    Plant Factory Released
    extensions
    36 Posts 9 Posters 3.7k Views 9 Watching
    • soloS Offline
      Looks great Pixero, I would create all the maps, until it looks perfect then save as a mod file, make a low poly proxy and add to your Thea tree library.
      I asked the question on both LumenRT and Tree factory forums if trees made in Tree factory can be used in LumenRT (with animation), yet to get an answer, do you know?
      • PixeroP Offline
        Pixero
        I read that all plants in LumenRT were made with Plant Factory but I don't know how they should be exported or in what format.
          jpalm32
          @krisidious said:
          "Pretty standard in the High End Plant Creation Business..." A lot of those businesses is there? what like 4?
          πŸ˜† πŸ˜†
          • PixeroP Offline
            Pixero
            It seems it comes in five different flavors now.
            Here is a comparison chart.
            http://www.theplantfactory-tech.com/purchase/index.php#Chart
            • KrisidiousK Offline
              Krisidious
              So if you buy $199 for Vue Artists and CG Artists for $99 you get everything that's in CG Professionals for $300 instead of the $495 it's advertised at. save 3 plants. Hmmm?
              $100 increments for maintenance on the top 3 systems... $100,$200 and $300.
              Whoever priced this did it pictorially and not by any sense of cost and effect.
              By: Kristoff Rand
              • DanielD Offline
                Daniel
                In the Designer, and Converter versions, plants can be exported for use in other software only as static meshes (will not animate such as responding to wind - I believe they will animate, however, in Vue). In the Artist version, plants cannot be exported. Also, in the Designer version there are more plants and plant components (for creating new plants).
                My avatar is an anachronism.
                • DanielD Offline
                  Daniel
                  If you ever get an answer to this question, please post it. I'm using LumenRT, too, and was wondering the same thing.
                  • soloS Offline
                    Steve Bell
                    E-On Software staff
                    LumenRT 4 Studio
                    No, I'm afraid Plant Factory is still not compatible with LumenRT. Although LumenRT 4 plants were all created with Plant Factory, there is still a lot of work to be done to allow Plant Factory to export directly into something that LumenRT can use. But we're working on it
                    • DanielD Offline
                      Daniel
                      Thanks, Solo
                      • soloS Offline
                        A PLE version is available.
                        Wrong slice, right place - redirect.pizza
                        (www.plantfactory-tech.com)
                        • 2 / 2
