    Looking for tool to cut non-solids along a plane
    34 Posts 10 Posters 2.9k Views 10 Watching
    • Rafferty94R
      Rafferty94
      Forgive me for jumping on this post..
      Hi Pilou.
      Could it be possible to achieve the same outcome by selecting the tiles and grouping them then with the group selected, select the walls and just intersect with selection?
        Surrely that make the same result!
        But not sure you will maybe obtain some lines trimed on the tiles!
        In the original file seems tiles are yet trimed! 😲
        erase all walls for see that!
        So use tiles without lines trimed!
        • cottyC
          cotty
          Reading the other answers I'm not longer shure that I understand the question right, but I created a little screencast, so here it is ...
          http://screenr.com/x84H
          my SketchUp gallery
          • kuponoK
            kupono
            Cutting the tiles at the cut-planes isn't the problem. Any of the Intersect Faces options will work. It's the niggling work erasing the hairy remnants that takes time. Cotty's screen-cast illustrates the problem. Even after aligning with axis, selecting and erasing took him some time. Zorro2's Slice Model at Section options is very nice, erasing everything behind a section, but it can't handle inside areas. Checkout my first screen-cast.
            http://www.screenr.com/574H
            Thanks for all the help.
            Roof to tile
              Ah! Ok! I had not understood that you want cut your roof's tiles! 😳
              I had trimmed only the wals ! πŸ˜„
              So first : as your tiles are some similar you have way better to make a component!
              You will obtain a very more light file!
              And if by hasard you want to change the model of the tile that will be more easy!
              So second: if your model 3D of tile is "manifold" (waterproof) and if you have the Pro version (you have as said your profile) you can make easily Boolean diff with 3D walls! πŸ˜„
              • S ShepherdS
                S Shepherd
                What if you had something like this, at least on the edges where you need to trim solids?
                SS
                Clay roof tile v7.skp
                • kuponoK
                  kupono
                  I initially tried using solid tools but opted out because:
                  • each tile has to be solid and, and in my experience, solids often get unsolid, for unknown reasons, and the hunt to find the problem eats time.
                  • you have to make each cut tile unique, then run the solid tool for each (taking a lot of time). While most of the field tile could be instances of a component saving polygons, the cut tiles would each be unique, costing polygons. I'm not sure if there will be a net savings over my single face exploded tile method.
                  • It could be my graphics card (NVIDIA GeForce 750M), but when I rotate the model with a field of component tiles I get lags as the tile field redraws. Rotating a field of exploded tiles is smooth. This is only a minor irritation.
                  I thought I'd save polygons by using a single face on the tiles. They look okay until you zoom into tiles with exposed ends.
                  I'm going to give components another try though, now that I've discovered Zorro2. It has the ability to operate on nested components. I should be able to use the slice-model-at-section option to save time, then use solid tools for interior and oddball tiles. I'll report back.
                  Wishful thinking:
                  With Zorro2 you can draw a edge on a face of a component which becomes a cut through the component. Pretty cool. You then have to select and erase the parts you don't want. I wish it had the capability of erasing everything to one side or the other of the edge. That'd be very cool.
                  • C
                    Charlie__V
                    Kupono,
                    I think I understand your problem.....see attached file for an alternate (albeit) still basic option.
                    Essentially........this method uses the "Stamp" function from the Sandbox tool set.
                    Create "stamps"..."cookie cutters"....errr....or "shears"...in this case I created 3 "cutters" to accomplish the task.....as opposed to a closed/single polygon (think doughnut) that will fail to "cut/shear" as necessary. (clear as mud?)
                    Once you create a proper "open/individual" stamp/cutter/shear....it is simply a matter of setting the Stamp "offset = zero" and extruding the undesireable geometry away from the desired geometry enough so that you can easily select/delete the same.
                    I have attached a .zip/SU file...hope it is not overweight.
                    Best,
                    Charlie
                    Lanai_Stamp_CUT_Method.zip
                    • gillesG
                      gilles
                      [attachment=0:3tavikye]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:3tavikye]
                      If you first hide what must not be cut by the section plane, it works fine.
                      • kuponoK
                        kupono
                        That's very useful to know. Works great.
                        • kuponoK
                          kupono
                          Kupono,
                          Best,
                          Charlie
                          Charlie, I like this approach. I was able to extrude the unwanted areas down, but no matter what I did I couldn't get the offset to equal zero. I saw on a few older posts that the offset can not be zero so I tried .001 and then .1--neither worked. I always end up with the default 1' offset. How'd you get it to work?
                          • C
                            Charlie__V
                            Kupono,
                            I apologise, I did not notice my input of 0" was not taking. 😳
                            I now see it forces 1" offset minimum......so now this method requires one extra step per cutter.
                            Simply offset the geometry of each cutter in 1" to compensate for the 1" added back by the stamp offest......delete one edge of the cutter to remove the face of the offset.(no need to clean up the perimeter stray lines)
                            Best,
                            Charlie
                            EDIT: Uploaded revised model........saved in V6 for Pilou πŸ˜‰
                            Revised to allow for stamp offset = 1"
                            • kuponoK
                              kupono
                              Charlie,
                              Aside the Stamp tool not accepting a 0" offset value, I've been unable to reliably change it to any value. It may be a SU-2013 bug. After some effort I've found a reliable kludge (contradiction?) (see screencast and attached model). What SU version are you using? Can anyone else duplicate this behavior?
                              Using the Stamp tool is a good solution for my tile trim problem. I'll be using it.
                              There've been a lot of great suggestions and I've learned a lot. Thanks to all.
                              http://www.screenr.com/Mz4H
                              StampOffsetTest.skp
                              • C
                                Charlie__V
                                @kupono said:
                                Charlie,
                                Kupono,
                                I am using SU 2013 Pro/Windows 7Pro.
                                I looked at your screencast.........Try selecting the Stamp tool from the toolbar....and before clicking the mouse on anything....enter a value....6....."....enter.
                                Now select the entity you wish to stamp....and then of course the surface to which you want to stamp.
                                This works reliably for me.
                                FYI:
                                Also....after fooling with this just a bit more I can almost set a value of zero.
                                By entering .001...."....enter......the stamp offset value displays as ~0"
                                Best,
                                Charlie
                                • kuponoK
                                  kupono
                                  Yup, that does indeed work--and offset = .001 is close enough for govt. work.
                                  Thanks again.
                                  • gillesG
                                    gilles
                                    Remember that if you apply Slice Model at Section inside a group, the rest of the model is not affected.
                                    SLICE MODEL AT SECTION_V6.skp
                                      Thx for the V6! β˜€
                                      Seems the Apply Section right click / Slice Model at section is not in V7, V6 ?
                                      I have only Create Group from Slice
                                      and so no Aplly Section itself ! Volume trimmed can't be copied as itself trimmed!
                                      • gillesG
                                        gilles
                                        Slice Model at Section is a feature of Zorro2, I don't know if it is V6 V7 compatible.
                                          Not an answer to your problem at hand but I noticed your statement about using the Solid Tools. You don't need to make the components unique prior running the Solid tools. The mere act of modifying the components with these tools essentially does the make unique for you. It replaces the original component with a group.
                                          If you did make your tiles solid components, it wouldn't be that difficult to Use Trim to cut the Tiles.
                                          Here's a quick example. The transparent gray box is the trimmer. Tiles are all instances of the same component.
                                          I select the Trim tool and clicked on the gray box. Then I clicked on each of the tiles that was partially within the box. All that remains is to delete the box. Each of the modified tiles is now a group called "Difference."
                                            There is no pluging for make that automatically ? (after a general selection of these particular tiles for example )
