    Plugin request "Section cut"
    12 Posts 6 Posters 729 Views 6 Watching
      jonorman
      Once again i have a wish for a new plugin, like i have in Inventor.
      Chamfer: select the surface, set distanse from edge, add angle and it trims away what you want.
      I do this manualy, but I wish i had a plugin for it.. πŸ˜„
      "crossing fingers" πŸ˜’
      Thnx
        Golly! Crossing your fingers works! The plugin you seek is now available. Actually it was available before you thought of it. πŸ˜‰ Try Round Corner by Fredo6. Read the first post and make sure you installed the LibFredo6 files as directed, too.
          jonorman
          LOL, have it and love it. Did not know it could do that.. Can it chamfer thru the profile like in the picture and not only the edge of the profile. If it can, then crossing fingers helped πŸ˜‰
            Are you talking about the section cut in your illustration? If so, that's not a chamfer. If you want a section cut, use a cutting plane at the desired location or you can use Zorro to cut through it and then add a face.
            • soloS Offline
              Create a profile, pull it, make a section plane and intersect then remove unwanted parts.
                No plugin needed.
                  jonorman
                  That is the way i do it today yes, but as i do the "section cut" operation a lot, I was hoping for a more automated way..
                    So maybe you want to change the title of your thread to more accurately communicate what it is you want to do with the plugin.
                    As Pete said, you could use a section cut, and Make Group From Slice. Then explode the slice.
                      jonorman
                      Title changed. I have several ways of doing the cut, but again hoping for a faster, quicker way... Like the one i use in inventor. select surface, edge, set cut distance and angle, hit enter, "hokus pokus" and its gone.. i don't know if it is a hard script to create, but you script writers create all kinds of miracles so Im hoping for the best here.
                      • yorik1984Y Offline
                        yorik1984
                        try this http://sketchucation.com/forums/viewtopic.php?p=315482#p315482
                          If you have Pro try my Cut to Plane http://sketchucation.com/resources/pluginstore?pln=TIG_Cut_to_plane
                          • kenK Offline
                            ken
                            I am surprised no one has mentioned this plugin. I use it all the time to trim steel and piping members. Just draw a face of what you wish to trim away, make your selection and select the face and presto you have trimmed the selection.
                            I use it from drilling holes and trimming ends.
                            http://sketchucation.com/forums/viewtopic.php?t=41582#p368373
                            Ken
