    Plugin request "Section cut"
    12 Posts 6 Posters 1.0k Views 6 Watching
      jonorman
      LOL, have it and love it. Did not know it could do that.. Can it chamfer thru the profile like in the picture and not only the edge of the profile. If it can, then crossing fingers helped 😉
        Are you talking about the section cut in your illustration? If so, that's not a chamfer. If you want a section cut, use a cutting plane at the desired location or you can use Zorro to cut through it and then add a face.
        • soloS
          Create a profile, pull it, make a section plane and intersect then remove unwanted parts.
            No plugin needed.
              jonorman
              That is the way i do it today yes, but as i do the "section cut" operation a lot, I was hoping for a more automated way..
                So maybe you want to change the title of your thread to more accurately communicate what it is you want to do with the plugin.
                As Pete said, you could use a section cut, and Make Group From Slice. Then explode the slice.
                  jonorman
                  Title changed. I have several ways of doing the cut, but again hoping for a faster, quicker way... Like the one i use in inventor. select surface, edge, set cut distance and angle, hit enter, "hokus pokus" and its gone.. i don't know if it is a hard script to create, but you script writers create all kinds of miracles so Im hoping for the best here.
                  • yorik1984Y
                    yorik1984
                    try this http://sketchucation.com/forums/viewtopic.php?p=315482#p315482
                      If you have Pro try my Cut to Plane http://sketchucation.com/resources/pluginstore?pln=TIG_Cut_to_plane
                      • kenK
                        ken
                        I am surprised no one has mentioned this plugin. I use it all the time to trim steel and piping members. Just draw a face of what you wish to trim away, make your selection and select the face and presto you have trimmed the selection.
                        I use it from drilling holes and trimming ends.
                        404 Not Found
                        (sketchucation.com)
                        Ken
