    Creation of folder from Ruby on Mac
    31 Posts 5 Posters 2.5k Views 5 Watching
    • jeff hammondJ
      yeah.. i don't know..
      the question by fredo is
      can you create a folder on mac via ruby or not?
      @fredo.. can you make a little script or snippet to test with?
        driven
        Yes, using the ruby snippet in my last post [ saved as a .rb file ], I can create both a Folder and a file from a ruby script in the Plugins folder.
        @Jeff it should work on yours as well.
        @Fredo, is there any pattern to what's failing?
          I don't understand Fredo's issues here... 😕
          I already make/use different 'personal subfolders' on PC AND MAC to store temporary files, AND also permanent files: they are automatically made for each User in straightforward Ruby Code.
          I gave detailed examples in my earlier post - lifted almost verbatim from the SCF tools loader .rb, I just edited out some module specific Constants...
          The 'Plugin Store. for example has ..Local/Temp/SCF/ PC||MAC ...xxx/T/SCF/ folders to take the temporary RBZ files etc during auto-install processing and the ..Local/SCF/ PC||MAC ...xxx/SCF/ folders to take the 'encrypted login cookie' that's used so you don't have to login with every visit !
          • fredo6F
            All I am trying to figure out is an alternate location where to create the DEFPARAM_Dir folder, since for some Mac users, it seems not to work in the SU Plugins area on Mac.
            I was just wondering is the Mac has some sophisticated security whereby certain file operations are prohibited from scripts, even if you can perform them manually (like create a folder).
            If not, then we are left with the normal access rules and I imagine that the /users rootpath is normally enabled for writing.
            PS: thanks to the contributors. I have to ask as I don't have a Mac currently.
              driven
              Basically, if you can't write to there, it's hard to find somewhere else with 'lesser' permissions.
              I think it will work for more people where it is, as far as I can find, this should only be an issue on 'Guest Accounts' that have file access restrictions enabled by an administrator. [maybe Corporations/Uni's etc..]
              You can test for 'admin' quite easily [code below] and use a MB or similar for those without them...
              It has lots, but for the majority of users, as long as it's in the 'User' domain it's actually a lot more complicated to limit access then allow it. App SandBoxing may come into play in a few cases.
              I think you should go with that assumption, and maybe add some simple test to you logfile RE:admin
              always happy to help keep your plugins working on macs
              This checks I'm an admin and writes to your folder from wherever I load your folder from.
              not the best coding, but works from a variety of accounts that I have access to.
              def isAdmin
                user = %x( whoami ).chomp!
                admins = %x( dscl . read /Groups/admin GroupMembership ).chomp!
                iSadmin = (admins.scan user) == user.to_a
              begin
                home = (File.dirname(__FILE__))
                test_dir = home + "/DEFPARAM_Dir"
               if not FileTest.writable_real? test_dir
                UI.messagebox("You need an administrator to modify defaults!") if  not isAdmin
                else
                path = File.join( test_dir, "/from_v2013_plugins_file")
                file = File.open(path, "w")
                file.write( Time.now.to_s )
                end #if
              rescue
                #some error occur, dir not writable etc.
              ensure
                file.close unless file == nil
              • fredo6F
                @driven
                Thanks very much.
                Are you also able to create the directory, not just to write files?
                  driven
                  Yes
                    Dir.mkdir(test_dir) unless FileTest.exists?(test_dir)
                  works fine,
                    @driven said:
                    Yes
                    works fine,
                    That is the normal way to test if a folder/file exists and then if not you make it etc 😄 BUT I recommend an alternative...
                    On a PC with the current Ruby version operations like File.exist? etc can report 'false' even when it does exists, consequently causing an error when you try to make it and it's there ! - this occurs when the path contains non-ASCII characters - which is possible in user-names in the path to the Temp folder etc. I think MACs are more tolerant of characters? BUT we want a 'cross-platform' solution...
                    The simplest way is to always make it, trapping the error if it fails because it exists !
                    begin;Dir.mkdir(test_dir);rescue;p'Dir exists';end
                    I just added the p 'puts' so you can see what happens in the RC...
                      driven
                      @TIG,
                      that works here as well, but it doesn't really tell you why it's failed.
                      can further checks be done in the 'rescue' to pin-point any issue
                      e.g
                        UI.messagebox("Houston, we have a problem") if not FileTest.writable_real? test_dir
                        UI.messagebox("You are not an administrator on this computer") if  not isAdmin?
                      which brings up a few questions, is there a PC equiv. for?
                      def isAdmin?
                       iSadmin == user.to_a
                      is FileTest.writable_real? any more reliable on a PC?
                        You normally won't need to know why it failed - of course you can puts the error message into the RC etc BUT why would a users temp folder tree limit writability anyway - it's where apps etc store their temp files ?
                        All my snippet was doing was avoiding the PC issue - where File.exist? returns 'false' when the file or folder actually exists, but there are non-ASCII characters in its path - like a 'usér-name'.
                        There's no other way of ensuring you 'make' the missing file / folder otherwise...
                        If File.exist? says 'false', BUT it really exists then Dir.mkdir will fail as you can't make a directory if it already exists, so isn't it best to always try and make it ?
                          driven
                          I was thinking more for a standalone debug script to try and find why these edge cases are failing.
                          • 2 / 2
