    Night render test
    renderpluginsextensions
    4 Posts 3 Posters 616 Views 3 Watching
    • eidam655E
      eidam655
      hi all,
      i'm fooling around with night renders with SU+VRay. the test scene is simple - a VRay plane, a box with windows, a light inside the box and some environment. this is what i've come up with; putting the obvious need for post-production aside, what do you think?
      the light is VRay's Rectangular light, i kept the physical camera on and adjusted exposure accordingly (shutter speed 10, F-stop 4, ISO 100), reduced the GI and BG color multipliers to 0,1, kept the GI color on TexSky and switched the BGcolor for a HDRi.
      the render
      I'm using SketchUp 2017, V-Ray 3.4
        rspierenburg
        I think your rendered scene is too warm in contrast with your rather cold background. The light should be warm of course but your shadowed area needs to be a lot bluer. If I remember correctly there is somewhere in the Environment tab that can help change that. If not it will have to be done in Photoshop afterwards.
        • V
          valerostudio
          My suggestion for night renders is to use a low res HDRI that is blurred in your GI slot and a hi res HDRI for your background for reflections. SIBL has a nice free collection http://www.hdrlabs.com/sibl/archive.html Once you have your environment, then you can work on lighting the interior of your cube.
          • eidam655E
            eidam655
            thanks, HDRi probably is the way to go with night scenes... i still have to find my workflow though, so thanks for the tip πŸ˜„
