    Plant Factory Released
    extensions
    36 Posts 9 Posters 3.9k Views 9 Watching
    • PixeroP Offline
      Pixero
      Having played a short while with the new version now...
      The interface is somtimes slow.
      You can "unsubdivide" a tree down to just triangles plus you can hide leaves and the outer branches so it could be used as a lowres proxy standin.
      The branch/trunk connections look pretty good.
      Highres tree
      Very lowres tree
        What spec machine are you using?
        • PixeroP Offline
          Pixero
          Here at home I have a i7 with 8gb RAM and a GTX580 1,5 GB Graphics card.
          Here are two very quick testrenders from Thea without much care for the materials.
          They look a bit over saturated in my opinion.
          Quick testrenders from Thea
          Another Quick testrender
          Exported to 3ds and imported into Thea without any problems. Color maps were applied but clipmaps and bumpmaps had to be added by hand.
          By the way..its super easy to create variations in Plant Factory.
          Just click on the Dice symbol.
          Hmm, might be useful though...
          • KrisidiousK Offline
            Krisidious
            I take it that it's 64 bit and multicore supported?
            By: Kristoff Rand
            • PixeroP Offline
              Pixero
              Its 64bit. Multicore I dont know.
              • soloS Offline
                Looks great Pixero, I would create all the maps, until it looks perfect then save as a mod file, make a low poly proxy and add to your Thea tree library.
                I asked the question on both LumenRT and Tree factory forums if trees made in Tree factory can be used in LumenRT (with animation), yet to get an answer, do you know?
                • PixeroP Offline
                  Pixero
                  I read that all plants in LumenRT were made with Plant Factory but I don't know how they should be exported or in what format.
                    jpalm32
                    @krisidious said:
                    "Pretty standard in the High End Plant Creation Business..." A lot of those businesses is there? what like 4?
                    πŸ˜† πŸ˜†
                    • PixeroP Offline
                      Pixero
                      It seems it comes in five different flavors now.
                      Here is a comparison chart.
                      http://www.theplantfactory-tech.com/purchase/index.php#Chart
                        Krisidious
                        So if you buy $199 for Vue Artists and CG Artists for $99 you get everything that's in CG Professionals for $300 instead of the $495 it's advertised at. save 3 plants. Hmmm?
                        $100 increments for maintenance on the top 3 systems... $100,$200 and $300.
                        Whoever priced this did it pictorially and not by any sense of cost and effect.
                        By: Kristoff Rand
                        • DanielD Offline
                          Daniel
                          In the Designer, and Converter versions, plants can be exported for use in other software only as static meshes (will not animate such as responding to wind - I believe they will animate, however, in Vue). In the Artist version, plants cannot be exported. Also, in the Designer version there are more plants and plant components (for creating new plants).
                          My avatar is an anachronism.
                          • DanielD Offline
                            Daniel
                            If you ever get an answer to this question, please post it. I'm using LumenRT, too, and was wondering the same thing.
                            • soloS Offline
                              Steve Bell
                              E-On Software staff
                              LumenRT 4 Studio
                              No, I'm afraid Plant Factory is still not compatible with LumenRT. Although LumenRT 4 plants were all created with Plant Factory, there is still a lot of work to be done to allow Plant Factory to export directly into something that LumenRT can use. But we're working on it
                              • DanielD Offline
                                Daniel
                                Thanks, Solo
                                • soloS Offline
                                  A PLE version is available.
                                  Wrong slice, right place - redirect.pizza
                                  (www.plantfactory-tech.com)
                                  • 2 / 2
