    Vray 1.6 open beta
    renderpluginsextensions
    94 Posts 28 Posters 26.3k Views 28 Watching
      AcesHigh
      it has VRAY RT? GPU or CPU?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Only CPU for now.
          arail1
          @cadfather said:
          looks really good.
          EDIT: btw, i filled the beta form, all i got was a strange id error and no way to redo it.
          Me too. Did you buy V-Ray from Chaos or Asgviz? I got an 'orderid' error but no way out of it. Frustrated.
            AcesHigh
            @jiminy-billy-bob said:
            Only CPU for now.
            so its not THAT real time I guess ๐Ÿ˜„
            does the RT window obeys the current renderer parameters (like for example IRMap+LightCache) in low settings or does it have its own render engine? (if it uses its own engine, how to know the final render using the usual engines will look the same?)
              CadFather
              no, i've only ever used the demo - the beta seems open to all though, not just licenced users. - maybe that's what i missed! ๐Ÿ˜’ ๐Ÿ˜†
                broomstick
                dkendig, I had a quick look, but I don't know if I'm being thick or something: where are the bump and displacement parameters for materials?
                  andybot
                  Only CPU for now.
                  It's its own separate engine, with its own settings. (for example reflection depth is much lower by default.) It's a sort of a progressive path tracing, looks nothing like the LC pass.
                  It does use distributed rendering, so you can hook up as many CPU's as you can find. ๐Ÿ˜„
                    CadFather
                    that's not what they say on the video though - they seem to make it a strong point that the engine is the same.
                      andybot
                      Hmm, I'll have to watch the video to see how exactly they describe it. Maybe they mean that you don't have to change anything to get RT to work - but it's definitely a different kind of render.
                      Andy
                        dkendig
                        CPU rendering with RT will result in the same image that you would get from a regular render, but as Andy said, it is sort of like progressive path tracing, so you can see a fairly decent result (enough to get a sense of illumination, color, etc) immediately. The longer it cooks, the better it looks. If you move the camera, it restarts, but again, you have a decent result immediately (no parsing time, no waiting at all). Move a light or an object in the scene, again, updates immediately. GPU support is something we want to add for this release if we have time for it, but we don't want to rush it in to the product and end up with an unstable build. We are all pretty fond of the way this build is working at the moment. FYI, if you use the GPU to render, there are some limitations: http://www.spot3d.com/vray/help/rt100/unsupported_features.htm, and that is due to the way you have to interact with the GPU. All of the V-Ray plugins have to be translated in to a shader language that the GPU can work with, and some of our features just don't translate well or at all. RT CPU will have none of these limitations, RT GPU will. That's one of the reasons we chose to integrate RT CPU first.
                        Devin Kendig
                        Developer
                          kalu
                          I am very disappointed with "CAOSGROUP". I have access to the new BETA and I request as the same as 3Dmax users the right to download VISMATS and they denied the request. Only owners of a license can download materials. So no trials witch I agree but BETA testers too? That's is ridiculous. Why users for MAX can have full access and the Sketchup BETA testers no?
                          Well they do not respond my request more than Bla Bla Bla without sense. I think someone respond by the book not by using their heads.
                          So you can download the soft test and not materials for use in CHAOSGROUP, use materials from other resources.
                          My 2 Cents.
                          THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                            CadFather
                            i'm a bit confused, must one be a licensed user to beta test?
                              jiminy-billy-bob
                              No, but you have to be licensed to download vismats on ChaosGroup's website.
                                CadFather
                                thanks, i thought that was the reason why i didn't get any emails reply.
                                  kalu
                                  If you are a Beta Tester you should have all the rights to have resources to test the soft in full. This is different to a trial version. You need resources to get feedback to the company and also check the soft and buy the soft in full.
                                  In this snon sesnse case the company only have the full access to users for other soft like 3D max and Sketchup is put in the ditch.
                                  Great strategy for new buyers no?
                                  Non sense. ๐Ÿ˜Ž
                                  • E Offline
                                    edenux
                                    Finally. Amazing improvements. I think we will have increase in quality of renders made with sketchup very fast ๐Ÿ˜„
                                    Only one question from me. How works material of proxy? For example if I created proxy with material. What will happen if I import that proxy into different project? Do I need to recreate its material?
                                    Want to see more? Visit my facebook page: https://www.facebook.com/Edvisualisation
                                      andybot
                                      Non sense. ๐Ÿ˜Ž
                                      kelper strikes again ๐Ÿ’š
                                      I think beta testing is different from a trial version of a software. Not sure why you would expect them to be released under the same conditions.
                                        dkendig
                                        kalu - I believe that there are licensing restrictions on some of the textures used for some materials, which prevent us from giving them away for free (this was the case with the Arroway materials I believe). It's not hard to make a material, and we provide plenty of documentation and tutorials on how to do it. If we made the life of a beta tester too easy, we would never find any bugs.
                                        Devin Kendig
                                        Developer
                                          kalu
                                          Thanks for the information. I talk to some people in Chaosgroup USA and as usual very helpful and different of the main company in Europe.
                                          Thanks again for the comments.
                                          Kalu. ๐Ÿ˜Ž
                                            cuttingedge
                                            2 questions .
                                            Pardon what could be a silly question. Do I have to uninstall my licensed copy to install this beta. My good sense is telling me I should do that but last time I had trouble activating which resulted in a disruption of office work for 3day or so..
                                            Will this upgrade come free for Licensed users?
                                            • 1 / 5
