    Style Stroke Width (Sketchy Edges)
    53 Posts 5 Posters 12.1k Views 5 Watching
      Charlie__V
      @dave r said:
      If you export a PNG or JPG does it look the same as on screen? What about if you increase the export size?
      Export is same for view size and of course "finer" for HQ export.
      View Size Export
      Export HQ
        I wonder how I got so lucky.
        Hardware acceleration on
          Charlie__V
          @box said:
          Sorry Charlie, just to clarify, the my two images above are the same style, top with max texture on and bottom with it off.
          10-4 Understood......I get the same. (w/raster based linestyles only)
          @box said:
          It appears to be related to hardware acceleration as well, if I turn that off the style works with max texture on but things become slow.
          I not well informed on the nuts & bolts of Open GL & Hardware Acceleration....but pretty sure this breaks any linkage to the Graphics Card and relys solely on "software" to process things. (hence the slowdown)
          IOW.....yes it does relate.........but I wonder if you can really have max texture capability without the Hardware Acceleration on. (sounds good anyway) πŸ˜„
          Charlie
          • BoxB Offline
            Do you have an Nvidia graphics cards?
              Charlie__V
              [attachment=0:3mght2s6]<!-- ia0 -->hardware accel.png<!-- ia0 -->[/attachment:3mght2s6]
              Dave,
              Beats me..........In your Open GL options......why not use the first option (40 True Color Medium 4x)?
              Charlie
                Charlie__V
                Nvidia Quadro600 (1GB).......2 year old machine.
                But again.....why only in SU 2013 and not SU V8?
                Charlie
                  [attachment=0:cbl0qscz]<!-- ia0 -->hardware accel.png<!-- ia0 -->[/attachment:cbl0qscz]
                  Dave,
                  Charlie
                  No special reason. It's the setting that was automatically selected when I installed SU and it didn't cause me any trouble so I left it alone.
                  • BoxB Offline
                    It's all very odd.
                    I now have it set, Use hardware acceleration on and the other two off, and that seems to work best for me.
                    Sketchy styles work, speed is good and I don't have the strange sloppy tool buttons.
                    I'm sure it will be different tomorrow.
                    Bugga, just realised I forgot which way I was holding my mouth....
                      Charlie__V
                      I did not draw attention to it in my original post, but look at the editor "stroke" preview pane.
                      Stroke Preview Pane
                      • BoxB Offline
                        Yep, I saw that and mine was the same.
                          Charlie__V
                          Box,
                          Now that you have your settings just right.........can you turn the max tex back on and "send to layout"............on my machine it will display properly in Layout while having the thick strokes in SU.
                          Edit:.....Scratch that.......I see you are on Free Make. 😳
                          Best,
                          Charlie
                          • BoxB Offline
                            If I turn max tex back on it goes thick in SU, I don't have layout on this machine to test, I don't use it, I have Pro for SU7 on another machine if I ever need it, but have not bothered to upgrade as I haven't found my needs stretch beyond the free version these days.
                              I noticed that, too. That seems to reflect the way the style displays but I wonder why it is like that. The line width is supposed to be 16 pixels (Well, the width of the boxes for the strokes is 16 pixels.) If you open the style in Style Builder, does it display like it should or as those wide strokes?
                                Charlie__V
                                I checked out a few of the styles in Style Builder earlier today......and they display as they should in the preview window.
                                But just now when I opened Style Builder (no Style Selected/loaded)it appears eerily like what the SU displays with Max Texture Selected.
                                Hmmm....wonder if SU relys on Style Builder in the background to display the sketchy styles?
                                EDIT: Or maybe selecting Max Tex somehow breaks the interpretation of the line width?
                                Style Builder: No Style
                                Style Builder: Brown Style
                                Style Builder: Brown Style (2013 Model)
                                  It looks like that because you have no stokes inserted in the set. In the upper right hand box you can see the empty cells where stokes need to be placed. The model displays those cells as well. You can drag the sample strokes from the left hand pane up to the cells and then you'll see the lines displayed on the model. If you open an existing style or load a style template, the strokes will be inserted into the cells automatically but the sample strokes aren't.
                                    Charlie__V
                                    Dave,
                                    Yes...I fully understand that,what I was pointing out was Style Builder (without any strokes inserted)looks very much like what Sketchup is displaying.(or NOT displaying)
                                    IOW....it's almost as if SU is not reading any of the sketchy linestyles of the particular style that is selected.
                                    (while correctly displaying the selected styles colors/background/etc.)
                                    Make sense?
                                    Charlie
                                    EDIT:
                                    Wonder if making a new style without any lines inserted would replicate the condition?
                                    I could test that..........but won't know if it breaks with Max Tex. on (on my machine).
                                      Charlie__V
                                      Interesting.........eliminating all of the Strokes in Style Builder seems to (almost) replicate the fat lines.
                                      No Strokes (Eliminated in Style Builder)...Light Brown
                                      Stroke_Width_SU2013.skp
                                        Almost. I wonder if it would be useful for something.
                                          Charlie__V
                                          Well....perhaps not very useful for capturing Sasquatch....or say Nessie for that matter. πŸ˜‰
                                          But may just be a hint to where the broken link lies....and no... not the same as the missing link.
                                          Charlie
                                            Charlie__V
                                            So.......almost a year later.....and having use maximum texture size ticked.......this bit me again. (how could I not immediately remember this thread) πŸ‘Š
                                            Anyway........I can add a little bit of info here:(perhaps useful to those having this issue)
                                            It seems that if you toggle the "use maximum texture size" off..... and purge the unused styles, you can then toggle "use maximum texture size" on again and the sketchy styles will display/behave as expected.
                                            I remain perplexed by this..........is it a Bug?
                                            If it were a video card would it not be "consistent"...IOW...as soon as use max tex size is back on one would expect it to foul up right away...........maybe not?
                                            C
                                            ![intial sketchy style selection displays correctly (w/MaxTex "on")](/uploads/imported_attachments/G2q2_MaxTex_SketchyEdge1.JPG "intial sketchy style selection displays correctly (w/MaxTex "on")")
                                            ![subsequent sketchy style selection(s) display incorrectly (w/MaxTex "on")](/uploads/imported_attachments/MvWy_MaxTex_SketchyEdge2.JPG "subsequent sketchy style selection(s) display incorrectly (w/MaxTex "on")")
                                            ![MaxTex "off" and after style purge MaxTex "on" sketchy styles display as expected](/uploads/imported_attachments/JHg4_MaxTex_SketchyEdge3.JPG "MaxTex "off" and after style purge MaxTex "on" sketchy styles display as expected")
                                            • 2 / 3
