    Creation of folder from Ruby on Mac
    31 Posts 5 Posters 2.5k Views 5 Watching
    • jeff hammondJ
      @driven said:
      @ Jeff, both paths are there, one for the user path [shows true] and one is showing that the 'old' System/Library/path doesn't exist anymore, so it's the same as doing
      SketchUp 2013 is only in the User path, as you have shown...
      right.. i think you missed the point of my post though..
      you got FALSE whereas i got TRUE upon using FileTest.writable_real?
      and we were both aiming for the same folder (the 2013 folder)
      ie- i had /Users/jeff in front of my path and your path started at /Library.. the front end was truncated
      [edit].. i'll also point out that using the tilde instead of /users/jeff returns false
      > FileTest.writable_real?("~/Library/Application Support/SketchUp 2013/SketchUp/plugins") false
        driven
        that's why I used
        FileTest.writable_real?(File.expand_path("~/Library/Application Support/SketchUp 2013/SketchUp"))
        which returns True, because the
        bit returns /Users/johns_iMac/Library/Application Support/SketchUp 2013/SketchUp, so when combined it gives the same result as hard coding, but will work for any user.
        The real point I was trying to make is that any 'Plugin' that's hardcoded to use "/Library/Application Support/SketchUp [n]/SketchUp/" will fail in v2013 because that 'Folder' is not created by v2013.
        So, given that the only pathout is from /Users/ why would there be any permission issues at all, unless something has been 'turned' off by 'System' or the user.
        Even with
        Sketchup.plugins_disabled?
        returning true
        FileTest.writable_real?(Sketchup.find_support_file('plugins' || 'Plugins' ))
        returns true
        no matter what I try, I can't get this to fail writing a new file in a new folder in 'Plugins'
        if saved in ~/Library/Application\ Support/SketchUp\ 2013/SketchUp/Plugins/from_v2013_plugins.rb
         begin
          home =  File.expand_path(File.dirname(__FILE__))
          test_dir = home + "/!Test_Folder"
          Dir.mkdir(test_dir) unless FileTest.exists?(test_dir)
          path = File.join( test_dir, "/from_v2013_plugins_file")
          file = File.open(path, "w")
          file.write(Time.now.to_s + "\n" +
        "FileTest.writable_real?('/tmp') = " + (FileTest.writable_real?("/tmp")).to_s + "\n" +
        "FileTest.writable_real?(ENV['TMPDIR']) = " + (FileTest.writable_real?(ENV['TMPDIR'])).to_s
        rescue IOError => e
          #some error occur, dir not writable etc.
        ensure
          file.close unless file == nil
        and it's text is
        %(#0000FF)[Sun May 26 23:08:59 +0100 2013
        FileTest.writable_real?('/tmp') = true
        FileTest.writable_real?(ENV['TMPDIR']) = true]
        so, all three paths are writable_real? from a ruby script from either /Users/johns_iMac/Applications/SketchUp 2013 or from /Applications/SketchUp 2013
        • jeff hammondJ
          yeah.. i don't know..
          the question by fredo is
          can you create a folder on mac via ruby or not?
          @fredo.. can you make a little script or snippet to test with?
            driven
            Yes, using the ruby snippet in my last post [ saved as a .rb file ], I can create both a Folder and a file from a ruby script in the Plugins folder.
            @Jeff it should work on yours as well.
            @Fredo, is there any pattern to what's failing?
              I don't understand Fredo's issues here... 😕
              I already make/use different 'personal subfolders' on PC AND MAC to store temporary files, AND also permanent files: they are automatically made for each User in straightforward Ruby Code.
              I gave detailed examples in my earlier post - lifted almost verbatim from the SCF tools loader .rb, I just edited out some module specific Constants...
              The 'Plugin Store. for example has ..Local/Temp/SCF/ PC||MAC ...xxx/T/SCF/ folders to take the temporary RBZ files etc during auto-install processing and the ..Local/SCF/ PC||MAC ...xxx/SCF/ folders to take the 'encrypted login cookie' that's used so you don't have to login with every visit !
