    No Drag and Drop Import in 2013?
    22 Posts 11 Posters 18.7k Views 11 Watching
    • KrisidiousK Offline
      Krisidious
      No Drag and Drop Import in 2013? I know it didn't work for all file types but at least I could drag .JPG's and drop them into the SketchUp window... Why not in 2013?
      By: Kristoff Rand
        d12dozr
        Jpg's work for me, Kris.
        http://goo.gl/f7ooYh
          Krisidious
          really? why not for me? hmmm... Well I haven't been using it really. just testing. I wonder what's different. Maybe it's because I don't have my folders set?
          By: Kristoff Rand
          • Chris FullmerC Offline
            Yeah, they should be working Kris. Can you drag and drop a .skp file into your model?
              Krisidious
              No I can't Chris... I'm wondering, I had this OS installed on another computer and then just switched the harddrive over. I've had lots of permission issues. Do you think that could be it?
              By: Kristoff Rand
                I don't know, but if you're getting other OS issues, then it might be related.
                  Krisidious
                  No... No other programs seemed to be affected. In fact I have always done this with sketchup. Just move my whole program folder over. But this time it didn't work and I've had issues where Tig had me go in and redo permissions on all the SU folders and it fixed the issues. Well, now that I know it's not supposed to be this way, I'll sort it out. I just figured it was a lost function in the new system.
                  By: Kristoff Rand
                  • bazB Offline
                    baz
                    Did you ever resolve this Kris?
                    I have the same problem now. (I have checked all my permissions)
                      On a PC you ought always to install SketchUp as an Admin [context-menu on installer exe]
                      If you do not do this, then you can get some permission issues later on... however, a later workaround is to set SketchUp.exe to 'always run as administrator' under the Compatibility context-dialog...
                      However, this has an unfortunate side-effect... an application running at a lower permissions level cannot affect an application running at an elevated level...
                      Windows-Explorer always runs at the permissions lowest level, so if you drag-n-drop from it into SketchUp, then it will only work IF SketchUp is running at the same permissions level.
                      So if you have set SketchUp to run at the elevated permissions level it cannot receive drag-n-drop from outside.
                      Perhaps there's something similar on MAC ??
                      • bazB Offline
                        baz
                        So a re-install as administrator should fix it?
                        • pbacotP Offline
                          I've got Drag & Drop (on Mac). Everything except pdf it seems.
                            pipinek
                            Greetings,
                            Su 2020 - latest version, Windows 10.
                            Same issue here. Drop and drag import function does not work at all.
                            Any suggestion?
                            Thank you in advance
                              I just tried it here on my PC in 2020.2. I inserted a PNG image, a JPG image, a .skp file and a .stl file using drag and drop. All worked as expected.
                              When you installed SketchUp did you follow TIG's advice to right click on the downloaded installer and choose Run as administrator?
                                Glenn at home
                                Working here at home today on SU Pro 19.3.253 Never got around to installing 2020 at home...lazy.
                                It does work correctly on my office PC running current version of 2020.
                                  rv1974
                                  @pipinek said:
                                  Greetings,
                                  Any suggestion?
                                  don't run SU as administrator
                                    In Windows Drag-n-Drop will not work if you have the SketchUp exe file's > Properties > Compatibility > For all users, checked to "Run this program as administrator".
                                    Drag-n-Drop fails because Windows Explorer always runs at a base-permissions level.
                                    And then Windows prevents such an app from affecting another app that is running at an elevated permissions level [like a wrongly configured SketchUp would be].
                                    Also you should always install any complex app by being logged into Windows as your normal-user account, then right-clicking on the app's installer exe file's icon > context-menu > "Run as administrator".
                                    If it's already installed then choose 'Repair' when prompted.
                                    This will reset various file and folder permissions properly.
                                    You should not need to reinstall everything from scratch...
                                    Running an app's installer's exe in any other way - e.g. by double-clicking its icon to 'Run' it - can cause all kinds of unpredictable and weird issues - usually with 'permissions'.
                                    Your normal-user account having admin-powers is not a problem, but it is not enough to avoid doing it properly - i.e. use right-click > "Run as administrator"...
                                      Glenn at home
                                      Literally nothing on my PC is installed this way nor has it needed to be. Nothing from Adobe Creative Cloud is installed this way nor is anything from AutoDesk installed this way. Both have desktop launchers that allow you to "click to install" apps that you have permission to install from your account. There is NO "right-click to install as admin" on ANY of their products. Every complex program on my PCs are either double-clicked to install or click to install and they ALL work as they should.
                                      AutoCAD 2021, AutoCAD Arch 2021, AutoCAD Map 3D 2021, Fusion 360, SU 2019, SU 2018, Form-Z Free, Simlab Composer 10, Blender 2.90, current version of Adobe Dimension, Illustrator, Photoshop, Bluebeam, Twinmotion 2020 etc..
                                      Not trying to start an argument just pointing this out.
                                        Not withstanding what might have worked on other complex apps...
                                        The recommend way is right-click > 'Install as administrator'
                                        This is a detailed explanation...
                                        https://www.techspot.com/guides/1718-run-as-administrator-explained/
                                        Don't ask me 'Why?' - since I'll respond. 'Because it works!'
                                        That's all I know...
                                        Perhaps the other apps' 'specialized-installers' call the correct processes...
                                          Glenn at home
                                          Yeah that's a good a answer as any. Pretty much my answer for not having to do it. "Works and has ALWAYS worked on my end." πŸ˜‰
                                            Both TIG and I could probably each come up with several hundred examples from the last three or four years where reported problems were fixed by correctly installing or repairing the installation with Run as administrator.
