    Creation of folder from Ruby on Mac
    31 Posts 5 Posters 2.5k Views 5 Watching
      Does Sketchup.find_support_file('plugins') in the Ruby Console now return the User's plugins folder ?
      It used to return the HD one...
      • jeff hammondJ
        entering that into 2013 ruby console:
        /Users/jeff/Library/Application Support/SketchUp 2013/SketchUp/plugins
          So in v2013 it looks at the writable user's plugins folder, in v8 it used to look at the HD version, which is where it WAS recommended to install plugins BUT you could have limited access rights and that caused issued.
          On a PC we are stuck with the main Plugins folder, which often needs its permissions fixing to allow it to be 'managed' by a user... πŸ˜’
          • fredo6F
            TIG, Dan, Jeff,
            Thanks.
            However what I want to be sure of is more precise.
            Even if a folder is writable 'manually', it may not be possible to create a folder "from a script". This is what I am looking for.
              driven
              @dan rathbun said:
              You could have a Mac user print out all the vars:
              :idea:
              By default [on my mac] SketchUp.app installs into /Applications, form there...
              ENV.each {|k,v| puts("#{k} = '#{v}'") } returns
              PATH = '/usr/bin;/bin;/usr/sbin;/sbin'
              TMPDIR = '/var/folders/rp/b9k42l5x7xngx_8tckgs0zdr0000gn/T/'
              SHELL = '/bin/bash'
              HOME = '/Users/johns_iMac'
              USER = 'johns_iMac'
              LOGNAME = 'johns_iMac'
              SSH_AUTH_SOCK = '/tmp/launch-wN3bJR/Listeners'
              Apple_Ubiquity_Message = '/tmp/launch-blGWcE/Apple_Ubiquity_Message'
              Apple_PubSub_Socket_Render = '/tmp/launch-a6GyAw/Render'
              DISPLAY = '/tmp/launch-mAuKFs/org.macosforge.xquartz;0'
              IG_ROOT = '/Applications/SketchUp 2013/SketchUp.app/Contents/Resources'
              SHLVL = '4'
              PWD = '/'
              _ = '/usr/bin/open'
              __CF_USER_TEXT_ENCODING = '0x1F5;0;0'
              COMMAND_MODE = 'unix2003'
              On other setups SketchUp.app can also be installed into ~/Applications, so I moved it to see the differences and form there...
              SHELL = '/bin/bash'
              USER = 'johns_iMac'
              IG_ROOT = '/Users/johns_iMac/Applications/SketchUp 2013/SketchUp.app/Contents/Resources'
              SHLVL = '4'
              PWD = '/'
              _ = '/usr/bin/open'
              IG_ROOT is the only change... but that may make a difference, especially with 'sandboxing' and 'gatekeeper', I'll dig some more.
                driven
                ok, I found a difference, v8 run from /Applications and v2013 run from ~/Applications
                this script is in both 'Plugins' folders, [with appropriate version in name...]
                FileTest.writable_real?('/tmp') && FileTest.writable_real?(ENV['TMPDIR'])
                    UI.messagebox("This code is for Mac only!")
                 begin
                  home = File.expand_path "~"
                  path = File.join( home, "/from_v8_plugins_file")
                  file = File.open(path, "w")
                  file.write(Time.now.to_s + "\n" +
                "FileTest.writable_real?('/tmp') = " + (FileTest.writable_real?("/tmp")).to_s + "\n" +
                "FileTest.writable_real?(ENV['TMPDIR']) = " + (FileTest.writable_real?(ENV['TMPDIR'])).to_s
                rescue IOError => e
                  #some error occur, dir not writable etc.
                ensure
                  file.close unless file == nil
                on start up v8 shows the dialog and writes the temp file to my user Directory. v2013 doesn't, I'll move it back to see if it's the ~/Application path that's causing it to not run...
                • fredo6F
                  John,
                  Thanks.
                  Then the next thing to check if whether a Ruby script can create a directory under the /users/...hierarchy (pointed to by HOME).
