    [Plugin][WIP] Layers Panel - Dev
    45 Posts 11 Posters 12.2k Views 11 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      Hmm, so a class variable in a class ? That makes sense ^^
      Thanks for the tip, I'll try that.
      • renderizaR
        renderiza
        I hope that naming the Class "TEST" didn't confuse you since the class name doesn't have anything to do with the variables (var test = true) in html. 😕
        I guess what i am trying to say is that the "var test" in html has nothing to do with "Class TEST" in ruby.
        Not sure if you are confusing them both but just in case. 💚
        Note: Will edit the name of the class on my last post to "PLUG".
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • renderizaR
          renderiza
          @jiminy-billy-bob said:
          Also, I can't get my WebDialog callbacks to work if the dialog is not in a global variable. I tried local, instance, and class variables, nothing works. What am I doing wrong ?
          If you want to change something from ruby to web-dialog you can do this...
          In Html & Javascript:
          <html>
             <head>
                <title>Example</title>
             </head>
             <body onLoad="startup(), stopwatch(this.value);">
             </body>
          </html>
          <script>
          var delay = 1000/5 ; #this will update 5 frames per second
          var timerID = false ;
          var test = true ;  #this is the value you will change from ruby
          function startup() {
          nextFrame();
          function stopwatch() {
          SD=window.setTimeout("stopwatch();", 100);
          function nextFrame() {
             try {
                test = test
                setFrame() ;
                top.timerID = self.setTimeout("nextFrame()", delay) ;
             } //try
             catch (e) {
                alert("push_frame; " + e) ;
          } //nextFrame()
          function setFrame() {
          url = 'skp;push_frame@' ;
             url += '&test=' + test;
          window.location.href = url ;
          </script>
          In Ruby:
          module SU_PLUG
             class PLUG
                @@model = Sketchup.active_model ;
                @@dir = File.dirname(__FILE__) # this plugin's folder
                @@path = File.join(@@dir, '/Folder/')
                @@dlg = "test.html" ;
                @@test_dlg = nil ;
                def initialize()
                   @test_1_file =  File.join(@@path, @@dlg)
                   if @@test_dlg == nil
                       @@test_dlg = UI;;WebDialog.new("Test", false, "Test", 300, 600, 70, 95, true) ;
                      @@test_dlg.add_action_callback("push_frame") do |d,p|
                         push_frame(d,p)
                   @@test_dlg.set_size(300, 600) ;
                   @@test_dlg.set_file(@test_1_file) ;
                   @@test_dlg.show() ;
                end #def
                def push_frame(dialog,data)
                    params = query_to_hash(data) ;  # parse state information
                    if params['test'].to_s == "true"  #Example of a  condition.
                       change = false
                       script = "top.test= " + change.to_s + ";"    #this sets test=true to test=false
                       dialog.execute_script(script);   #this execute it
                end #def
                def unescape(string)
                if string != nil
                string = string.gsub(/\+/, ' ').gsub(/((?;%[0-9a-fA-F]{2})+)/n) do
                [$1.delete('%')].pack('H*')
                return string
                end #def
                def query_to_hash(query)
                param_pairs = query.split('&')
                param_hash = {}
                for param in param_pairs
                name, value = param.split('=')
                name = unescape(name)
                value = unescape(value)
                param_hash[name] = value
                return param_hash
                end #def
             end #class
          end #module
          Hope this helps and again very good plugin!
          • Dan RathbunD
            Dan Rathbun
            Ruby uses 2 space indentation. HTML & Javascript 4 space indentation.
            NOTHING uses 3 or odd number spaced indents !
            I'm not here much anymore.
            • Dan RathbunD
              Dan Rathbun
              See this other post: Re: Webdialog scripting issues
              Use local vars INSIDE methods as temporary variables. They get garbage collected when the method ends.
              Use @@vars INSIDE modules or for class-wide access.
              Use @vars in class instance methods (define and init them inside the initialize method.)
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Thanks a lot, I'll try that.
                  Only Python require a certain indentation - Ruby, HTML and JS doesn't care. It's just coding convention within the team/project you're working with.
                  • I
                    iannuzzi
                    Please, don't ever give up on this plugin, it'd save my life! I wish I could help
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      I won't give up ! 😄 I just don't have time curently. I will at the end of july.
                      No worries
                      • KrisidiousK
                        Krisidious
                        just posting so I'll get updates on this thread.
                        By: Kristoff Rand
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          I made another thread to discuss the behaviour of the plugin : http://sketchucation.com/forums/viewtopic.php?f=323&t=52225
                          Feel free to participate 😄
                          • L
                            Litchi
                            Thanks for your present!This is a great plugin, but I have a problem,I created a layer group,which contains a number of layers,but when I restart the plugin Panel,everything was back to the way they were,the group disappeared, the new layer still exist。
                            • jiminy-billy-bobJ
                              jiminy-billy-bob
                              Yep, it doesn't save anything yet ^^
                              See the first post :
                              ToDo :
                              • **Saving ! For now, every time you refresh the webdialog, or exit SU, the sorting/nesting disappears.**So it's useless as is.
                              It will come. Just not now 😄
                              It's obviously at the top of my todo list.
                                driven
                                hi
                                I just wondered if you had ever seen this, it has some nice ideas, to take forward
                                404 Not Found
                                (sketchucation.com)
                                I did some work on the mac version, but Chris and Jim had already done the tricky bits...
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  Hey guys !
                                  I finally got a working version (See first post for download). It saves sorting/nesting (Except group hiding/collapsing)
                                  I still wouldn't recommand using it in production though, as it may produce bugsplats, and it still behave strangely with the undo stack.
                                  There are still a lot of bugs, so I need you guys to help me track them and getting methods to reproduce them.
                                  I updated the first post with what's working and what's not.
                                  I don't think it works on mac, though I'm not able to test...
                                  For now, I tested only on win7 SU2013 IE8-10, with no bugsplats so far.
                                  Feedback (about bugs or features) would be highly appriciated ! 😄
                                    Once I hide a Layer I can't unhide it unless I nest it in a Layer Group
                                    Win8
                                    Great tool 👍
                                    • KrisidiousK
                                      Krisidious
                                      woooot wooot!
                                      By: Kristoff Rand
                                      • jiminy-billy-bobJ
                                        jiminy-billy-bob
                                        Win8
                                        Great tool 👍
                                        Weird, it works for me on win8 with SU2013 and IE10.
                                        Which versions of SU and IE are you using ?
                                          SU8 and IE10
                                          I'll try it on SU2013
                                          • jiminy-billy-bobJ
                                            jiminy-billy-bob
                                            It works for me on win8 with SU8 and IE10. Do you have the same problem with a new file ?
                                            If so, can you zip and upload your plugins folder ?
                                            • 2 / 3
