    Custom text feature removed in LO 2013?
    layout
    14 Posts 7 Posters 1.3k Views 7 Watching
      marcdurant
      I know there's a way to save "Favorite" fonts on Mac, but I don't know of any way to do this on Windows... Could you explain what you were doing in LayOut 3? We didn't make any changes to the font panel (that I know of...)
      thanks,
      Marc
      • KrisidiousK Offline
        Krisidious
        I have one if you do architecture. It's in Imperial, but the symbols and notes you might like.
        http://sketchucation.com/forums/viewtopic.php?f=40&t=49829&hilit=scrapbook
        By: Kristoff Rand
          troypiggo
          thanks,
          Marc
          Aaah. That's what happened. I was using a Mac with previous version, but now have moved to a PC.
          This is not my signature. I type it at the end of every message for quality control.
            troypiggo
            Thankyou! I saw that the other day but hadn't downloaded yet. Have now ๐Ÿ˜„
            I don't do architecture, I'm a structural engineer. But that certainly gives those starting out a framework to build their own. Very generous of you.
            • mikebelluckfM Offline
              mikebelluckf
              Yep - definitely NO font window on Mac Layout - quite annoying!!!! I use fonts all the time in layouts - ugh! Show me I am wrong!
              MIKE BELL
              http://www.mikebell.euย  ย +44 7970 646 705
              Event // Exhibition // Experiential // Installation
              Design / Layouts / CAD Plans / Digital Scamps
              • bmikeB Offline
                bmike
                  troypiggo
                  That's it, Mike. The "Collections" and I was creating my own "Favourites".
                    marcdurant
                    Hi Mike-
                    The Font window is available under "Window -> Show Fonts" in the menu bar. I always look for this command in the "Text" menu instead, which is wrong. Where were you looking for it? If we get enough complaints I might be able to move the command.
                    thanks,
                    Marc
                      Mike, it has been this way since the beginning. On the PC there is a Text window for setting fonts and their attributes. On Mac, because it uses Mac's font utility, it isn't accessed as a window in the same way. It would be nice to have it in the tray but I find it is easy enough to right click on the text and change the font or get there from the Window menu.
                      • pbacotP Offline
                        @marcdurant said:
                        Hi Mike-
                        thanks,
                        Marc
                        Can you get it snap in the stack and collapse like the other windows?
                        • bmikeB Offline
                          bmike
                          @pbacot said:
                          @marcdurant said:
                          Hi Mike-
                          thanks,
                          Marc
                          This would be great!!!!
