherd
              What if you had something like this, at least on the edges where you need to trim solids?
              SS
              Clay roof tile v7.skp
              • kuponoK Offline
                kupono
                I initially tried using solid tools but opted out because:
                • each tile has to be solid and, and in my experience, solids often get unsolid, for unknown reasons, and the hunt to find the problem eats time.
                • you have to make each cut tile unique, then run the solid tool for each (taking a lot of time). While most of the field tile could be instances of a component saving polygons, the cut tiles would each be unique, costing polygons. I'm not sure if there will be a net savings over my single face exploded tile method.
                • It could be my graphics card (NVIDIA GeForce 750M), but when I rotate the model with a field of component tiles I get lags as the tile field redraws. Rotating a field of exploded tiles is smooth. This is only a minor irritation.
                I thought I'd save polygons by using a single face on the tiles. They look okay until you zoom into tiles with exposed ends.
                I'm going to give components another try though, now that I've discovered Zorro2. It has the ability to operate on nested components. I should be able to use the slice-model-at-section option to save time, then use solid tools for interior and oddball tiles. I'll report back.
                Wishful thinking:
                With Zorro2 you can draw a edge on a face of a component which becomes a cut through the component. Pretty cool. You then have to select and erase the parts you don't want. I wish it had the capability of erasing everything to one side or the other of the edge. That'd be very cool.
                  Charlie__V
                  Kupono,
                  I think I understand your problem.....see attached file for an alternate (albeit) still basic option.
                  Essentially........this method uses the "Stamp" function from the Sandbox tool set.
                  Create "stamps"..."cookie cutters"....errr....or "shears"...in this case I created 3 "cutters" to accomplish the task.....as opposed to a closed/single polygon (think doughnut) that will fail to "cut/shear" as necessary. (clear as mud?)
                  Once you create a proper "open/individual" stamp/cutter/shear....it is simply a matter of setting the Stamp "offset = zero" and extruding the undesireable geometry away from the desired geometry enough so that you can easily select/delete the same.
                  I have attached a .zip/SU file...hope it is not overweight.
                  Best,
                  Charlie
                  Lanai_Stamp_CUT_Method.zip
                  • gillesG Offline
                    gilles
                    302 Found
                    (www.screenr.com)
                    [attachment=0:3tavikye]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:3tavikye]
                    If you first hide what must not be cut by the section plane, it works fine.
                    • kuponoK Offline
                      kupono
                      That's very useful to know. Works great.
                      • kuponoK Offline
                        kupono
                        Kupono,
                        Best,
                        Charlie
                        Charlie, I like this approach. I was able to extrude the unwanted areas down, but no matter what I did I couldn't get the offset to equal zero. I saw on a few older posts that the offset can not be zero so I tried .001 and then .1--neither worked. I always end up with the default 1' offset. How'd you get it to work?
                          Charlie__V
                          Kupono,
                          I apologise, I did not notice my input of 0" was not taking. 😳
                          I now see it forces 1" offset minimum......so now this method requires one extra step per cutter.
                          Simply offset the geometry of each cutter in 1" to compensate for the 1" added back by the stamp offest......delete one edge of the cutter to remove the face of the offset.(no need to clean up the perimeter stray lines)
                          Best,
                          Charlie
                          EDIT: Uploaded revised model........saved in V6 for Pilou πŸ˜‰
                          Revised to allow for stamp offset = 1"
                          • kuponoK Offline
                            kupono
                            Charlie,
                            Aside the Stamp tool not accepting a 0" offset value, I've been unable to reliably change it to any value. It may be a SU-2013 bug. After some effort I've found a reliable kludge (contradiction?) (see screencast and attached model). What SU version are you using? Can anyone else duplicate this behavior?
                            Using the Stamp tool is a good solution for my tile trim problem. I'll be using it.
                            There've been a lot of great suggestions and I've learned a lot. Thanks to all.
                            302 Found
                            (www.screenr.com)
                            StampOffsetTest.skp
                              Charlie__V
                              @kupono said:
                              Charlie,
                              302 Found
                              (www.screenr.com)
                              Kupono,
                              I am using SU 2013 Pro/Windows 7Pro.
                              I looked at your screencast.........Try selecting the Stamp tool from the toolbar....and before clicking the mouse on anything....enter a value....6....."....enter.
                              Now select the entity you wish to stamp....and then of course the surface to which you want to stamp.
                              This works reliably for me.
                              FYI:
                              Also....after fooling with this just a bit more I can almost set a value of zero.
                              By entering .001...."....enter......the stamp offset value displays as ~0"
                              Best,
                              Charlie
                              • kuponoK Offline
                                kupono
                                Yup, that does indeed work--and offset = .001 is close enough for govt. work.
                                Thanks again.
                                • gillesG Offline
                                  gilles
                                  Remember that if you apply Slice Model at Section inside a group, the rest of the model is not affected.
                                  SLICE MODEL AT SECTION_V6.skp
                                    Thx for the V6! β˜€
                                    Seems the Apply Section right click / Slice Model at section is not in V7, V6 ?
                                    I have only Create Group from Slice
                                    and so no Aplly Section itself ! Volume trimmed can't be copied as itself trimmed!
                                    • gillesG Offline
                                      gilles
                                      Slice Model at Section is a feature of Zorro2, I don't know if it is V6 V7 compatible.
                                        Not an answer to your problem at hand but I noticed your statement about using the Solid Tools. You don't need to make the components unique prior running the Solid tools. The mere act of modifying the components with these tools essentially does the make unique for you. It replaces the original component with a group.
                                        If you did make your tiles solid components, it wouldn't be that difficult to Use Trim to cut the Tiles.
                                        Here's a quick example. The transparent gray box is the trimmer. Tiles are all instances of the same component.
                                        I select the Trim tool and clicked on the gray box. Then I clicked on each of the tiles that was partially within the box. All that remains is to delete the box. Each of the modified tiles is now a group called "Difference."
                                          There is no pluging for make that automatically ? (after a general selection of these particular tiles for example )
                                            Ah, Plugin Pilou, if there was anyone who would know, it ought to be you. 🀣
                                            I was only showing making the cuts using native tools. I didn't use any plugins nor did I bother to look for any.
