    [Plugin] Simple Plugin Installer
    83 Posts 29 Posters 189.0k Views 29 Watching
    • GaieusG
      Hi Dima,
      Have you got the latest version of SketchUp 8? This feature was introduced in Maintenance release 2 only.
      • K
        kungfu
        why does i dont have install extension?
        • massimoM
          massimo Moderator
          Look at the post above yours.
            Because you need SketchUp 8M2 or newer. πŸ˜’
            • F
              filipeefilipe
              I dont find the button "install extension". Could somebody help me? Is there another way to install rbz files? thank you.
              • massimoM
                massimo Moderator
                • F
                  filipeefilipe
                  Massimo, i had seen that post. I've asked if there is another way to instal rbz files. I dont want change my sketchup version. thank you.
                  • GaieusG
                    In that case, simply change the *rbz extension to *.zip, open the archive and copy the content into the plugins folder of your SketchUp application.
                    • F
                      filipeefilipe
                      It worked! thank you, Gaieus!
                      • SKYNET-71S
                        SKYNET-71
                        Hi to all, i have a problem with sk 8 pro, do not upload it to m2. It's possible a manual installation? How can I use the plugins with the extension rbz without the button "install extensions" or without the Maintenance Release 2? What's the difference between "VERTEX TOOLS v 1.1 and BEZIER SURFACE? What's the best? Thanks for help. Greetings to all.
                          Why wouldn't you upgrade to at least the last maintenance release of SU8? If you really aren't going to do that, change the .RBZ extension to .ZIP. Then you can extract and manually install the files within. Make sure you maintain the file structure within the downloaded file. Also make sure you read the thread from which you download the file and be sure you get any required supporting files and install them correctly, too.
                          • SKYNET-71S
                            SKYNET-71
                            Hi.I have a problem for installing the "rbz" files. I just updated SU 8 pro, BUT I CAN NOT INSTALL PLUGINS rbz! I followed all the explanations, but without solving the problem. In my System Preferences window, there is no "Ruby Console+" (why?)but in Windows <Ruby Console, yes. The file to be loaded with rbz system preferenes <install extensions or Plugins<Install, must stay in the plugins folder or can stand even in the desktop? Messages SKETCHUP when I install the plugins rbz are ok, Quadface Tools STAY in the System preferences Window but I can not find it in tools / plugins ! Can anyone help me please? Thanks.
                            SKYNET-71
                            • tt_suT
                              tt_su
                              Do not place RBZ files in your plugins folder. You can download them to anywhere else on your computer. Then use SketchUp.. Window > Preferences > Extensions > Install Extension and select the RBZ file.
                              Also not that some plugins require additional files.
                              • P
                                paulwolf
                                So I installed the plugin and it helped greatly. The problem I am having now is that it moved my plugins folder and I cant find it anywhere. It has messed up my Vray and when I try uninstalling and then reinstalling all of the plugins are still attached to the new download. Does anyone have any experience with this problem or advice. Much appreciated.
                                -Paul
                                • B
                                  BeePee
                                  Your SU Plugins are excellent! Clean-up is especially brilliant, I use it all the time. One query though:
                                  I'm having trouble importing complex STL files into Skethcup using the usual STL Import and Export plugin, so I searched and found su2stl to see if it would work better. I downloaded it and it's in my Loaded Plugins list.
                                  However, there is no menu button to open it, and it's not in my Loaded Exrensions list. I downloaded your Simple Plugin Installer in the hopes it would do the trick, but no luck.
                                  I know this isn't your program. but how do I get su2stl.rd working so I can use it to imp[ort STL files?
                                  The STL files I'm trying to load (small complex models in mm) pop up instantly in Rhino, but Sketchup struggles. It will load simpler ones after quite a time, but not the more complex ones.
                                  Final question: is there another STL importer that is worth trying for Skethup?
                                  Thanks for your help,
                                  BeePee
                                    What trouble? Might be worth addressing this first.
                                      JMaults
                                      So happy I found this!!! Im new to sketch up and I was having trouble installing the house builder extension which was a zipped file with .rb files. Was so lost! Time saver you are.
                                      • BoxB
                                        You'll find the Sketchucation tools very handy for plugins too.
                                        http://sketchucation.com/resources/plugin-store-download
                                        • 4 / 5
