    [Plugin] CleanUp
    974 Posts 217 Posters 861.7k Views 217 Watching
    • O Offline
      oggstreamer
      i found a blog about webdialog on wine related to Sketchup:
      Getting SketchUp 8 Working in Wine -- Even WebDialogs!
      Updated 2010/12/22: ย Updates are shown in red ย below: Some SketchUp enthusiasts have created an excellent resource on getti...
      (robsworldoftech.blogspot.com)
      maybe it will work this way but i don't have time right now to try it.
        GooUser
        Hello thomthom ! I'm new user of sUP and this forum! Thank you for your work! And sorry for my bad English !
        • F Offline
          finnishXchange
          Thom,
          I am excited to try your program for cleaning up lines in a file imported from autocad. Would you mind explaining how to install the plug-in, or direct me to where I might find a tutorial for that? I'm a new member of this site and the only other plug-in I have used is Kerkythea, so pretty clueless what to do with the rb file after saving it to the desktop. I am using SU version 8 with mac OS x 10.6.8.
          Thanks a lot!
          Troy
            Here are some instructions how to install zipped plugins:
            http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
            Note that for this plugin to work, you will also need to install another plugin library (linked from the first post). That's also zipped so the procedure is the same.
            • opalO Offline
              opal
              Hello,
              So.. after the installation of M2, I put tt_cleanup.rb in the brand new plugins folder.. I think the shiny new empty folder confused it.. it's lonesome in there and I'm getting the messages on startup
              tt?cleanup.rb
              Error: No such file to load - TT_lib2/core.rb
              So.. instead of using the copy/paste of the file from the old plugins folder, I came back to this thread and downloaded it again.. same error message.
              Is there a companion file I'm supposed to download with it?
                Yes, TT_Lib2, which is linked from the description in the first post. Above the download link.
                • opalO Offline
                  opal
                  hmmm.. I have that one in there
                  I'll take it out and download fresh
                  thank you ๐Ÿ˜„
                    Check how you extracted the files. For each plugin there is a description on how and where the files should be installed. Or even better, if you have SketchUp 8 and updated to the recent M2 update, go to Window > Preferences > Extensions > Install Extension and install the plugins from there. Just select the zip files from the file dialog that appears.
                    • opalO Offline
                      opal
                      Got it working this morning ty
                      the M2 install from within the program feature doesn't seem to see anything besides file folders and .rbs files. I went to my backup plugins folder to start getting some of the missing most used plugins back after the update from within sketchup and don't see zip or rb files with that tool.
                        The 'button-installer' only works on .RBZ files [which are compressed archives just like .ZIP files]. By default you will only see folders or .RBZ files in the browser that is opened by the button... BUT you can trick it into showing you all file types: type *+<enter> in the file field and all files will now show... find the tool's .ZIP file and install it, it will work just like a .RBZ file... NOTE: it will install any .ZIP file... so ensure that it is a proper tool-set ZIP and not one of your holiday-photos, as they will could be copied into Plugins folder too ๐Ÿ˜‰ Also note that picking any other non-compressed archive file type will generate an error...
                        • opalO Offline
                          opal
                          cool.. ty again
                          • kingsiK Offline
                            kingsi
                            I am very new to Sketchup (1st week) and also one of those annoying people that never says thanks on forums. I plan on being neither from now on. So on that note many thanks for the cleanup script
                            kingsi
                            Noobtastic
                              ๐Ÿ‘
                                Boumbastique
                                Zip file don't want to unpack, it says - "unknown format or an error in archive" tt_cleanup.zip ๐Ÿ˜ข (other zip files works correct on my pc)
                                  Try downloading again
                                    Boumbastique
                                    I tried many times, it didn't work, unfortunately.
                                      Boumbastique
                                      I have found it on other resource. Work's great. thomthom thank you very much, you're cool man ๐Ÿ‘
                                        And where exactly is this other resource?
                                        • john2J Offline
                                          john2
                                          i cant load cleanup properly. however if i create a separate folder with required ttlib, this plugin works perfectly.
                                          http://i.imgur.com/9af9A.jpg
                                          my plugins list is here
                                          http://www.sendspace.com/file/jwyz90
                                          Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                          • sumasterS Offline
                                            sumaster
                                            CHK it out your Internet Explorer Version
                                            I think you have old internet explorer
                                            Install New internet explorer this problem is sold
                                            Thank you,
                                            SUmaster
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 48
                                            • 49
                                            • 26 / 49