                  If so, then, I'll store the parameters in this part, whether Sketchup is installed in /users or /applications.
                    driven
                    I think this is the crux of the issue,
                    SU 2013 writes nothing to the
                    > FileTest.writable_real?("/Library/Application Support/SketchUp 2013/SketchUp") false
                    plugins are either in the app bundle or written to
                    > FileTest.writable_real?(File.expand_path("~/Library/Application Support/SketchUp 2013/SketchUp")) true
                    it also appears that though loaded they don't 'auto run' on load from /Plugins.
                    This does appear to be different, from v8
                    the same tmp paths are still all accessible, but not immediately on load.
                    I can get it to auto run on load from "~/Library/Application Support/SketchUp 2013/SketchUp/Tools", but only because I have another script that writes that Directory for me, and SU auto loads/runs my startup files that are in it.
                      Of course a user should be able to make a new directory in one of the user's 'own' folders.
                      After all it would be pointless having permissions set to prevent a user writing things into their own folders. Conversely it's a good idea to protect system/program folders from indiscriminate changes by general users...
                      As I mentioned several posts back, the premade user's folders for making temporary files, OR subfolders within this to keep you files together, is the ../Local/Temp/ folder or the MAC ...xxx/T/ equivalent.
                      The location one level down from that can be used for the permanent subfolder+files from your tool as this isn't auto-purged during system cleanups... ../Local/ or ...xxx/
                      I don't see you concern, these folders are designed to do exactly what you intend, so permissions should always be OK...
                      • jeff hammondJ
                        maybe you didn't give it the proper path? because when i put this in the console:
                        FileTest.writable_real?("/Users/jeff/Library/Application Support/SketchUp 2013/SketchUp/plugins")
                        it returnstrue
                        that's the exact path i was given upon entering the line from TIG-- Sketchup.find_support_file('plugins')
                          driven
                          @ Jeff, both paths are there, one for the user path [shows true] and one is showing that the 'old' System/Library/path doesn't exist anymore, so it's the same as doing
                          ls /Library/Application\ Support | grep "SketchUp"``
                          which returns...
                          %(#4000BF)[Google SketchUp 6
                          Google SketchUp 7
                          Google SketchUp 8
                          SketchUp 5]
                          where ls ~/Library/Application\ Support | grep "SketchUp" ``
                          returns
                          %(#008000)[Google SketchUp 6
                          Google SketchUp 7
                          Google SketchUp 8
                          SketchUp 2013
                          SketchUp 5]
                          SketchUp 2013 is only in the User path, as you have shown...
                            driven
                            @TIG
                            I think it's something else that has changed, I can still write files anywhere I want, if triggered by a user action after SU has loaded.
                            before, I could just run a script on load, so the simplest example, if saved as hello.rb
                            UI.messagebox("Hello from Plugins")
                            it would run as soon as SU loaded it from either Plugins folder, but it doesn't now.
                            if I use load "/Users/johns_iMac/Library/Application Support/SketchUp 2013/SketchUp/Plugins/hello.rb" from 'Ruby Console' it runs.
                            If your trying to write to temp 'on load' it won't work from 'Plugins' anymore. It's not the destination that's at fault, it simply won't run.
                            EDIT: found what had changed, but I'll leave this up anyway, I had v2013 Plugins turned 'off', from another script... DOH so it will run and write from the ~/Library/path to 'Plugins'
                            • jeff hammondJ
                              right.. i think you missed the point of my post though..
                              you got FALSE whereas i got TRUE upon using FileTest.writable_real?
                              and we were both aiming for the same folder (the 2013 folder)
                              ie- i had /Users/jeff in front of my path and your path started at /Library.. the front end was truncated
                              [edit].. i'll also point out that using the tilde instead of /users/jeff returns false
                              > FileTest.writable_real?("~/Library/Application Support/SketchUp 2013/SketchUp/plugins") false
                                driven
                                that's why I used
                                which returns True, because the
                                bit returns /Users/johns_iMac/Library/Application Support/SketchUp 2013/SketchUp, so when combined it gives the same result as hard coding, but will work for any user.
                                The real point I was trying to make is that any 'Plugin' that's hardcoded to use "/Library/Application Support/SketchUp [n]/SketchUp/" will fail in v2013 because that 'Folder' is not created by v2013.
                                So, given that the only pathout is from /Users/ why would there be any permission issues at all, unless something has been 'turned' off by 'System' or the user.
                                Even with
                                Sketchup.plugins_disabled?
