    Animation and the DR Spawner
    renderpluginsextensions
    17 Posts 5 Posters 1.5k Views 5 Watching
    • N Offline
      n3v
      Hi All
      Using Vray 1.6.23 Beta and Sketchup Make.
      I am having my first attempt at making a short of animation. I followed nomeradona's tutorial which is pretty much faultless.
      http://sketchupvrayresources.blogspot.co.uk/2011/08/tutorial-vray-sketchup-animation.html
      However, to speed things up I want to use the DR spawner, now firing of the first test which is 5 seconds of animation at 30 fps, the first render used all 12 cores (2 machines), then the subsequent frames have dropped down to the original local machine which is only 4 cores, this has so far been running for around 8 hours and only produced around the first second of the short, with all 12 cores it would presumably be around 3 seconds worth.
      The DR spawner is working and currently displays [dr]getting frame data.but has not processed anything since the first scene
      Is there a setting that I have missed to make sure that all slaves help render each scene? as at this rate its going to take 2 1/2 whole days to produce 5 seconds. or if not is it possible to pause after each frame and restart so that all cores are working?
      Also as a side note: using the DR Spawner I noticed using the new find hosts button, it found an extra 3 hosts, this is peculiar because it normally only finds 2. Upon rendering it has somehow managed to thread the original machine, which is an i3 4 core machine. This machine is now rendering with 8 cores. This is weird as I have used this machine many times before but with only 4 cores. I should also mention the extra four cores are definitely something to do with the DR spawner because the extra four start sometime after the original four start. I am obviously not complaining about this feature but am astounded I have this much secret fire power and if anyone knows why or how this worked I would be grateful.
      • V Offline
        valerostudio
        I tested an animation this weekend using DR, but only using it on my local to utilize the 64 bit spawner and it did the same thing. Only renders frame 1 and stops.
        • N Offline
          n3v
          Hi Valero,
          Is this a bug in vray 1.6 or has it never worked? bit frustrating as I'm looking at a 2.5 day render which could presumably cut in half if I could get all spawners to contribute
          • V Offline
            valerostudio
            Honestly, I don't know. 1.49.01 had issues with DR and issues with saving light maps so animation and DR was just territory you didn't tread on back then. It could be a bug. Hopefully Devin will chime in on this one.
            • andybotA Offline
              andybot
              I just tested and animation seems to work fine in 1.6 with DR. I used saved maps.
              • dkendigD Offline
                dkendig
                if you haven't done so already, please submit a bug report. Animation is a rather large feature, and we want it working properly, so this should get high priority in our bug tracker. I know there have been some changes to how DR works with animation. Fernando told me yesterday that LC now works properly in animation, but I don't think he was using DR for those tests. He is out of the office today, but if you send in a bug report to our bug tracker, we will be sure to get to it at some point in the near future.
                Devin Kendig
                Developer
                • N Offline
                  n3v
                  Hi I used DR and saved light cache files as per the tutorial, how do you submit a bug report dkendig?
                  andybot, did you let it render past the first scene? Mine worked ok with saved maps up until the first scene and then the slaves dropped off. When starting and restarting the DR spawner the host would send over the info but the slaves wouldnt render
                  • N Offline
                    n3v
                    Ok as an update, I have tried the following two variations still with no improvement
                    1. after precalculating the LC, this time I loaded the LC from file and left the irradiance map to 'incrementally add'
                    2. no precalculations - straight render
                    still the slaves drop off after the first frame, I get the impession that the machine is receiving the data but is waiting for something to activate it.
                    • andybotA Offline
                      andybot
                      That sounds like a trouble that was happening with the older betas. Are you sure you have updated to the latest released beta? Yes, I tried all the frames, not just the first.
                      • dkendigD Offline
                        dkendig
                        n3v - http://www.chaosgroup.com/forums/vbulletin/showthread.php?72758-How-to-submit-a-bug-report <-- How to submit a bug report. Essentially, you just send an email to vfswip@chaosgroup.com, but the forum post outlines the kind of information we need to help track this issue down.
                        Devin Kendig
                        Developer
                        • N Offline
                          n3v
                          andybot I am using 1.60.23 jun 11 that is the latest right? is there any chance you could somehow share your settings so I can see whether I have set up the scene wrong as I wouldn't want to report a false bug.
                          Dkendig, I will follow Andy's advice first to make sure that its the software and not me and then if not I will submit.
                          thanks both
                          • N Offline
                            n3v
                            new candidate build doesnt appear to have fixed this. beginning to wonder whether its my setup or the software. Also now appears that patch render in animation no longer wants to work?
                            • andybotA Offline
                              andybot
                              Here is my model if you want to take a look. Nothing fancy.
                              animation_basic_test5_A.skp
                              • N Offline
                                n3v
                                Hi Andy bot, thanks for sharing I will check out your model when I get a chance and let you know how it goes. My model is around 61mb and I didnt use any proxies to avoid them not being sent across the network.
                                • dkendigD Offline
                                  dkendig
                                  asset collection should no longer be something to fear, it's automatic, and behind the scenes.
                                  Devin Kendig
                                  Developer
                                    Sephiroxxx
                                    If you found the Fix please post it. I am having the same problem, it uses all cores / slaves for first images and after that only main cores.
                                    • N Offline
                                      n3v
                                      Sephiro - nothing as yet, will let you know when I know more
