    SketchUp 2014 Wishlist
    125 Posts 54 Posters 51.6k Views 54 Watching
      @dod3r said:
      Some easy native way to check commutative volume of nested component with solid parts in it.
      Do you mean cumulative?
      • Chris FullmerC Offline
        If you do mean cumulative, that would be a fairly simple and fun ruby plugin to write ๐Ÿ˜„
          DOD3R
          yes i did meant cumulative.
          I would like to see cumulative volume in entity info panel, that is the reason why i am posting it in sketch up 2014 wishes. But Chris if you can do that by some ruby script that would be cool. Maybe the information doesn't have to by in entity info tab it also can be in measurements box or information line next to it.
            I would like to be able to input a length and angle for a line and have THAT as the result rather than a loose aproximation. Is it too much to ask for? Is it too much that making a group or component should be a result of intersecting lines and arcs or are we stuck with a system that would have been innacurate when making cart wheels with an adze and by eye measurement?
              Deleted, not a good day. I will start again monday after a day to reflect on what I am using this tool for.
                Hi Dave, I made the mirror copy by copy and paste in place then flip along axes. Nothing wildly technical about it. I have noticed a problem in the placement of markers and drawing lines or moving lines to an angle. Sometimes the line or angle looks right but problems are emphasised when mirroed objects are placed in the group or component. The number of times I have found this is beyond my count. Essentially put, when you put the double doors into the frame the discrepency is writ large and while it may be my little bit of autism, I cannot abide a model I spent hours on at times being out of true.
                  Me neither... :s
                  Got a sample model?
                    ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                    • N Offline
                      numerobis
                      This is how modeling in sketchup should work in the year 2013...
                      this is really awesome... groboto inside modo! ๐Ÿ˜ฎ
                      If they only would implement a sketchup-like snapping system, i would immediately make the switch! (from SU and max)
                      • PixeroP Offline
                        Pixero
                        Wow, that's innovative. I've heard a lot of good things about Modo. If there was a plugin to get SU snapping and such I guess a lot of SU users would make the switch.
                          ArCAD-UK
                          In LO its about time when rotating an object that the angle can be set by snapping to other geometry. I was trying to align a rotated scene on a site plan the other day and ended up having to approximate it. ๐Ÿ˜•
                          • O Offline
                            OG1
                            My wishlist is:
                            1). Preventing my textures from exploding along with the group (which happens to me on many occasions!) Not sure if it does this just on smoothed surfaces, but if that's the case, then I want it to stop! lol
                            http://i41.tinypic.com/f9nszl.jpg
                            2). To be able to export the animation scenes along with the mesh in collada (dae) data! Why is that not possible anyways? Is there a plugin for that? I've sampled RegularPolygons Keyframe Animation Plugin, and it works like a charm, but without being able to export that animation data to collada, it's pretty much useless to me. If we did have the ability to export that data, I'd buy this plugin in a heart beat!
                            3). I also agree that Sketchup needs some sort of UV mapping. I do use Dales SketchUV. It's a brilliant plugin and I love it, but it's not perfect. I still, sometimes, get some stretching / warping with it, and each and every face gets exported instead of just one unified "map", so instead of one map, I get a gazillion different "pieces" of the one texture. (did I explain that right? O.o)
                            4). For Trimble to realize that Sketchup isn't just for architects anymore! ๐Ÿ˜‰
                            (No offense intended to all you brilliant architects)
                            I have been using Sketchup since @last owned it for creating content for Virtual Worlds.
                            Ok, so maybe they don't have to do this one. I'll settle for the other 3! ๐Ÿ˜„
                            If I could just see those 3 little, teeny weeny things implemented, I'd be one happy camper AND buy the latest version of Sketchup!
                            ๐Ÿ˜„
                            I got my bill for paying attention. I got robbed!
                              Got a sample model of that #1 issue there?
                              • O Offline
                                OG1
                                Sure. How do I put it in here?
                                  Click "Post a reply" and then there is an "Upload attachment" tab under the textbox.
                                  • O Offline
                                    OG1
                                    Ok, here it is! Thanks thomthom!
                                    Edit: removed the file now since it has been d/led. OG
                                      • O Offline
                                        OG1
                                        @thomthom said:
                                        Didn't you download the file? I didn't want to keep it up as public as it is a WIP for a VW. Content creators will snatch any chance they can get to swipe a working mesh! ๐Ÿ˜‰
                                        If you still wanted to see it, I can PM it to you?
                                          DOD3R
                                          more than one active section plane
                                            Yes, you can send it by PM if you don't want to share it in public. No problem.
                                            • 4 / 7
