    Euclideon Unlimited Power Rendering
    21 Posts 8 Posters 2.9k Views 8 Watching
    • mitcorbM Offline
      mitcorb
      Hi, Aerilius:
      I do not fully understand your reference to repetition in this case. In the video I saw that instead of using redraw at various levels of detail/distance/zoom, the application somehow assigns chunks of view to only the available pixels in the screen?? He made a point of the fact that this is the application only and is not currently taking advantage of GPU at all?
        Aerilius
        For the display rendering, they use the "intelligent search algorithm" that searches only as much points as your screen has pixels (therefore it scales well with model complexity).
        What I meant was that saving the model as trillions of points (or having all points in memory) requires a lot of memory (I read a blog were someone calculated that it would be several petabytes), except if you have repeated geometry like the palms and elephants.
        • mitcorbM Offline
          mitcorb
          Ok, I get it now. Yes, that is a valid point. Repetitive/ identical elements would seem a method to hold down file size- and I guess for a game that would be ok until the marketplace reacts or demands more and better.
          Whatever the outcome, rational and justified pricing, and accessible user interface should be everyone's demand.
            tomasz
            If one can display LiDAR data, which is definitely not repeatable, on a laptop in real time then the technology is really impressive.
            5-20% reduction in data size is interesting, but I guess one will still need a decent portion of a hard-drive to store it.
            Copy of the temporary website
            http://www.euclideon.com/
            I am waiting patiently for a demo, that could be downloaded.
            Euclideon’s UD technology features a 3D search algorithm that can render unlimited quantities of point cloud data in real time. As the technology efficiently grabs only one point for every screen pixel, it can display models of previously unimaginable sizes at interactive frame-rates.
            Using Geoverse™, data from any of the standard industry formats is converted by Euclideon’s Unlimited Detail technology, reducing the file to 5-20%of the original size. This data can be installed on a local computer for single use or anywhere on the network for multiple users to access. Load times for data sets of any size or location are less than a second.
            UNLIMITED OPPORTUNITIES
            • Render all of your point cloud data, all at once — no size limit.
            • Reduce fi le size to 5-20% of the original with native data conversion.
            • Store data centrally and stream over the network.
            • Reduce load times to less than a second regardless of data size.
            • Run it on entry level desktop computers and laptops.
            • Accommodate stereoscopic display.
              tomasz
              Lidar data images extracted from the brochure:
                tomasz
                The newest presentation of Geoverse !
                Euclideon Geoverse 2013 - YouTube
                [flash=640,480:1mkmbwvy]http://www.youtube.com/v/Irf-HJ4fBls[/flash:1mkmbwvy]
                Impressive!
                Well done Bruce & Euclideon!
                I wonder how much their SDK is 😄
                  tomasz
                  The most impressive is the way they access pointcloud data from USB or a HDD in realtime.
                  • mitcorbM Offline
                    mitcorb
                    I like how this has progressed. They have implemented their technology as a very useful tool outside of entertainment. But, the video was amazing.
                    • PixeroP Offline
                      Pixero
                      Wow, that was impressing.
                      • olisheaO Offline
                        olishea
                        the voice is back!! 😆 not as strange this time though.
                        oli
                          Starling75
                          Nice ...
                          I want my own lidar 😄
                          http://www.starlingarch.cz
                            tomasz
                            Here you can listen to specialists from Geo industry commenting on the Geoverse. You can also see a full scan of Vienna that fits on 3TB external HD.
                            They have the SDK available. Trimble are you interested?
                            Geoverse Interviews 2013 - YouTube
                            [flash=640,360:20poeq20]http://www.youtube.com/v/csvmRgi0gZQ[/flash:20poeq20]