                                returning true
                                FileTest.writable_real?(Sketchup.find_support_file('plugins' || 'Plugins' ))
                                returns true
                                no matter what I try, I can't get this to fail writing a new file in a new folder in 'Plugins'
                                if saved in ~/Library/Application\ Support/SketchUp\ 2013/SketchUp/Plugins/from_v2013_plugins.rb
                                 begin
                                  home =  File.expand_path(File.dirname(__FILE__))
                                  test_dir = home + "/!Test_Folder"
                                  Dir.mkdir(test_dir) unless FileTest.exists?(test_dir)
                                  path = File.join( test_dir, "/from_v2013_plugins_file")
                                rescue IOError => e
                                ensure
                                and it's text is
                                %(#0000FF)[Sun May 26 23:08:59 +0100 2013
                                FileTest.writable_real?('/tmp') = true
                                FileTest.writable_real?(ENV['TMPDIR']) = true]
                                so, all three paths are writable_real? from a ruby script from either /Users/johns_iMac/Applications/SketchUp 2013 or from /Applications/SketchUp 2013
                                • jeff hammondJ
                                  yeah.. i don't know..
                                  the question by fredo is
                                  can you create a folder on mac via ruby or not?
                                  @fredo.. can you make a little script or snippet to test with?
                                    driven
                                    Yes, using the ruby snippet in my last post [ saved as a .rb file ], I can create both a Folder and a file from a ruby script in the Plugins folder.
                                    @Jeff it should work on yours as well.
                                    @Fredo, is there any pattern to what's failing?
                                      I don't understand Fredo's issues here... πŸ˜•
                                      I already make/use different 'personal subfolders' on PC AND MAC to store temporary files, AND also permanent files: they are automatically made for each User in straightforward Ruby Code.
                                      I gave detailed examples in my earlier post - lifted almost verbatim from the SCF tools loader .rb, I just edited out some module specific Constants...
                                      The 'Plugin Store. for example has ..Local/Temp/SCF/ PC||MAC ...xxx/T/SCF/ folders to take the temporary RBZ files etc during auto-install processing and the ..Local/SCF/ PC||MAC ...xxx/SCF/ folders to take the 'encrypted login cookie' that's used so you don't have to login with every visit !
                                      • fredo6F
                                        All I am trying to figure out is an alternate location where to create the DEFPARAM_Dir folder, since for some Mac users, it seems not to work in the SU Plugins area on Mac.
                                        I was just wondering is the Mac has some sophisticated security whereby certain file operations are prohibited from scripts, even if you can perform them manually (like create a folder).
                                        If not, then we are left with the normal access rules and I imagine that the /users rootpath is normally enabled for writing.
                                        PS: thanks to the contributors. I have to ask as I don't have a Mac currently.
                                          driven
                                          Basically, if you can't write to there, it's hard to find somewhere else with 'lesser' permissions.
                                          I think it will work for more people where it is, as far as I can find, this should only be an issue on 'Guest Accounts' that have file access restrictions enabled by an administrator. [maybe Corporations/Uni's etc..]
                                          You can test for 'admin' quite easily [code below] and use a MB or similar for those without them...
                                          It has lots, but for the majority of users, as long as it's in the 'User' domain it's actually a lot more complicated to limit access then allow it. App SandBoxing may come into play in a few cases.
                                          I think you should go with that assumption, and maybe add some simple test to you logfile RE:admin
                                          always happy to help keep your plugins working on macs
                                          This checks I'm an admin and writes to your folder from wherever I load your folder from.
                                          not the best coding, but works from a variety of accounts that I have access to.
                                          def isAdmin
                                            user = %x( whoami ).chomp!
                                            admins = %x( dscl . read /Groups/admin GroupMembership ).chomp!
                                            iSadmin = (admins.scan user) == user.to_a
                                          begin
                                            home = (File.dirname(__FILE__))
                                            test_dir = home + "/DEFPARAM_Dir"
                                           if not FileTest.writable_real? test_dir
                                            UI.messagebox("You need an administrator to modify defaults!") if  not isAdmin
                                            else
                                            file.write( Time.now.to_s )
                                            end #if
                                          rescue
                                          ensure
                                          • fredo6F
                                            @driven
                                            Thanks very much.
                                            Are you also able to create the directory, not just to write files?
