    [Plugin][WIP] Layers Panel - Dev
    45 Posts 11 Posters 12.2k Views 11 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      Thanks a lot, I'll try that.
        @dan rathbun said:
        Ruby uses 2 space indentation. HTML & Javascript 4 space indentation.
        NOTHING uses 3 or odd number spaced indents !
        Only Python require a certain indentation - Ruby, HTML and JS doesn't care. It's just coding convention within the team/project you're working with.
        • I
          iannuzzi
          Please, don't ever give up on this plugin, it'd save my life! I wish I could help
          • jiminy-billy-bobJ
            jiminy-billy-bob
            I won't give up ! 😄 I just don't have time curently. I will at the end of july.
            No worries
            • KrisidiousK
              Krisidious
              just posting so I'll get updates on this thread.
              By: Kristoff Rand
              • jiminy-billy-bobJ
                jiminy-billy-bob
                I made another thread to discuss the behaviour of the plugin : http://sketchucation.com/forums/viewtopic.php?f=323&t=52225
                Feel free to participate 😄
                • L
                  Litchi
                  Thanks for your present!This is a great plugin, but I have a problem,I created a layer group,which contains a number of layers,but when I restart the plugin Panel,everything was back to the way they were,the group disappeared, the new layer still exist。
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    Yep, it doesn't save anything yet ^^
                    See the first post :
                    @jiminy-billy-bob said:
                    ToDo :
                    • **Saving ! For now, every time you refresh the webdialog, or exit SU, the sorting/nesting disappears.**So it's useless as is.
                    It will come. Just not now 😄
                    It's obviously at the top of my todo list.
                      driven
                      hi
                      I just wondered if you had ever seen this, it has some nice ideas, to take forward
                      404 Not Found
                      (sketchucation.com)
                      I did some work on the mac version, but Chris and Jim had already done the tricky bits...
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Hey guys !
                        I finally got a working version (See first post for download). It saves sorting/nesting (Except group hiding/collapsing)
                        I still wouldn't recommand using it in production though, as it may produce bugsplats, and it still behave strangely with the undo stack.
                        There are still a lot of bugs, so I need you guys to help me track them and getting methods to reproduce them.
                        I updated the first post with what's working and what's not.
                        I don't think it works on mac, though I'm not able to test...
                        For now, I tested only on win7 SU2013 IE8-10, with no bugsplats so far.
                        Feedback (about bugs or features) would be highly appriciated ! 😄
                          Once I hide a Layer I can't unhide it unless I nest it in a Layer Group
                          Win8
                          Great tool 👍
                          • KrisidiousK
                            Krisidious
                            woooot wooot!
                            By: Kristoff Rand
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              Win8
                              Great tool 👍
                              Weird, it works for me on win8 with SU2013 and IE10.
                              Which versions of SU and IE are you using ?
                                SU8 and IE10
                                I'll try it on SU2013
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  It works for me on win8 with SU8 and IE10. Do you have the same problem with a new file ?
                                  If so, can you zip and upload your plugins folder ?
                                    Bit more info...
                                    I've a starting template that loads with a layer other than layer 0.
                                    If I toggle off visibility of this layer I can't toggle it back on.
                                    If I drag the layer it then reappears...
                                    [screenr:3cmp7xlp]vKmH[/screenr:3cmp7xlp]
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      Great, thanks for the video and infos. I think I see where the bug comes from. I'll try to reproduce this and fix it, and I'll let you know.
                                      • L
                                        Litchi
                                        I am very happy to see your new version which can effectively work,thaks a lot !
                                        and It still has some bug:
                                        1、When you installed this plugin,Every time when you start SketchUp, Ruby console will automatically appear
                                        2、When you rename a layer group, cannot immediately see the changes the results,You must refresh the layers panel to see it.
                                        3、When you open or refresh the layers panel again,layer group is automatically displayed the layers inside it.
                                        I'm sorry, my English is not very good, I hope you can understand what I mean
                                        And I want to see the full version
                                        thanks for your work !
                                        • Bob JamesB
                                          Bob James
                                          Don't ever give up on this: it is an absolute Winner and should be native to SU.
                                          Thank you Rich, TT and the rest of you Ruby gurus for helping him 👍
                                          • jiminy-billy-bobJ
                                            jiminy-billy-bob
                                            New version : Alpha 0.04
                                            • Fix Rich's bug with template layers
                                            • Fix Console showing at startup
                                            • Fix group renaming
                                            • Now group collapsing/expanding is saved
                                            • 2 / 3
