    Sketchup 13 crash (makes me wild)
    13 Posts 5 Posters 1.2k Views 5 Watching
      Stermo
      I work on new model but my sketchup crash non stop I really do not why.I just work on model and do save and after 1-2 min crash or just do something and crash that makes me wild.I do no know what to do to work normal Please HELP
        How is it without plugins loading ?
        What plugins do you have loading...
          Stermo
          I will try to work without load any plugins and will give you an answer soon...
            Any render plugins installed? BIM related plugins?
              Stermo
              Yes I have v-ray installed and I am not sure about BIM plugin maybe I have it but I didn't use this plugins when sketchup crash. Most of the time when sketchup crash is after saving or use the roundcorner.I will make something like chronology about crashing. I really hope to fine the solution becouse this makes me ...
                Try without Vray beta loading...
                  Stermo
                  Sorry for my late answer.This is little chronology about 3 hours work on sketchup for today
                  After make move
                  After used the fredo scale
                  After right click on object
                  After make move
                  After click close (this is strangely)
                  After try to paint
                  But after disabled the v-ray the crashes is little less.I can't find the connection between crashes.The SU 13 crash more than SU 8
                    So in reality, it is the V-ray plugin that is making you wild. What other bad plugins have you got installed? ๐Ÿ˜’
                    This problem with V-ray has been known for a long time.
                      Stermo
                      I have almost every useful plugin installed and I can't determine what do these crashes but sometimes is really annoying.Will be good if someone write a some script to determine the crashes.
                        I'm afraid that's not possible. Crashes happens abrupt and because the errors are not caught.
                          You should really have 'every in the universe plugin' loading at once... ๐Ÿ˜•
                          That will slow SketchUp's startup very noticeably, and it's also a recipe for clashes.
                          For example, several rendering plugins loading at once is a particularly risky path...
                          It's best to have a set of your 'vital' plugins that you frequently use which are 'enabled' and auto-load as SketchUp starts, and a set of your more infrequently used plugins that are normally 'disabled', which you then enable/load as and when they are needed. If these are Extensions then the 'Extensions Manager' can control their loading, if they are vanilla plugins then use th 'SketchUcation Plugins Manager' to do this for you, using a simple GUI...
                          Both tools are included with the 'SketchUcation Plugin Store' toolset...
                          Most risky/known plugins are listed in threads in SCF...
                          • yorik1984Y Offline
                            yorik1984
                            V-ray plugin is crashed SU13. I check this and turn off.
                            Especially when I used Roundcorner plugin.
                              Stermo
                              Thank you guys about advices I will try disable most non-used plugins and I will you keep informed with my crashes.
