    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 182.9k Views 109 Watching
      db11
      @jiminy-billy-bob said:
      I will, but first I'm learning what are the differences between windows and mac.
      Looking forward to a functioning Mac version!
      A question / suggestion:
      Any chance that your plugin will work with the TIG's Layer Name Export/Import plug-in in a way that will preserve/establish the layer hierarchy?
      I would love to have standardized, predefined layer outline sets — depending on the type of model being built: i.e. furniture, cabinetry, architectural, product design — that could be loaded from a .layers file on starting a new model. I do that now, but being able to import an outlined layer structure would be killer!
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        I'll look into that. In the meantime, you can use templates. They should keep the nested/sorted structure.
          db11
          Cool.
          Given that you report some people apparently using the beta on their macs, maybe I will try it out as-is to help with user testing. Don't have the knowledge to help on the Ruby front, but can at least add my voice through bug reporting (assuming that the current beta works at all on my mac).
          I'm running SU8 on OSX 10.6.8 (Snow Leopard)... will let you know how it goes.
            jiminy-billy-bob
            Great, thanks ! 😄
              db11
              OK, after about an hour of playing (and 1 bug splat) around here's what I found on my mac:
              What works:
              • installation
              • toolbar
              • web dialogue (layers panel window)
              • add layer
              • add group
              • name/rename group/layer
              • nest / move
              • import layers through TIGs plugin - fills layer panel
              • layer visibility toggle
              Doesn't work:
              • group visibility (no effect at all)
              • delete layer (no effect at all)
              • delete group (deletes group and nested layers from panel, but not Layers window)
              • purge unused layers
              Big Problems:
              • existing layers don't automatically fill layer panel
              • on save and close / reopen, layer panel loses all layers
              • on switching focus to a second model window, the layer panel loses all layers
                ( probably related to the fact that Mac OS allows multiple windows in a single application instance whereas Windows allows only one window per application instance (therefore multiple model windows = multiple SU instances) IIANM.
              Hope this helps. This is going to be an awesome plugin once it's debugged!
                jiminy-billy-bob
                Thanks a lot ! That's very usefull 😄
                • ToboboT Offline
                  Tobobo
                  This looks like a giant leap forward. Well done 👍
                  I use a lot of models from other people and CAD drawings, this will be great to keep the model organised.
                  Toby
                  Philippians 4:13
                    jiminy-billy-bob
                    New version 0.3 beta !
                    Changelog :
                    • Locking layers (Works only when purging or deleting from the plugin's menu)
                    • Ability to add a layer only visible in the current scene (New pop-up menu when holding the "Add layer" button)
                    • Layers Panel is now a toolwindow, but you can't dock nor collapse it
                    • Two different delete buttons, for better performance (The red cross deletes the layer content, the green arrow moves the content to the default layer)
                    • Several bug fix
                    http://i.imgur.com/5ly9dzl.png
                    Download in the plugin store !
                    • utilerU Offline
                      utiler
                      Gee, you do work fast and listen to request, JBB!!!!!!
                      Have you ever been to Boulder; I hear they're hiring...... 👍
                      Just Curious...
                      • bagateloB Offline
                        bagatelo
                        Someone already ask for freeze layers content?
                          jiminy-billy-bob
                          I'm not sure I could do that. 😕
                          • I Offline
                            ivreich
                            OMGOMGOMGOMGOMGOMG
                            Layer groups!!! FINALLY. THANK YOU...You are a godsend!
                            Now if only we can get Trimble to pay you royalties to include this in the next basebuild of SU...It's something they should have had since the very beginning
                            Well done.
                            Joel
                            • cmeedC Offline
                              cmeed
                              this looks like a really good addition to sketchup.
                              but - existing layers don't show up. downloaded plugin mid project.
                              using latest sketchup and latest version of Layers panel. Windows.
                              cheers
                              c
                              EDIT: I'm not sure what happened but the layers have now appeared - it could have coincided with me importing an image but not sure
                              • X Offline
                                xkalvisx
                                Does not save group names
                                opening the panel, the group names reappear (Group1, group2, etc.).
                                More ...
                                We would like to keep the size of the panel as it was before it was shut down.
                                Great thanks.
                                https://www.dropbox.com/s/mw0340kn4nvquja/1.jpg
                                Dropbox - Error - Simplify your life
                                (www.dropbox.com)
                                Before it was listed all the names of the groups.
                                Thanks.
                                • bagateloB Offline
                                  bagatelo
                                  Maybe you can add this function?
                                  http://sketchucation.com/forums/viewtopic.php?f=323&t=54108&p=490389#p490389
                                  • cmeedC Offline
                                    cmeed
                                    This plugin is really good. And intuitive. maybe because its so familiar (pShop)
                                    I am losing my group names. no data lost but its happened a couple of times.
                                    I'm looking out for the next time and will report ..
                                    cheers
                                    c
                                    EDIT: every time i use "undo" the layer Group Name reverts back to the "Group1"- its original default name.
                                    Anybody confirm this???
                                    (all layer names within group stay the same)
                                      jiminy-billy-bob
                                      Sorry guys about the group names, I'll look into it.
                                      When you had the problem, did you restart sketchup after installing the plugin ?
                                      If you manage to reproduce the bug, I would be glad if you gave me the intructions.
                                      Sorry, but that's a limitation of the API. Sketchup saves the dialog's size/position between sessions, but not during a session... Dumb, I know, but there's not much I can do.
                                      That's not really the purpose of the plugin, which is to manage layers, not the model's entities. Maybe one day I'll add this kind of features, but for now that's not my priority.
                                        jiminy-billy-bob
                                        When you undo, the Layers Panel dialog reloads its content. So what you're seeing is related to the same bug everybody is having with group names.
                                        • cmeedC Offline
                                          cmeed
                                          Yes i restarted - they didn't appear right away! they appeared after i'd worked on the model for a bit. then i noticed. I'll keep my eyes open when next time the occasion crops up.
                                          Great to see this Plugin. especially the "add layer visible only in this scene" - touch!!
                                          c
                                            jiminy-billy-bob
                                            If you have an old copy of the file that you didn't open after you installed Layers Panel, it would be great if you could PM it to me 😄
                                            • 33
                                            • 34
                                            • 8 / 34
