    Style Stroke Width (Sketchy Edges)
    53 Posts 5 Posters 12.8k Views 5 Watching
      But just now when I opened Style Builder (no Style Selected/loaded)it appears eerily like what the SU displays with Max Texture Selected.
      It looks like that because you have no stokes inserted in the set. In the upper right hand box you can see the empty cells where stokes need to be placed. The model displays those cells as well. You can drag the sample strokes from the left hand pane up to the cells and then you'll see the lines displayed on the model. If you open an existing style or load a style template, the strokes will be inserted into the cells automatically but the sample strokes aren't.
      • C
        Charlie__V
        Dave,
        Yes...I fully understand that,what I was pointing out was Style Builder (without any strokes inserted)looks very much like what Sketchup is displaying.(or NOT displaying)
        IOW....it's almost as if SU is not reading any of the sketchy linestyles of the particular style that is selected.
        (while correctly displaying the selected styles colors/background/etc.)
        Make sense?
        Charlie
        EDIT:
        Wonder if making a new style without any lines inserted would replicate the condition?
        I could test that..........but won't know if it breaks with Max Tex. on (on my machine).
        • C
          Charlie__V
          Interesting.........eliminating all of the Strokes in Style Builder seems to (almost) replicate the fat lines.
          No Strokes (Eliminated in Style Builder)...Light Brown
          Stroke_Width_SU2013.skp
            Almost. I wonder if it would be useful for something.
            • C
              Charlie__V
              Well....perhaps not very useful for capturing Sasquatch....or say Nessie for that matter. πŸ˜‰
              But may just be a hint to where the broken link lies....and no... not the same as the missing link.
              Charlie
              • C
                Charlie__V
                So.......almost a year later.....and having use maximum texture size ticked.......this bit me again. (how could I not immediately remember this thread) πŸ‘Š
                Anyway........I can add a little bit of info here:(perhaps useful to those having this issue)
                It seems that if you toggle the "use maximum texture size" off..... and purge the unused styles, you can then toggle "use maximum texture size" on again and the sketchy styles will display/behave as expected.
                I remain perplexed by this..........is it a Bug?
                If it were a video card would it not be "consistent"...IOW...as soon as use max tex size is back on one would expect it to foul up right away...........maybe not?
                C
                ![intial sketchy style selection displays correctly (w/MaxTex "on")](/uploads/imported_attachments/G2q2_MaxTex_SketchyEdge1.JPG "intial sketchy style selection displays correctly (w/MaxTex "on")")
                ![subsequent sketchy style selection(s) display incorrectly (w/MaxTex "on")](/uploads/imported_attachments/MvWy_MaxTex_SketchyEdge2.JPG "subsequent sketchy style selection(s) display incorrectly (w/MaxTex "on")")
                ![MaxTex "off" and after style purge MaxTex "on" sketchy styles display as expected](/uploads/imported_attachments/JHg4_MaxTex_SketchyEdge3.JPG "MaxTex "off" and after style purge MaxTex "on" sketchy styles display as expected")
                  Charlie,
                  I get the results you show in your second screen shot with certain OpenGL settings. On my PC, the line styles behave themselves with Hardware Acceleration turned off.
                  • C
                    Charlie__V
                    @dave r said:
                    Charlie,
                    Hey Dave,
                    Well.......maybe it is a graphics card issue after all?
                    Seems strange to me though that the sketchy edge styles (tied to image files) act up only when "use maximum texture size" is selected. (Hardware Acceleration off on my machine exhibits even more anomolies)
                    Would be nice to know what.......if anything......is amiss.
                    (Reminder..I think the viewports in LO ignore this anomolie...discussed earlier in this thread) πŸ˜•
                    Until then.......I will try my best to remember to disable/manipulate the "use max tex size" when this occurs.
                    Best,
                    Charlie
                      I always have Max Texture selected and have never seen it influence the way the lines render but maybe it's different on different computers.
                      • C
                        Charlie__V
                        So......I prefer to have max tex size ticked.(imported image clarity)
                        This has been (really) bugging me........and so for anyone following this...this workaround helped me:
                        If you (temporarily) un-tick use max tex size and create scenes with your desired sketchy style(s) you can then turn use max tex size back on..... with no ill effects to the scenes with sketchy styles.
                        You may have to repeat the untick/re-tick if selecting a new sketchy style...but know that if it is not saved to a scene it will not (reliably) display correctly.
                        Note:
                        Really makes me wonder why use max tex size causes this...almost like there is a bad connection to the sketchy style (stroke) image file(s).
