    Creation of folder from Ruby on Mac
    31 Posts 5 Posters 1.9k Views 5 Watching
      driven
      maybe you didn't give it the proper path? because when i put this in the console:
      @ Jeff, both paths are there, one for the user path [shows true] and one is showing that the 'old' System/Library/path doesn't exist anymore, so it's the same as doing
      ls /Library/Application\ Support | grep "SketchUp"``
      which returns...
      %(#4000BF)[Google SketchUp 6
      Google SketchUp 7
      Google SketchUp 8
      SketchUp 5]
      where ls ~/Library/Application\ Support | grep "SketchUp" ``
      returns
      %(#008000)[Google SketchUp 6
      Google SketchUp 7
      Google SketchUp 8
      SketchUp 2013
      SketchUp 5]
      SketchUp 2013 is only in the User path, as you have shown...
        driven
        @TIG
        I think it's something else that has changed, I can still write files anywhere I want, if triggered by a user action after SU has loaded.
        before, I could just run a script on load, so the simplest example, if saved as hello.rb
        UI.messagebox("Hello from Plugins")
        it would run as soon as SU loaded it from either Plugins folder, but it doesn't now.
        if I use load "/Users/johns_iMac/Library/Application Support/SketchUp 2013/SketchUp/Plugins/hello.rb" from 'Ruby Console' it runs.
        If your trying to write to temp 'on load' it won't work from 'Plugins' anymore. It's not the destination that's at fault, it simply won't run.
        EDIT: found what had changed, but I'll leave this up anyway, I had v2013 Plugins turned 'off', from another script... DOH so it will run and write from the ~/Library/path to 'Plugins'
        • jeff hammondJ Offline
          right.. i think you missed the point of my post though..
          you got FALSE whereas i got TRUE upon using FileTest.writable_real?
          and we were both aiming for the same folder (the 2013 folder)
          ie- i had /Users/jeff in front of my path and your path started at /Library.. the front end was truncated
          [edit].. i'll also point out that using the tilde instead of /users/jeff returns false
          > FileTest.writable_real?("~/Library/Application Support/SketchUp 2013/SketchUp/plugins") false
            driven
            that's why I used
            FileTest.writable_real?(File.expand_path("~/Library/Application Support/SketchUp 2013/SketchUp"))
            which returns True, because the
            bit returns /Users/johns_iMac/Library/Application Support/SketchUp 2013/SketchUp, so when combined it gives the same result as hard coding, but will work for any user.
            The real point I was trying to make is that any 'Plugin' that's hardcoded to use "/Library/Application Support/SketchUp [n]/SketchUp/" will fail in v2013 because that 'Folder' is not created by v2013.
            So, given that the only pathout is from /Users/ why would there be any permission issues at all, unless something has been 'turned' off by 'System' or the user.
            Even with
            Sketchup.plugins_disabled?
            returning true
            FileTest.writable_real?(Sketchup.find_support_file('plugins' || 'Plugins' ))
            returns true
            no matter what I try, I can't get this to fail writing a new file in a new folder in 'Plugins'
            if saved in ~/Library/Application\ Support/SketchUp\ 2013/SketchUp/Plugins/from_v2013_plugins.rb
             begin
              home =  File.expand_path(File.dirname(__FILE__))
              test_dir = home + "/!Test_Folder"
              Dir.mkdir(test_dir) unless FileTest.exists?(test_dir)
              path = File.join( test_dir, "/from_v2013_plugins_file")
              file = File.open(path, "w")
              file.write(Time.now.to_s + "\n" +
            "FileTest.writable_real?('/tmp') = " + (FileTest.writable_real?("/tmp")).to_s + "\n" +
            "FileTest.writable_real?(ENV['TMPDIR']) = " + (FileTest.writable_real?(ENV['TMPDIR'])).to_s
            rescue IOError => e
              #some error occur, dir not writable etc.
            ensure
              file.close unless file == nil
            and it's text is
            %(#0000FF)[Sun May 26 23:08:59 +0100 2013
            FileTest.writable_real?('/tmp') = true
            FileTest.writable_real?(ENV['TMPDIR']) = true]
            so, all three paths are writable_real? from a ruby script from either /Users/johns_iMac/Applications/SketchUp 2013 or from /Applications/SketchUp 2013
              yeah.. i don't know..
              the question by fredo is
              can you create a folder on mac via ruby or not?
              @fredo.. can you make a little script or snippet to test with?
                driven
                Yes, using the ruby snippet in my last post [ saved as a .rb file ], I can create both a Folder and a file from a ruby script in the Plugins folder.
                @Jeff it should work on yours as well.
                @Fredo, is there any pattern to what's failing?