              • fredo6F
                All I am trying to figure out is an alternate location where to create the DEFPARAM_Dir folder, since for some Mac users, it seems not to work in the SU Plugins area on Mac.
                I was just wondering is the Mac has some sophisticated security whereby certain file operations are prohibited from scripts, even if you can perform them manually (like create a folder).
                If not, then we are left with the normal access rules and I imagine that the /users rootpath is normally enabled for writing.
                PS: thanks to the contributors. I have to ask as I don't have a Mac currently.
                  driven
                  Basically, if you can't write to there, it's hard to find somewhere else with 'lesser' permissions.
                  I think it will work for more people where it is, as far as I can find, this should only be an issue on 'Guest Accounts' that have file access restrictions enabled by an administrator. [maybe Corporations/Uni's etc..]
                  You can test for 'admin' quite easily [code below] and use a MB or similar for those without them...
                  It has lots, but for the majority of users, as long as it's in the 'User' domain it's actually a lot more complicated to limit access then allow it. App SandBoxing may come into play in a few cases.
                  I think you should go with that assumption, and maybe add some simple test to you logfile RE:admin
                  always happy to help keep your plugins working on macs
                  This checks I'm an admin and writes to your folder from wherever I load your folder from.
                  not the best coding, but works from a variety of accounts that I have access to.
                  def isAdmin
                    user = %x( whoami ).chomp!
                    admins = %x( dscl . read /Groups/admin GroupMembership ).chomp!
                    iSadmin = (admins.scan user) == user.to_a
                  begin
                    home = (File.dirname(__FILE__))
                    test_dir = home + "/DEFPARAM_Dir"
                   if not FileTest.writable_real? test_dir
                    UI.messagebox("You need an administrator to modify defaults!") if  not isAdmin
                    else
                    file.write( Time.now.to_s )
                    end #if
                  rescue
                  ensure
                  • fredo6F
                    @driven
                    Thanks very much.
                    Are you also able to create the directory, not just to write files?
                      driven
                      Yes
                      works fine,
                        @driven said:
                        Yes
                        works fine,
                        That is the normal way to test if a folder/file exists and then if not you make it etc 😄 BUT I recommend an alternative...
                        On a PC with the current Ruby version operations like File.exist? etc can report 'false' even when it does exists, consequently causing an error when you try to make it and it's there ! - this occurs when the path contains non-ASCII characters - which is possible in user-names in the path to the Temp folder etc. I think MACs are more tolerant of characters? BUT we want a 'cross-platform' solution...
                        The simplest way is to always make it, trapping the error if it fails because it exists !
                        begin;Dir.mkdir(test_dir);rescue;p'Dir exists';end
                        I just added the p 'puts' so you can see what happens in the RC...
                          driven
                          @TIG,
                          that works here as well, but it doesn't really tell you why it's failed.
                          can further checks be done in the 'rescue' to pin-point any issue
                          e.g
                            UI.messagebox("Houston, we have a problem") if not FileTest.writable_real? test_dir
                            UI.messagebox("You are not an administrator on this computer") if  not isAdmin?
                          which brings up a few questions, is there a PC equiv. for?
                          def isAdmin?
                           iSadmin == user.to_a
                          is FileTest.writable_real? any more reliable on a PC?
                            You normally won't need to know why it failed - of course you can puts the error message into the RC etc BUT why would a users temp folder tree limit writability anyway - it's where apps etc store their temp files ?
                            All my snippet was doing was avoiding the PC issue - where File.exist? returns 'false' when the file or folder actually exists, but there are non-ASCII characters in its path - like a 'usér-name'.
                            There's no other way of ensuring you 'make' the missing file / folder otherwise...
                            If File.exist? says 'false', BUT it really exists then Dir.mkdir will fail as you can't make a directory if it already exists, so isn't it best to always try and make it ?
                              driven
                              I was thinking more for a standalone debug script to try and find why these edge cases are failing.
                              • 2 / 2
