    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      tsong12
      Sketchup 2013 currently does not support the all latest LibFreso plugins....please consider in your next update.
      Thanks!!
      • fredo6F Offline
        Thanks!!
        With LibFredo6 4.9c, this should be OK.
        • X Offline
          Xandisc
          Fredo6.
          First of all, thank you very much this plug in is great, works perfectly, simple. Superb.
          Question is, can I install it on V2013? I copied from my plugins folder from V8 and doesn't work and makes SU crash. Is there a way around it?
          Many thanks
          Alex
            @xandisc said:
            Fredo6.
            Many thanks
            Alex
            You would find it useful to go back to the first post of this thread and read. It is clearly spelled out that there has been an updated version. You should download and install that instead of using the old version you had in your SU8 Plugins directory. In fact you should download current versions of all of Fredo's plugins instead of using the old ones.
            Get the Sketchucation Plugin Store and you can download and auto install all of the plugins you need through it.
            • petestjohnP Offline
              petestjohn
              Hey Fredo- can't get any of your plugins running on win 8 64 with SU 2013 - here's the error message...
              "Cannot load plugin LibFredo6 because the script cannot create DEFPARAM_Dir folder in:
              c:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins
              Please create it manually, respecting the case
              Then this error continues for the rest of my Fredo6 plugins and it ends with this:
              Error Loading File LibFredo6.rb
              undefined method `average_load_time' for Traductor::Plugin:Class
              thoughts?
              • Alan FraserA Offline
                Alan Fraser
                It sounds like you may not have full permission for your Plugins folder...and Windows won't create the necessary sub-folder. Make sure that all the user names in your Plugins folder's Properties/Security all have full edit permission.
                3D Figures
                  If you shared your OS etc in your User-profile details it helps us to help you... πŸ˜’
                  Sounds like Alan's is right.
                  The inability to make the folder suggests that you have limited security permissions to the Plugins folder.
                  [Re]Set them to FULL for every one listed.
                  BUT the missing file in the next message suggests that you have not properly installed the Lib folder etc...
                  This might be a mistake in the way you have extracted/installed it, OR it might look like it looks like it's installed OK, but in fact the dread Windows 'Compatibility Files' VirtualStore has kicked in to save you from yourself [resetting permissions to full for the Plugins folder should stop it recurring but you need to sort out the mess it made before the fix!]... This has been discussed endlessly in many threads...
                    petestjohn
                    Jeeze, thanks guys! I'm afraid I posted waaaayyy too fast before I read the most recent posts! I've been struggling with an upgrade to win 8 and will dive into the permissions issue (and reinstalling) to hopefully correct the issue. Thanks for the quick response and great plugins...
                      sharath303
                      hi,
                      i cant instal fredo tools, on my mac, i use sketch up 2013.
                      i ve tried installing it through sketchucation plugin tool, and manually, its says installed successfully, but i cant find tools.
                      may be i m looking in wrong place? i m new to sketchup.
                      • Rich O BrienR Online
                        Where are you looking?
                        It is in the tools menu and the right-click menu
                          tulacong
                          oah...thank you
                            glenn
                            Hi Fredo6,
                            Just wanted to pass long a quick thanks for all your plugins.
                            I switched from sketchup v7pro to 2013pro this weekend, and manually installed your plugins (windows 😎 all work great. Had to change permissions on the plugins folder.
                            thanks again,
                            Glenn
                              sharath303
                              i ve seen, i cant find them..
                                What are you expecting to see?
                                  sharath303
                                  hi,
                                    This is the 'LibFredo6' thread - but you talk about 'fredo tools'. πŸ˜•
                                    The FredTools page is at http://sketchucation.com/forums/viewtopic.php?p=373073#p373073
                                    BUT they do need this latest Lib installed too...
                                    Have you installed that toolset AND the Lib ?
                                    The FredTools page has detailed usage notes... what is it that you can't do πŸ˜•
                                      sharath303
                                      i ve installed the lib and the toolset, its says successfully installed and i cant find them in my plugins and tools. only joint push pull is working.
                                        Have you restarted SketchUp after installing Fredo Tools ?
                                        It should appear as submenu of various tools in the Tools menu ??
                                        Some complex tool installs need a restart to complete the install...
                                          babamay16
                                          Hello. Please help. I tried installing this plugin but can't work fine.
                                          It's always error.
                                          "Cannot load plugin LibFredo6 because script cannot create DEFPARAM_Dir folder in:
                                          C:/Program Files/SketchUp/SketchUp 2013/Plugins
                                          Please create it manually, respecting the case."
                                          Anyone have a solution?
                                            It's always error.
                                            Yes. The solution has been given repeatedly including on this page of the thread. You need to set the permissions for the Plugins folder to give full access for everyone.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 109
                                            • 110
                                            • 24 / 110