                  I don't understand Fredo's issues here... πŸ˜•
                  I already make/use different 'personal subfolders' on PC AND MAC to store temporary files, AND also permanent files: they are automatically made for each User in straightforward Ruby Code.
                  I gave detailed examples in my earlier post - lifted almost verbatim from the SCF tools loader .rb, I just edited out some module specific Constants...
                  The 'Plugin Store. for example has ..Local/Temp/SCF/ PC||MAC ...xxx/T/SCF/ folders to take the temporary RBZ files etc during auto-install processing and the ..Local/SCF/ PC||MAC ...xxx/SCF/ folders to take the 'encrypted login cookie' that's used so you don't have to login with every visit !
                  • fredo6F Offline
                    All I am trying to figure out is an alternate location where to create the DEFPARAM_Dir folder, since for some Mac users, it seems not to work in the SU Plugins area on Mac.
                    I was just wondering is the Mac has some sophisticated security whereby certain file operations are prohibited from scripts, even if you can perform them manually (like create a folder).
                    If not, then we are left with the normal access rules and I imagine that the /users rootpath is normally enabled for writing.
                    PS: thanks to the contributors. I have to ask as I don't have a Mac currently.
                      driven
                      Basically, if you can't write to there, it's hard to find somewhere else with 'lesser' permissions.
                      I think it will work for more people where it is, as far as I can find, this should only be an issue on 'Guest Accounts' that have file access restrictions enabled by an administrator. [maybe Corporations/Uni's etc..]
                      You can test for 'admin' quite easily [code below] and use a MB or similar for those without them...
                      It has lots, but for the majority of users, as long as it's in the 'User' domain it's actually a lot more complicated to limit access then allow it. App SandBoxing may come into play in a few cases.
                      I think you should go with that assumption, and maybe add some simple test to you logfile RE:admin
                      always happy to help keep your plugins working on macs
                      This checks I'm an admin and writes to your folder from wherever I load your folder from.
                      not the best coding, but works from a variety of accounts that I have access to.
                      def isAdmin
                        user = %x( whoami ).chomp!
                        admins = %x( dscl . read /Groups/admin GroupMembership ).chomp!
                        iSadmin = (admins.scan user) == user.to_a
                      begin
                        home = (File.dirname(__FILE__))
                        test_dir = home + "/DEFPARAM_Dir"
                       if not FileTest.writable_real? test_dir
                        UI.messagebox("You need an administrator to modify defaults!") if  not isAdmin
                        else
                        file.write( Time.now.to_s )
                        end #if
                      rescue
                      ensure
                      • fredo6F Offline
                        @driven
                        Thanks very much.
                        Are you also able to create the directory, not just to write files?
                          driven
                          Yes
                          works fine,
                            @driven said:
                            Yes
                            works fine,
                            That is the normal way to test if a folder/file exists and then if not you make it etc πŸ˜„ BUT I recommend an alternative...
                            On a PC with the current Ruby version operations like File.exist? etc can report 'false' even when it does exists, consequently causing an error when you try to make it and it's there ! - this occurs when the path contains non-ASCII characters - which is possible in user-names in the path to the Temp folder etc. I think MACs are more tolerant of characters? BUT we want a 'cross-platform' solution...
                            The simplest way is to always make it, trapping the error if it fails because it exists !
                            begin;Dir.mkdir(test_dir);rescue;p'Dir exists';end
                            I just added the p 'puts' so you can see what happens in the RC...
                              driven
                              @TIG,
                              that works here as well, but it doesn't really tell you why it's failed.
                              can further checks be done in the 'rescue' to pin-point any issue
                              e.g
                                UI.messagebox("Houston, we have a problem") if not FileTest.writable_real? test_dir
                                UI.messagebox("You are not an administrator on this computer") if  not isAdmin?
                              which brings up a few questions, is there a PC equiv. for?
                              def isAdmin?
                               iSadmin == user.to_a
                              is FileTest.writable_real? any more reliable on a PC?
                                You normally won't need to know why it failed - of course you can puts the error message into the RC etc BUT why would a users temp folder tree limit writability anyway - it's where apps etc store their temp files ?
                                All my snippet was doing was avoiding the PC issue - where File.exist? returns 'false' when the file or folder actually exists, but there are non-ASCII characters in its path - like a 'usΓ©r-name'.
                                There's no other way of ensuring you 'make' the missing file / folder otherwise...
                                If File.exist? says 'false', BUT it really exists then Dir.mkdir will fail as you can't make a directory if it already exists, so isn't it best to always try and make it ?
                                  driven
                                  I was thinking more for a standalone debug script to try and find why these edge cases are failing.
                                  • 2 / 2
