    Animation and the DR Spawner
    renderpluginsextensions
    17 Posts 5 Posters 1.9k Views 5 Watching
    • N Offline
      n3v
      Hi I used DR and saved light cache files as per the tutorial, how do you submit a bug report dkendig?
      andybot, did you let it render past the first scene? Mine worked ok with saved maps up until the first scene and then the slaves dropped off. When starting and restarting the DR spawner the host would send over the info but the slaves wouldnt render
      • N Offline
        n3v
        Ok as an update, I have tried the following two variations still with no improvement
        1. after precalculating the LC, this time I loaded the LC from file and left the irradiance map to 'incrementally add'
        2. no precalculations - straight render
        still the slaves drop off after the first frame, I get the impession that the machine is receiving the data but is waiting for something to activate it.
        • andybotA Offline
          andybot
          That sounds like a trouble that was happening with the older betas. Are you sure you have updated to the latest released beta? Yes, I tried all the frames, not just the first.
          • dkendigD Offline
            dkendig
            n3v - http://www.chaosgroup.com/forums/vbulletin/showthread.php?72758-How-to-submit-a-bug-report <-- How to submit a bug report. Essentially, you just send an email to vfswip@chaosgroup.com, but the forum post outlines the kind of information we need to help track this issue down.
            Devin Kendig
            Developer
            • N Offline
              n3v
              andybot I am using 1.60.23 jun 11 that is the latest right? is there any chance you could somehow share your settings so I can see whether I have set up the scene wrong as I wouldn't want to report a false bug.
              Dkendig, I will follow Andy's advice first to make sure that its the software and not me and then if not I will submit.
              thanks both
              • N Offline
                n3v
                new candidate build doesnt appear to have fixed this. beginning to wonder whether its my setup or the software. Also now appears that patch render in animation no longer wants to work?
                • andybotA Offline
                  andybot
                  Here is my model if you want to take a look. Nothing fancy.
                  animation_basic_test5_A.skp
                  • N Offline
                    n3v
                    Hi Andy bot, thanks for sharing I will check out your model when I get a chance and let you know how it goes. My model is around 61mb and I didnt use any proxies to avoid them not being sent across the network.
                    • dkendigD Offline
                      dkendig
                      asset collection should no longer be something to fear, it's automatic, and behind the scenes.
                      Devin Kendig
                      Developer
                        Sephiroxxx
                        If you found the Fix please post it. I am having the same problem, it uses all cores / slaves for first images and after that only main cores.
                        • N Offline
                          n3v
                          Sephiro - nothing as yet, will let you know when I know more
