    DWG Import trouble
    4 Posts 4 Posters 301 Views 4 Watching
      Dc2Productions
      Good morning all!
      I'm currently working on a project with vendor supplied CAD files in .dwg format.
      The problem is, when I view the file in a DWG viewer (screen on right) everything looks fine.
      However when I import the file into SU, (screen on left) it barely imports anything!
      This is not the first time this has happened so I would really love to find a solution to this.
      Im confused as to how the elements could be there in the viewer but not import when bringing into SU? 😒
      If anyone has a solution to this problem, please pass it along!!
      Dan
      .dwg file from vendor
      my screenshot of problem
      • pbacotP Offline
        Same result here.
          It contains a 'Proxy' object.
          I opened it in CAD and Exploded it and got a lot more to Import...
          BUT it is still pretty much useless !
          • ToboboT Offline
            Tobobo
            Some of the more recent AutoCAD programs allow a fbx or obj export. That could be a better way of getting a good transition.
            I could do it for you, if you can't with your version.
            Toby
            Philippians 4:13
