    [Plugin] T2H_2D_DXF_IMPORT 2020+
    13 Posts 6 Posters 14.9k Views 6 Watching
      tak2hata
      This is 2D-DXF importer plugin.
      vesion4.5.1: I update this plugin for sketchup 2020.
      NOTICE
      Strongly Recommend Sketchup version 8 higher for using this.
      The copyright of this plug-in is in TAK2HATA.
      I MAKES NO GUARANTEE OF VALIDITY about this script.
      Please use this script at your own risk.
      You can use freely.
      Entities are grouped by Layer.
      Text can be imported.
      Not support polymesh.
      Command find From [Menu]->[File]->[2D-DXF-IMPORT]
      Get the latest version from the PluginStore:https://sketchucation.com/pluginstore?pln=t2h_2d_dxf_import2020
      or AutoInstall from within SketchUp using the SketchUcation Tools
      older version:http://sketchucation.com/resources/pluginstore?pln=t2h_2d_dxf_import
      This script uses "win32ole.so" for File access in windows os.
      So The DXF file path includes special character will have no problem....perhaps.
      Thanks.
      by TAK2HATA
        Hi tak2hata,
        Are you able to upload to the plugin store? If not I can set it up shortly
        Sent from my iPad
          tak2hata
          @rich o brien said:
          Hi tak2hata,
          Hi,Rich.
          Now I am trying to upload to plugin store.
          Please wait.
          by TAK2HATA
            tak2hata
            @rich o brien said:
            Hi tak2hata,
            Hi,Rich.
            I could not upload to SketchUcation Plugin Store. πŸ˜•
            I hope you,please set this up.
            And teach me about how to uploading to plugin store. πŸ˜‰
            Thanks.
            by TAK2HATA
              Logout and then login.
              Can you see this area?
              (sketchucation.com)
              Can you read this thread?
              http://sketchucation.com/forums/viewtopic.php?f=382&t=52516
              Any problems let me know...
              But give it a go and see what happens.
                tak2hata
                (sketchucation.com)
                Thank you very much!! 😍
                Now I upload the plugin to store for the first time.
                by TAK2HATA
                  You now have a listing in the PluginStore, but it seems that you have not uploaded the necessary files...
                  I have done this for you...
                  Please read the links that Rich provided, so you can manage your Plugins yourself in the future πŸ˜„
                  Also note how to link the 'Move Info' button to the main page itself and not the general thread...
                  I have changed the link - yours simply went to the latest post of the thread, not the main-page...
                    tak2hata
                    Sorry..TIG.
                    Thanks for your revision.
                    I was in a hurry,and mistook.
                    I will learn more about upoloading to plugin store.
                    by TAK2HATA
                      aa6621
                      hello,
                      i can't use it at SU 2015.
                        aa6621
                        hello,
                        i can't use it at SU2015.
                        • F Offline
                          fjsgruppe
                          Hi, please do bring it to SU2016!!! :Thanks fro:
                            tak2hata
                            Long Time no see.
                            finally,I update this plugin to version4.5.1 for sketchup 2020.
                            by TAK2HATA
                            • O Offline
                              orangehk
                              Thanks a ton. It successfully imported the dxf exported by Inkscape.
