    [Tutorial > Texturing] Texturing an arch - #2
    87 Posts 18 Posters 36.9k Views 18 Watching
      Nice arch! πŸ‘
      Of course, now we have Whaat's SketchUV Plugin (with tube mapping) which save even more time and head-ache...
      @marvins_dad said:
      BTW - I didn't read past the initial steps since I didn't have any issues, but if you are matching an opening - make the height of the flat column of brick equal to the length of outer arc of the assembly. Did that make sense?
      I guess it all depends where you grab that column (inner or outer side) with Fredoscale.
      • ziiarZ Offline
        ziiar
        Is there a way to do this without the FredoScale plugin? I'm making a gothic arch like the one mentioned in the previous thread:
        http://sketchucation.com/forums/download/file.php?id=37073&mode=view/rokbox.jpg
        I assume this was modeled with the follow me tool, which is what I did do model it.
          This wasn't made with FredoScale nor the Follow me tool.
          I drew the outline, then offset to make the inner hole. Then another offset to create the line in the middle. After that I selected the edges of the inner hole and moved it inwards.
          hm... this is probably better suited with screenshots....
              @Thom
              What flashed up at the start?
                    ah - I use shortcuts of often I don't even notice it. That's my tool to inspect face and edge normals: http://sketchucation.com/forums/viewtopic.php?t=21472#p180592
                    • ziiarZ Offline
                      ziiar
                      Thanks thomthom! But I'm still not sure how to use the arcs as a perpendicular path for the textures like you did.
                      http://sketchucation.com/forums/download/file.php?id=37072
                        It's time to make some new tutorials based on newer plugins (or newer versions of plugins). I might put together something during the week-end.
                        • ziiarZ Offline
                          ziiar
                          That would be great! looking forward to it.
                          • 5 / 5
