    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 379.6k Views 89 Watching
      Ray Brown
      Okay guys, I know I must be missing something important here. I'm using a MacBook Pro, Snow Leopard, SU8 Pro. I've loaded, uninstalled, and reloaded CompoSpray 1.4.2 at least half a dozen times. It simply will not show up anywhere in my menus. It's in the correct Plug-Ins file, and I'm pretty sure there are no other installations anywhere else. I've used the plug-in before on a Windows PC, and I love it. I miss it. I want it.
      HELP ME!!! Please!!
      PS: I'm not a SketchUp newbie, but I'm also not a techie. I need plain English, simple words, pictures if possible. Thx.
      Ray
      Ray Brown
      Ray Brown Urban Design
        The tool has a loader made by compoSprayToolbar.rb which is in the 'plugins' folder.
        There is also a subfolder of files - 'CompoSpray'.
        The location of the plugins folder is in the MAC hd... lib - as outlined on the first page of the tool's PDF help-file.
        It adds a submenu in the 'Draw' menu that runs the tools...
        It also makes a toolbar that needs to be activated from the 'View' menu 'tool-palette' submenu list...
        Because it uses lingvo files for locale translations you might think that it might needs deBabelizer.rb in 'plugins' [which is supplied with several of my own tools] - however, Didier has made up a hash to do this within his own .rbs files...
          Sir
          Is it possible to set the density of the components sprayed?
          what are the trials to drop components? - this model has just gone past 64000 ❓
          • mitcorbM
            mitcorb
            Hi, Sir/ Mat: The density or frequency of the components is currently controlled by the choices of by vertex/ vertices, or by the use of "brushes" with triangular or rectangular shapes. See the first page of this topic and read down and you will see this mentioned. I am not entirely sure if I understand your question about "trials"?
            • Didier BurD
              Didier Bur
              @Sir: density is set with the "pressure" parameter of the dialog box.
              Take a look at the user guide just in case... 😒
              DB
                Sir
                haha I did read the included pdf, couldnt see it - must have missed it.
                so what are the trials to drop components? does the plugin try to drop all the components in exponentially increasing numbers till it drops them all?
                • Didier BurD
                  Didier Bur
                  No, it drops components one by one but when it cannot drop an instance at the location the ray hit the surface, this is considered like a "trial".
                  DB
                    satipatana
                    @dcrites said:
                    Does anyone have a solution for the problem which Pilou posted earlier? I have a 15" HP Laptop running windows 7, with Google Sketchup 8 -
                    I'm a Landscape Architecture student, so spraying trees rather than placing them individually would be an absolute godsend. But if I can't get to the bottom of the screen, I can't do much. I've tried using the 'tab' key to get to the 'spray' icon, but it doesn't seem to work (though tabbing over to the 'close' icon does. Arg.
                    768 pixels is the maximum height on my monitor.
                    I had the same problem in a laptop asus K55V with the same maximun resolution for the screen. I don´t know if yours has this feature but my laptop alows to change the orientation of the scren using alt+ctrl+arrows. So, to use the plugin I change the orientation to vertical and then i can see displayed the ok button at the bottom. I hope you can at least use it this way.
                    • C
                      careca
                      Hi.
                      What tweak would be needed to make this fantastic plugin work under the portable plugins extension? So far it would not show up in the Draw menu. I assume it has to do with the path reference somewhere?
                      Thanks.
                      martin
                        matt.gordon320
                        Hi Didier,
                        I'm getting this error when trying to add CompoSpray to my plugins library that's hosted on my company's network drives (utilizing Fredo6's 000_Additional_Folders script). Any suggestions on how I can fix it so I can avoid the error, and still deploy the plugin network wide?
                        I'm trying to learn Ruby for SketchUp, so let me know if my assumption is correct. The error is resulting from CompoSpray being directed to look at C:...Plugins for the language file instead of the location that Additional Folders is redirecting it to, correct?
                        • Didier BurD
                          Didier Bur
                          yes, u're correct. I'll check the code.
                          DB
                            sidewalk
                            I'm getting the "No Component Selected" error message, even when a component IS selected in the drop-down menu. The error is occurring across different files and components. Any suggestions?
                            Sorry if this issue has previously been addressed.
                            • X
                              xaideoe
                              @matt.gordon320 said:
                              Hi Didier,
                              Same error here on Mac... Only in the new version.
                                PM the author - Didier - he may have forgotten about fixing it...
                                He has compiled his entire code set in the subfolder - so it's not readable.
                                It's a good idea to setup a reference to the folder path in readable code [e.g. the loaded rb file] that the rbs then uses.
                                Ruby's FILE doesn't work inside rbs files, but he could have set in the loader rb...
                                $cs_Folder=File.join(File.dirname(__FILE__),'CompoSpray')
                                and then used that is his rbs compiled code... instead of the hard-coded
                                File.join(Sketchup.find_support_file('plugins'),'CompoSpray') that then looks in the wrong place IF the install is NOT into the standard folder...
                                • dmonticalboD
                                  dmonticalbo
                                  How come it doesn't work on SketchUp 2013?
                                    Can you explain what "doesn't work"? It's a bit vague description. Do you get any errors installing or using? (Keep Ruby Console open. Window > Ruby Console)
                                    Unexpected behaviour during operation?
                                      jackwatson
                                      I can't seem to get it working on sketchup 2013 either.
                                      Installation seems to be fine, as the icons appear in the toolbar, but clicking 'Components Spray [Top-Down]' and 'Components Spray [Perpendicular]' does nothing.
                                      Clicking 'Settings' brings up a dialog box with a couple of drop down options, but playing with these seems to do nothing to make the actual tool function properly... unless I'm doing something wrong, which is a strong possibility 😄
                                      Any help would be appreciated!
                                      • N
                                        Nightgaunt
                                        I am having the same issue with SketchUp 2013.
                                        Ruby console reports the following when spray on horizontal is clicked.
                                        Error: #<Errno::EACCES: Permission denied - C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/CompoSpray/csSettings.html>
                                        (eval):373:in initialize' (eval):373:in new'
                                        (eval):373:in write_cs_dialog' (eval):111:in compoSpray_main'
                                        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/compoSprayToolbar.rb:17
                                        (eval):373:in `call'
                                        (eval):373
                                        Which is odd as it is the only plugin to which this happens. Any ideas?
                                        .......Changing permisions for the "CompoSpray" folder in Plugins directory using Windows Explorer "properties" is a good place to start! Just answered my own question. 😳
                                          Certainly looks like a 'permissions issue'.
                                          Ensure that your Plugins folder... and all of its contents - its files and its subfolders and their files have FULL read/write properties>security permissions set for everyone involved, and they apply to all contents !
                                          • OxerO
                                            Oxer
                                            Hi, I'm having problem with the CompoSprayES.lingvo file and with the components name. I explain, if the words into translation file or into component name have accentuation signs, the plugin doesn't work.
                                            Examples:
                                            In .lingvo file
                                            Triángulo--> plugin doesn't work Triangulo--> plugin works
                                            Octógono--> plugin doesn't work Octogono--> plugin works
                                            In component name
                                            Trébol--> plugin doesn't work Trebol--> plugin works
                                            Árbol--> plugin doesn't work Arbol--> plugin works
                                            SU8 and Mac OSX 10.9
                                            • 13
                                            • 14
                                            • 8 / 14
