    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • W
      Woody Longspike
      Hey TIG thanks for your reply I'm on Windows XP home 32 bit SP3. There`s no properties/security settings tab, thats a windows vista or 7 & up thing. I do have computer admin settings which I always log in as admin.
        XP !
        Then you need to do it another way...
        http://support.microsoft.com/kb/308419
        http://www.ehow.com/how_2383435_set-permissions-windows-xp.html
        • W
          Woody Longspike
          If simple file sharing is enabled, the simple file sharing user interface is displayed instead of the Security and Sharing tabs. By default, this new user interface is implemented in both Windows XP Home Edition and Windows XP Professional if you are working in a workgroup. If you disable simple file sharing, the classic Security and Sharing tabs appear, and you can specify which users and groups have access to shared folders on your computer.
          Note You cannot disable simple file sharing in Windows XP Home Edition.
          Aha...Thanks Fredo6, TIG, & Dave R. I was under the impression Additional Plugin Folder plugin was a work around this problem. Apparently after reading many support articles and threads here, there, and everywhere else, Windows XP Home has failed me ๐Ÿ˜  http://support.microsoft.com/kb/307874 no fix or work around available from my understanding. Thanks again for your help.
            Can you not fix permission in the command-console?
            I think that was explained in the first link I gave ??
            • LanaL
              Lana
              Very, very thanks TIG, you are big. Congratulations.
              • fredo6F
                NEW RELEASE: LibFredo6 v4.9a - 18 May 13
                LibFredo6 4.9a is dedicated to Curvizard 1.2 (to improve the management of bigger amount of contours and edges).
                • fredo6F
                  NEW RELEASE: LibFredo6 v4.9b - 19 May 13
                  LibFredo6 4.9b is a technical release mainly dedicated to some issues on Mac platforms.
                  • W
                    watkins
                    Dear Fredo6,
                    There is a small problem with your plugin checker
                    404 Not Found
                    (sketchucation.com)
                    Kind regards,
                    Bob
                    • mitcorbM
                      mitcorb
                      At this time, LibFredo6 version 4.9b 19 May 13 is not listed as such in the Plugins Index yet, and the Plugin Store does not list it yet, either. I realize that the database keepers will update this soon, just wanted to report.
                        Yes, we know - Fredo is changing versions frequently at the moment ๐Ÿ˜’ - once the dust settles be assured that it'll get into both the Index and the Store [the updating is not 'automatic' - it needs human intervention to ensure it's kosher...]
                        • fredo6F
                          NEW RELEASE: LibFredo6 v4.9c - 20 May 13
                          LibFredo6 4.9b is a technical release still dedicated to some issues on Mac platforms.
                          • fredo6F
                            @watkins said:
                            Dear Fredo6,
                            404 Not Found
                            (sketchucation.com)
                            Kind regards,
                            Bob
                            This should be fixed with 4.9c
                              mhackee
                              its not working on sketchup 2013.
                              it says, cannot load plugin Libfredo6 because the script cannot create DEFPARAM_Dir folder
                              pls create it manually, respecting the case
                                It cannot create the folder because you do not have FULL security permissions to your Plugins folder... FCS it has been covered in a dozen posts a hundred times...
                                Since you decline to give us any information about your OS etc then I must therefore guess...
                                That you have Windows...
                                If you [with some Admin Rights] find your SketchUp/Plugins folder and select its icon and right-click > context-menu > Properties > Security...
                                You will find that you do NOT have FULL permissions.
                                Therefore... Edit... and give everyone listed FULL permissions.
                                Now everything will work.
                                I reiterate: ๐Ÿ˜’
                                This will apply to most users.
                                IF YOU WANT TO INSTALL PLUGINS [EITHER MANUALLY OR AUTOMATICALLY] AND THEREAFTER HAVE THEM WORK WITHOUT ERROR YOU MUST DO SO INTO A FOLDER FOR WHICH YOU HAVE 'FULL' SECURITY PERMISSIONS.
                                On your own PC it is not beyond the wit of man to set your security-permissions appropriately.
                                Therefore fix the permissions to the main Sketchup/Plugins folder...
                                This is most prevalent on PCs... BUT MAC users need not feel so smug, because their 'plugins' folder in the 'HD' path [NOT the 'user' one] might also need resetting to have FULL Read/Write permissions...
                                If you are on a business or academic network you might have restricted access-rights to the main Sketchup/Plugins folder. Therefore you must install plugins into a 'custom-plugins' folder to which you have FULL rights... If this is the case, then seek further advice on how to contrive this...
                                Or you might want to 'centralize' your plugins-folder on a personal network for use by several personal PCs... then again you might need to make special arrangements to allow for this setup... if so ask again...
                                  Don-Quixote
                                  @cosedimarco said:
                                  @Fredo6
                                  New Italian translation is ready. ๐Ÿ˜„
                                  How can I set Italian Lang for this plug-in?
                                  where I should to put this file?
                                  • fredo6F
                                    @don-quixote said:
                                    @cosedimarco said:
                                    @Fredo6
                                    Go to menu Windows > LibFredo6 Settings... > Set language and just choose Italian.
                                    The file is part of the package.
                                      Don-Quixote
                                      ~~I don't have any "LibFredo6 Setting" folder and I don't understand where I should to search that folder ~~
                                      I FOUD IT ahahaha, Thank you so much that will help me a lot ๐Ÿ˜‰
                                      • mariochaM
                                        mariocha
                                        On MAc, with SU 2013, the HD///SketchUp 2013//Plugins folder does not exist.
                                        So only the User/library/application support/SketchUp 2013/SketchUP/Plugins. ๐Ÿ˜„
                                        %(#008000)[Mario C.
                                        • T
                                          tsong12
                                          Sketchup 2013 currently does not support the all latest LibFreso plugins....please consider in your next update.
                                          Thanks!!
                                          • fredo6F
                                            Thanks!!
                                            With LibFredo6 4.9c, this should be OK.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 115
                                            • 116
                                            • 31 / 116