                        IOW...one would not think use max tex size would cause blurred/heavy/pixelated sketchy linestyles (strokes).....I would think the opposite.....the linestyles would be more refined.........no?
                        Heck.......the more I think about it.......the imported images (max tex) in my file react accordingly to the use max tex size......untick....and the images blur......re-tick and they clear up.
                        Regardless of scene attributes/settings.
                        Yet the sketchy styles "hold on" to the blurred/heavy/pixelated linestyles.....ignoring the un-ticking/re-ticking of the use max tex size.
                        Okay.....rambling now.........thinking for sure this is a bug....not so much graphics card/other.
                        Best.
                        C
                          I don't know, Charlie. I have never seen the sketchy line styles impacted by having Max Texture Size checked on either my PC or my Mac.
                          • C
                            Charlie__V
                            Dave,
                            Yeah....thanks....It's weird...this machine was fine and all of a sudden it mis behaves like this.
                            When I say Bug....I mean it's like something gets corruped within SU (some sort of cache?)....I see talk about some having trouble with P lists and how that can be repaired...think that's Mac though.....any way...I'm getting into the weeds.
                            I am glad I can overcome it and use the max tex size now. (hopefully it helps others)
                            Thanks for your help. πŸ˜‰
                            Charlie
                            • maxhouserocksM
                              maxhouserocks
                              i have the exact same problem in SU2014 and SU2015 on two different machines, 1 is an Origin PC with a NVIDIA TITAN BLACK, the other is an MSI laptop with an NVIDIA GeForce GTX880M . I had always kept the max texture setting check marked, now i will have to keep toggling as you suggest.
                              So strange that these edges suddenly lose their definition and appear to be fat, wide, blurry lines...makes no sense.
                              your work around works for me, but boy is it a pain.
                              I had trouble even finding a reference to this issue but certainly glad i found this post.
                              Thanks guys!
                              Bob
                              Robert A. Christman
                              http://rachristman.blogspot.com/
                                Robert, was it the max Texture Size of Hardware Acceleration change that fixed it for you?
                                I guess I haven't seen this for a long time and had kind of forgotten about it.
                                • maxhouserocksM
                                  maxhouserocks
                                  yes. max texture, not acceleration. i uncheck max texture only, purge styles in model, then select the ones i want to use and turn max texture back on. very very strange. i like to use max textures all the time.
                                  has anyone ever submitted this as a bug to Trimble? or is that useless??
                                  thanks,
                                  bob
                                  this works. the style i tried to use HAS to be purged as you mentioned though. Then i can load it after the purge.
                                  Robert A. Christman
                                    I don't know if anyone has submitted it as a bug. I'm not entirely sure it is a bug. As I said, I haven't seen this in a long time. Certainly never on my current PC or MacBook Pro. I put it down to an issue with the GPU or the graphics driver.
                                    I've created a lot of sketchy styles and it hasn't been a problem.
                                    By the way, what style is that?
                                    • maxhouserocksM
                                      maxhouserocks
                                      its called SCRATCH. i dl'd from this site:
                                      http://www.sketchupartists.org/2012/05/styles-collection-2013/
                                      (towards bottom of page)
                                      But the watermarks didnt seem to come witht he style for me for some reason. was initially what i was interested in.
                                      Interesting that you dont have the problem anymore. i have never run into it until now. Maybe i should try updating drivers, etc and report back.
                                      thanks,
                                      bob
                                      Robert A. Christman
                                        I thought that looked like one of my line styles.
                                        As for the watermark, I'll check when I get home from work and see what the deal is. If there is a watermark it should show up unless it's disabled in the watermark settings.
                                        Years ago, I had a big problem with it on a style I made for a client's projects. I haven't used that style for more than 5 years now. None of the other sketchy styles have shown that.
                                        It is weird that it just reared its ugly head now for you.
                                        • maxhouserocksM
                                          maxhouserocks
                                          hahaha! i didnt put the two together...you are THE David R!
                                          Nothing came in for watermarks at all. there are none attached when i look through the edit settings.
                                          Great work btw. Very cool. I have some cool ones i made years ago with some nice watercolor backgrounds, texture overlays, etc that i should probably share. Is that site the best place to share styles and things like that?
                                          thanks,
                                          bob
                                          Robert A. Christman
                                          • maxhouserocksM
                                            maxhouserocks
                                            i cant help but notice that your squirrel seems to frequent the same Haberdashery as ThomThom. Coincidence?
                                            Robert A. Christman
                                            • 2 / 3
