    [Plugin][WIP] Layers Panel - Dev
    45 Posts 11 Posters 11.8k Views 11 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      I made another thread to discuss the behaviour of the plugin : http://sketchucation.com/forums/viewtopic.php?f=323&t=52225
      Feel free to participate 😄
        Litchi
        Thanks for your present!This is a great plugin, but I have a problem,I created a layer group,which contains a number of layers,but when I restart the plugin Panel,everything was back to the way they were,the group disappeared, the new layer still exist。
          jiminy-billy-bob
          Yep, it doesn't save anything yet ^^
          See the first post :
          @jiminy-billy-bob said:
          ToDo :
          • **Saving ! For now, every time you refresh the webdialog, or exit SU, the sorting/nesting disappears.**So it's useless as is.
          It will come. Just not now 😄
          It's obviously at the top of my todo list.
            driven
            hi
            I just wondered if you had ever seen this, it has some nice ideas, to take forward
            404 Not Found
            (sketchucation.com)
            I did some work on the mac version, but Chris and Jim had already done the tricky bits...
              jiminy-billy-bob
              Hey guys !
              I finally got a working version (See first post for download). It saves sorting/nesting (Except group hiding/collapsing)
              I still wouldn't recommand using it in production though, as it may produce bugsplats, and it still behave strangely with the undo stack.
              There are still a lot of bugs, so I need you guys to help me track them and getting methods to reproduce them.
              I updated the first post with what's working and what's not.
              I don't think it works on mac, though I'm not able to test...
              For now, I tested only on win7 SU2013 IE8-10, with no bugsplats so far.
              Feedback (about bugs or features) would be highly appriciated ! 😄
                Once I hide a Layer I can't unhide it unless I nest it in a Layer Group
                Win8
                Great tool 👍
                • KrisidiousK Offline
                  Krisidious
                  woooot wooot!
                  By: Kristoff Rand
                    jiminy-billy-bob
                    Win8
                    Great tool 👍
                    Weird, it works for me on win8 with SU2013 and IE10.
                    Which versions of SU and IE are you using ?
                      SU8 and IE10
                      I'll try it on SU2013
                        jiminy-billy-bob
                        It works for me on win8 with SU8 and IE10. Do you have the same problem with a new file ?
                        If so, can you zip and upload your plugins folder ?
                          Bit more info...
                          I've a starting template that loads with a layer other than layer 0.
                          If I toggle off visibility of this layer I can't toggle it back on.
                          If I drag the layer it then reappears...
                          [screenr:3cmp7xlp]vKmH[/screenr:3cmp7xlp]
                            jiminy-billy-bob
                            Great, thanks for the video and infos. I think I see where the bug comes from. I'll try to reproduce this and fix it, and I'll let you know.
                              Litchi
                              I am very happy to see your new version which can effectively work,thaks a lot !
                              and It still has some bug:
                              1、When you installed this plugin,Every time when you start SketchUp, Ruby console will automatically appear
                              2、When you rename a layer group, cannot immediately see the changes the results,You must refresh the layers panel to see it.
                              3、When you open or refresh the layers panel again,layer group is automatically displayed the layers inside it.
                              I'm sorry, my English is not very good, I hope you can understand what I mean
                              And I want to see the full version
                              thanks for your work !
                              • Bob JamesB Offline
                                Bob James
                                Don't ever give up on this: it is an absolute Winner and should be native to SU.
                                Thank you Rich, TT and the rest of you Ruby gurus for helping him 👍
                                  jiminy-billy-bob
                                  New version : Alpha 0.04
                                  • Fix Rich's bug with template layers
                                  • Fix Console showing at startup
                                  • Fix group renaming
                                  • Now group collapsing/expanding is saved
                                    Krisidious
                                    So far so good for me... look forward to locking and then I'm golden. Great Work.
                                    By: Kristoff Rand
                                      jiminy-billy-bob
                                      Well, even though locking is on my todo list, my top priority is to get everything working smoothly as is.
                                      • A clean undo stack
                                      • Saving group hiding
                                      • Fix a nasty bug with 3 levels of nested groups
                                      • Fix bugs with layers being sorted inside/outside of hidden groups
                                      • etc...
                                        greatoe
                                        something i've been looooooooong waiting for, great work!
                                        it do work on Mac.
                                        but, it won't read existing layers, would you please fix this?
                                          jiminy-billy-bob
                                          I'm sorry but I don't have a Mac, I have no way to test the plugin on this OS.
                                            Krisidious
                                            Mine read existing layers on PC just fine. And I could drag and drop existing layers into groups too. 😍
                                            By: Kristoff Rand
                                            • 2 / 3
