    [Req] Pipe along Path with decreasing diameter
    13 Posts 5 Posters 1.3k Views 5 Watching
    • jeff hammondJ Offline
      you can use curviloft for this (loft along a path)
      (in this case, there's a tiny circle at the other end of the pipe.. if you need it to go to a point, you'll have to manually edit the last section)
          Pherim
          Thank you for your suggestions so far. I already use curviloft, although not specifically for this purpose. It would be great to have a plugin that really goes to a point in the end, but if there is no plugin like this, I will have to stick to doing it manually.
            @Pherim
            Both CurviLoft and EEbyRails will make the 'horn' form, but you need to specify two 'rails' along the skin itself, and make it in two halves...
              Seems Draw Metal / "Draw a Taper" makes exactly that you want! πŸ˜‰
              Last Icone
              http://www.drawmetal.com/_/rsrc/1268959040068/toolbars-large.tiff?height=48&width=420
              Select any path ( a welded curve)
              Select your form section from the PopUp Menu (here Round)
              Enter first Size Diameter, second Size diameter
              As 0 is not permited take something like 0.01 πŸ˜‰
              Number of Sides of the section (here 24)
              Position of the Path (here Center)
              et voilΓ ! πŸ˜„
              Ps Of course "sharpness" of the curve is depending of the number of segments of the curve!
                Quick Lathe by Trogluddite can also make the horn! πŸ˜‰
                http://sketchucation.com/forums/download/file.php?id=103960&t=1
                http://sketchucation.com/forums/download/file.php?id=103961
                • massimoM Offline
                  massimo Moderator
                  Really? πŸ˜‰
                    @Massimo
                    After reading your post Pherin has written!
                    So I show him that was possible! πŸ˜‰
                      Pherim
                      Ah, thank you, I already downloaded Tapermaker, but I haven't tried it out yet. Thanks for showing me that it can do what I want. Will try it out soon! But as you wrote, 0 is not allowed as an end value, so I still will have to draw the end manually. I really don't want any face at the end, no matter how small. But this seems to be very close to what I want.
                      But is it actually impossible to make such a plugin or has just nobody done it yet?
                        You drawn not, and nothing to select on the screen, you just enter a value! πŸ˜‰
                          Pherim
                          Yes I have, since there is never a point at the end, which is what I want, there is always still a circle and I definitely have to draw the end manually. Apparently, there is no such plugin that really does what I want, but the ones that are mentioned here are quite close.
