    Retangular light
    renderpluginsextensions
    8 Posts 5 Posters 919 Views 5 Watching
      pankaj_tamore
      Dear friends,
      Can anyone out there tell me what needs to be done for changing rectangular light color in vray. i tried lot but found only luminance changes from white to yellow or to blue as i want. but its color remains white the it is seen in its default mode.in realty when we switch on blub with blue colored glass it give blue color luminance & same time it looks blue not yellow though it its filaments gives off yellow light since it is surrounded by blue color glass it determines its(blue) color of light.
      Thanks & Regards
      Pankaj A. Tamore
      • pbacotP Offline
        What software? This post might fit better in one of the rendering forums.
          pankaj_tamore
          Thank you very much for notifying me that in a haste i missed to mention the name of rendering software in my post. it was Vray i got stuck in!
          • pbacotP Offline
            Maybe I didn't read all the way to the forum name! I see this IS in the V-ray forum! Unfortunately I am not the person to help with V-ray. Bump.
            • massimoM Offline
              massimo Moderator
              No worries, I moved the topic after pankaj said it was vray. ๐Ÿ˜‰
              • dkendigD Offline
                dkendig
                you want the light itself (the rectangle) to appear to be a different color? Or you want the light that is cast from it to be a different color? I'm not sure I follow what you are trying to do here.
                Devin Kendig
                Developer
                  pankaj_tamore
                  Dear All,
                  I am thanking each one you for your replies and support regarding my Rectangular light query.
                  • andybotA Offline
                    andybot
                    If you've changed the color but it still shows as white, you might try reducing the intensity of the light. The light is probably just too bright to see the color in your render.
