    [Plugin] Camera Settings Export/Import
    33 Posts 21 Posters 55.9k Views 20 Watching
    • C
      careca
      Hello.
      I'm sharing a little script with everybody that does export & import camera settings, making transfers between files possible.
      As I was not able to find any script that can do this (though "Camera Statistics" provides the raw numbers, it requires quite a bit of copy&paste efforts), I went ahead and wrote it myself.
      So it's basically tackling an issue we have quite frequently in the office, when we have several versions of SU model files, dating back to different dates and occasions. And then sometime the client asks for a before/after comparison, for what we have to retain older files and retrofit them with newer camera positions (or do the same thing vice-verse).
      The scripting might be ruby-beginner-style, but is seems to be working on our SU 8 Win7 systems.
      It provides basic export options (choose between exporting "all scenes", "current scene" "selected scene") and import options (update camera of scenes with identical scene name)
      If somebody find this helpful, feel free to download and use it and let me know if you like it.
      Also feel free to enhance the script further.
      Best regards.
      Martin
      p.s. updated version uploaded 2012-08-29
      Camera Export / Import Version 1.1
      • ToboboT
        Tobobo
        Thanks I'll let you know how i get on.
        Toby
        Philippians 4:13
          Using the Advanced Camera extension in SU8 you can copy and paste camera objects around.
          View > Toolbars > Advanced Camera Tools
            Btw - to avoid potential clashes with other plugins it's best to wrap everything into a module. otherwise you're adding methods inthe global namespace which affects all other plugins.
            See more notes about avoiding clashes with other plugins in this article: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
              Aerilius
              In addition to using a module, avoid any hard-coded file paths:
              %(#000000)[D:\SU_camera_export.txt] does most likely not exist.
              An alternative is to use environment variables ( %(#000000)[ENV["TEMP"]||(ENV["TMP"]]; %(#000000)[ENV["USERPROFILE"]||ENV["HOME"]]) to get a default path or to ask the user directly for a path.
              Example:
              mypath = [UI.savepanel](https://developers.google.com/sketchup/docs/ourdoc/ui#openpanel)("Save the camera settings") return if mypath.nil? mypath = [File.expand_path](http://www.ruby-doc.org/core-1.8.6/File.html#method-c-expand_path)(mypath) myfile = File.new(mypath, "w")
              UI.messagebox exported_cams.to_s + " Cameras were successfully exported to #{mypath}"
              Lastly file_loaded?("camera_export_import.rb") does not look up a file path but just an arbitrary string. That means after the file has loaded, we have to tell it SketchUp at the end of the file by using the same string: file_loaded("camera_export_import.rb")
              Otherwise it looks good for the first script! πŸ‘ We are always happy if people accomplish the first step . Once you're infected by Ruby, you can not get away from it.
              • C
                careca
                hi Aerilius, thomthom, all.
                thanks for the feedback, i have updated the script accordingly and replaced it in my original post.
                regards,
                martin
                p.s. advanced camera tools would be great - maybe you can convince our sysadmins to install it for us πŸ˜‰
                  Should be bundled with SketchUp 8... Maybe you need to enable it under you list of Extensions?
                  Anyway - looking forward to seeing more plugin creations! πŸ˜„
                    rv1974
                    Could you add support for hidden geometry, visible layers, style and shadows please?
                      jpalm32
                      Is that a pro tool only? Not in my free 8.
                      Not in Ext. list either
                        Ah! Now that's a good point! Could very well be a Pro feature. Didn't think of that. 😳
                        • C
                          careca
                          Re: [Plugin] Camera Settings Export/Import
                          Postby rv1974 on Wed Aug 29, 2012 11:36 am
                          thanks for your comment - but to be honest, this was not the intention of this plugin, I only wanted to transfer camera settings between files. going into "hidden geometry, visible layers, style and shadows" will require to write a script for transferring complete scenes/pages, a completely different approach...
                          martin
                          • C
                            careca
                            "...with Maintenance 2 release, ACT installs with SketchUp 8.
                              jpalm32
                              Not free version! Unless I'm getting a missing module.
                                mirale999
                                Great plugin~ I was worrying how to compare two designs the very last minute~
                                paranoia is a higher form of awareness...
                                • F
                                  floffy1983
                                  Works exactly as advertised,thank you.
                                    ACT is a Pro-only add-on...
                                    Just like LayOut, Solid tools, some Exporters/Importers etc...
                                    • G
                                      grasset17
                                      Merci beaucoup pour ce script qui fonctionne Γ  merveille
                                      • Q
                                        qazokm
                                        Finally I found it, thanks
                                        • lsztukaL
                                          lsztuka
                                          I have the same problem with going back to older designs often. The script does what it should in a fast and simple way. It helped me a lot! Thanks!
                                          • OxerO
                                            Oxer
                                            Thanks you very much!! πŸ‘
                                            Very useful for a project that I'm working on.
