    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
      rv1974
      Fredo, thank you for clarification 👍
      and hoping for p.2 will come true in some up-coming point update.
        sridhar
        Hi Fredo,
        Tried using the plugin, it allows me to select and then quickly flashes the cleansing screen and generates a flat rectangular surface and contours as guidelines.
        I have installed as instructed.
        Am i missing something
        Regards
        Sridhar
        • fredo6F
          @sridhar said:
          Hi Fredo,
          Regards
          Sridhar
          The default view for the Cleansing is the map view. Are your original contours given an elevation?
          The best would be to post your model
            sridhar
            @sridhar said:
            Hi Fredo,
            Regards
            Sridhar
            Hi sending the screenshot
            thanks
            • fredo6F
              @Sridhar
              It seems you miss the button palette
                sridhar
                @Sridhar
                The button comes briefly and then exits out of the plugin with an output shown above,
                Regards
                Sridhar
                • fredo6F
                  @sridhar said:
                  Regards
                  Sridhar
                  Could you open the Ruby console and report of the error message you see.
                  Your model seems complex and there may be some issues
                  Thanks very much
                  • C
                    chris87
                    @sridhar said:
                    Regards
                    Sridhar
                    Thanks very much
                    I have the same problem.
                    The rod of Topshaper tools also disappears to this level.
                    No message of mistake in the Ruby console.
                    This problem even occurs with the well stocked examples.
                    • fredo6F
                      @chris87, @sridhar
                      Could check that if you type Return, you go to the next step (preview). You can also check the contextual menu.
                      By the way, which OS are you on?
                      • C
                        chris87
                        @fredo6 said:
                        @chris87, @sridhar
                        OS :
                        PC windows 7 - sketchup 8 pro last version-
                        No action occurs with the key return
                        the contextual menu "toposhaper --- > generate land (square maillage)" makes the previous operation throw back only.
                        the toposhaper toolbar doesn't reappear.
                        excuse me for the bad english language (french user....)
                        best regards and thank you for your superb plugins...
                        • B
                          bhbarchitects
                          Great plugin love it!
                            **Ewie**
                            @tig said:
                            Ewan
                            Open the Ruby Console.
                            Then try running the tool.
                            Report any error messages.
                            Also check your Plugins folder's Properties > Security permissions are set to FULL for everyone in the list [Edit + Apply/OK]
                            If not this might stop some log file etc getting written if you have limited rights...
                            Hi TIG, sorry for the tardy reply, I didn't get a notification of the replies on this thread..
                            I checked permissions on the plugin folder; all full control so no issues there.
                            Re-ran the plugin with the ruby script window open.. Same issue as before, this time using one of the sample files
                            Screen shot attached to explain.
                              @Ewan
                              Have you tried reinstalling the whole Topo'toolset AND the latest LibFredo again.
                              That might jolt it into submission...
                              First, if you did a manual install check for misplaced files in the Plugins folder.
                              Then reinstall the Lib, then Topo'toolset - I recommend you get/use the "SketchUcation Plugin Store" and use its 'AutoInstall' feature, this will ensure that everything is always put into the right places...
                              • C
                                chris87
                                @tig said:
                                @Ewan
                                I have exactly the same problem.
                                All is installed correctly with the good rights and with the last libraries.
                                No error in the ruby console !!!!
                                  Can you post screenshots for Fredo to check...
                                  Of the Plugins folder showing the installed files/subfolder and the contents of the subfolder itself...
                                  • fredo6F
                                    @chris87, @ewan
                                    It may simply be a bug.
                                    I'll come back with some instructions in order to figure out what it could be.
                                    What would help me is that you tell me what you see in the contextual menu when you are in this screen (a screenshot is OK).
                                    • C
                                      chris87
                                      @fredo6 said:
                                      @chris87, @ewan
                                      screenshot
                                      • fredo6F
                                        Chris,
                                        I mean when you are within TopoShaper and have the display of your screenshot, right click and tell me what is the contextual menu.
                                        • C
                                          chris87
                                          @fredo6 said:
                                          Chris,
                                          Visible on my screenshot :
                                          right click
                                          toposhaper ---- > générer terrain (maillage carré)
                                          best regards
                                          • soloS
                                            I'm getting a warning when starting SU 2013
                                            Error loading File bootstrap_TopoShaper.rb
                                            uninitialized constant bTopoShaper;;T6
                                            I have tried reinstalling and even checked that bootstrap_TopoShaper is present in plugin folder.
                                            Still get the error.
                                            • 22
                                            • 23
                                            • 4 / 23
