    โš ๏ธ Attention | Having issues with Sketchucation Tools 5? Report Here
    Sketchup make
    14 Posts 4 Posters 445 Views 4 Watching
      drams
      I am a sketchup pro owner but have not upgraded to SU 2013. I downloaded Sketchup make to evaluate and have had 2 or three bug splats in about 1/2 hours of use just drawing simple forms. I also find the no snap to center point of lines. Also can't draw pyramid or raise a simple roof because the point or line can not be selected over the adjacent surface.
      I also find it irritation that this forum is here with no ability to search.
        drams
        Sorry, I posted earlier today and said I could not search forum. I must have been in the premium section I later found I could search in the not premium forum.
        Sorry for not checking things our thoroughly.
          As you've found Search is readily available...
          If you hover your cursor over a line, near it's midpoint then the inference snap should change to a light-blue color and the tooltip change to 'midpoint' - you may have to wait a fraction of a second for the change to kick-in...
          To 'raise' 3d forms using Move ensure you have the correct object[s] selected - to move an 'apex' start Move with nothing selected and pick the desired vertex, alternatively draw a temporary line from the 'apex' [upwards], preselect that and Move it up... it will drag connected edges with it [erase the temporary line when done].
          To force the affected geometry to 'auto-fold' when Moving it you can [should] press/hold 'Alt'...
            drams
            Thank you TIG for quick reply. I was able to 'raise' using the move tool as you suggested. I did notice that the snap to mid point is not working as it should. The small circle does not appear as it does in previous versions. I can find the midpoint if I move cursor to point close to center and start drawing line but circle snap indicator never appears. Should I install again to get proper function.
            I also wonder why I got so many program freeze ups in only a few minutes of use?
              Try turning off Hardware Acceleration and see if that changes the appearance. Or try updating your graphics drivers.
                drams
                Thanks Dave R (A name sake)I turned off Hardware Acceleration and the small blue circle now appears. I will continue my evaluation. Thanks for your help.
                I love Sketchup, have been using it since Sketchup 4.0. It has been a god send of designing furniture and home remodeling layouts.
                  drams
                  I went back to evaluation and as soon as I tried to open a new file I got another bug splat.
                  Is Sketchup 2013 an unstable program? It has shut every time I try it.
                    I haven't found it to be unstable.
                    Have you got a bunch of plugins you copied over from SU8?
                      drams
                      Thanks for the reply Dave. I don't have any added plugins. I downloaded the program and started using it and have been getting shut downs after a short time. It happens when I click on "File" a second time.
                        Strange. What version of Windows are you using?
                          Uninstall it.
                          Then reinstall it - 'run as admin'.
                            drams
                            I uninstalled and redownloaded from Sketchup site and opened again and drew a simple form and clicked on "File" and it crashed again. I opened program again and clicked on "File" to open a Sketchup file and then clicked on "File" again and it immediately crashed.
                            I never had this problem before and I have been using the program since at least version 4.o starting in about the year 2004 or 5.
                              Have you reported/complained directly to Trimble?
                              There is a limit to what we can advise ๐Ÿ˜•
                              • Chris FullmerC Offline
                                His "Click on the File Menu and Crash" reminded me of a similar report we got from Dan Rathbun. Turns out it is the exact same problem.
                                (This is PC only from what we have seen)
                                There are a small amount of users who are crashing when they click on the File Menu. So far the culprit has been the .fbx exporter. The fix is to find your SketchUp installation folder and then go to the Exporters folder. Remove the file called skp2fbx.dll. Then try to use SU again. That should be a temporary fix. If you are an .fbx user, we are working on a more permanent real solution. I supposed you could try to export from a different machine if possible.
                                From what we've seen, this is limited to XP SP3, and it isn't very common even on those machines. But if you see anyone around the forum complaining that SU crashes a lot, and its always when they click on the file menu, this is probably the reason.
                                Thanks Dave for helping troubleshoot this. I'll let everyone know when we get a fix in place. If anyone else is seeing this issue, I'd like to know about it so we can get their system info and see if they can help test any potential fixes.
