    [Plugin] ToolbarBuilder
    32 Posts 9 Posters 4.3k Views 9 Watching
    • F Offline
      function
      pressing the save button does nothing for me 😕
      • renderizaR Offline
        renderiza
        If you have SketchUp Free Version you might need to do this...
        1. Open your default Plugin Folder.
        2. Make New Folder with name "Toolbars"
        3. Try Plugin Again.
        Cheers!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • F Offline
          function
          ah that did it! thanks
            Check you have FULL read/write security permissions to the Plugins folder, the manual creation of the subfolder might have fixed it for now but without FULL rights you will get problems with some scripts...
            • H Offline
              hebeijianke
              Hope it can support chinese language
              add some strings
              <!DOCTYPE html>
              <html lang="en-US">
              <head>
              [highlight=#ff4040:2056xzo0]<meta http-equiv="content-type" content="text/html;charset=utf-8">[/highlight:2056xzo0]
              	<title>Smustard ToolbarBuilder</title>
              	<style type="text/css">
                RickW
                Version 1.0.2 is now uploaded. I added a third button that loads all saved custom toolbars with a single click.
                The problem with generating the buttons at SU launch is that not all .rb files have been loaded when ToolbarBuilder loads, and thus some commands have not been created. This causes errors when the plugin attempts to create the buttons. I will continue to explore possible resolutions to this issue.
                RickW
                www.smustard.com
                • KrisidiousK Offline
                  Krisidious
                  How do we make custom bars for plugins that are not listed?
                  By: Kristoff Rand
                    RickW
                    I'll have to investigate that one. Right now, the plugin queries Toolbars and Command items to generate its list of items for customization. I'll have to see if there's a way to query (usually older) plugins that don't use the Command structure for creating their menu items.
                    EDIT: Are there any in particular that you don't see?
                    RickW
                    www.smustard.com
                      Krisidious
                      The one's I'm interested in making toolbars for are SDM tools, Vali Architect and ThomThom's many plugins
                      By: Kristoff Rand
                        RickW
                        Version 1.0.3 is now online, which has full autoloading of saved toolbars at launch, and they remember their positions!
                        Now to investigate Krisidious's request...
                        RickW
                        www.smustard.com
                        • panixiaP Offline
                          panixia
                          i can't see the wire tool button
                          • F Offline
                            function
                            Having trouble saving in the new version. I did a clean install of the new sketchup, upgraded to IE 10, turned off all firewalls and made sure the folders all have full read/write. The new version also does not show ordinary sketchup commands.
                              RickW
                              That is correct. It can only address Ruby commands created with UI::Command. Plugins that do not use this (i.e., they create menu items only), will not be available. This is a limitation of the Ruby API.
                              RickW
                              www.smustard.com
                                RickW
                                Strange, it appears on my machine. Try opening the Ruby console before launching the WebDialog and see if there are any messages.
                                WebDialog
                                Resulting Toolbar
                                RickW
                                www.smustard.com
                                • F Offline
                                  function
                                  can't save to Toolbars folder
                                  ToolbarBuilder callback ; save
                                  Error; #<NameError; undefined local variable or method `d' for #<Smustard;;ToolbarBuilder;0xb369--->>
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ToolbarBuilderPro.rb;283;in `write_file'
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ToolbarBuilderPro.rb;258;in `create_html'
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ToolbarBuilderPro.rb;283;in `call'
                                    RickW
                                    I'll look into it.
                                    EDIT: fixed (had a variable left over from command line testing, converted it to the "real" variable).
                                    Download 1.0.5 for the fix.
                                    RickW
                                    www.smustard.com
                                    • 2 / 2
