    Cant see my model!!!
    14 Posts 7 Posters 1.7k Views 7 Watching
      Jomy
      Hmmm well everything is there, I have Hidden Geometry on and when I go to outliner everything is there. I don't know if the problem has to do with the file being heavy or what but I can't seem to be able to do anything with it.
        driven
        what does 'Outliner' say is in the drawing?
        if anything is there, can you double click into editing an item?
        you may have a really long line that's throwing things out.
        revert to last Saved may also work
        • ely862meE
          ely862me
          Not hurting to mention the layers ?
          Elisei (sketchupper)
          Come and See EliseiDesign
            driven hit on something to check. It may be that it's not a really long line but a tiny line segment that is placed at a long distance from the rest of the model. As he suggested, what happens when you double click on something in the Outliner? Another thing to do is right click on one of the entries in Outliner and choose Zoom Extents. If you find your model that way, take careful note of where it is. Then hit Camera>Zoom Extents or Zoom Extents on the toolbar. Drag a large selection box around the area where the model isn't and hit Delete. Hit Zoom Extents again to see if you were able to select and delete the tiny thing causing the problem.
              Jomy
              Ok! so when I double click on something in the Outliner the name disappears. Also when I right click on something in the outliner and choose Zoom Extents, it doesn't do anything. So today while trying to figure this out I went to camera>position camera and then change the view style to back edges and this is what I get. Everything seems to be there...
                Jomy
                This is what it looks like when I position the camera and change the styleThis is what it looks like when I position the camera and change the styleHey I posted something on here before but it doesn't seem like it went through. But yeah the outliner shows everything in there, when I click on something in the outliner, the name sort of disappears. Also when I right click on something in the Outliner and then click on zoom extents it doesn't do anything. Today while trying to figure things out I went to camera>position camera and then change the view style to back edges. This is what I got. Everything seems to be there...
                  Well, you really haven't given us a whole lot to work with and it doesn't sound like you've tried our suggestions. What happens when you turn on Hidden Geometry? Have you tried Command-A and Edit>Unhide all? Is it possible you've turned off Edges in the style setting? Maybe you could give us a screen shot of the Outliner?
                  • Wo3DanW
                    Wo3Dan
                    Is this an ordinary display issue due to unsupported OpenGL?
                    Try menu Window > Preferences > OpenGL > disable 'Use hardware acceleration' and restart SketchUp to see if you model is visible as should.
                      Jomy
                      Hey Guys I'm sorry I haven't really given you enough details. Somebody recommended me to attach my file to this post. Its really big, so I have attached the file to transferbigfiles.com
                      The link to it is:
                      Transfer Big Files
                      TransferBigFiles.com allows computer users to send large files to anyone. Videos, pictures, documents or any other file that is too large to send as an email attachment can be sent through TransferBigFiles.com
                      TransferBigFiles.com (www.transferbigfiles.com)
                      hopefully one of you can find out what's wrong!
                      Thanks in advance
                        You have got a lot of overly complex geometry and multi-level nested objects your that SKP...
                        Something in there probably has some rogue geometry a zillion miles off the origin causing issues...
                        Some of the objects are also weirdly named etc...
                        e.g. the 'kitchen' and the the two 'baths'...
                        Try exporting some of the components as individual SKPs and work on those, then reload them...
                          Jomy
                          Thanks Juan.V. Soler I can see it!!!
                            JuanV.Soler
                            ... don´t ask me how I did it ...
                            exploded randomly some components , changing the style , ...
                            anyway it worked so you can now see your model , I hope 😄
                            https://www.dropbox.com/s/spc1hau7v1e9jlf/housequick%202.skp
                            Cheers
                            edit : mission accomplished, removed the attachment
